What it does is stores the data in the database as this...
ALTER TABLE phpbb_users ADD user_xfire varchar( 255 ) NOT NULL DEFAULT '';
This stores and even returns a value on the editing of a profile so that part works.
This is what is used on the template side...
<!-- IF postrow.U_XFIRE --><li class="xfire-icon"><a href="xfire:add_friend?user={postrow.U_XFIRE}" onclick="return xfireCheck();"><img src="http://icon.alanedwardes.com/xfire/{postrow.U_XFIRE}" title="{L_XFIRE} {user_xfire}" border="0" /></a></li><!-- ENDIF -->
As you can see I am using a third party script for that but I have something done up I think may work but isn't.
error_reporting(0);
function xfire_online($user){
$target_url = ('http://www.xfire.com/profile/'.$user.'/');
$ch = curl_init();
curl_setopt($ch, CURLOPT_USERAGENT, $userAgent);
curl_setopt($ch, CURLOPT_URL,$target_url);
curl_setopt($ch, CURLOPT_FAILONERROR, true);
curl_setopt($ch, CURLOPT_AUTOREFERER, true);
curl_setopt($ch, CURLOPT_RETURNTRANSFER,true);
curl_setopt($ch, CURLOPT_TIMEOUT, 10);
$do = curl_exec($ch);
if (!$do) echo('Error');
$replace = str_replace("\n", "", $do);
$replace = str_replace(" ", "", $replace);
$replace = str_replace("<strong>Status</strong><br />Online</p><p><strong>", "wooitsonline", $replace);
preg_match("/wooitsonline/", $replace, $matches);
if($matches[0] == 'wooitsonline'){
return 'online';
}else{
return 'offline';
$username = $_GET["username"];
$image = xfire_online("$username");
if ($image == 'online') echo('Online');
if ($image == 'offline') echo('Offline');
The JavaScript part is this...the php script generates a query to check xfires user page for online status which returns an image. I want it so when they click the image it uses the url to add a person, if they do not have xfire installed and it returns an error I want a popup box to open xfires download page. I've tried this and this is what I have...
var activex = ((navigator.userAgent.indexOf('Win') != -1) && (navigator.userAgent.indexOf('MSIE') != -1) && (parseInt(navigator.appVersion) >= 4 ));
var CantDetect = ((navigator.userAgent.indexOf('Safari') != -1) || (navigator.userAgent.indexOf('Opera') != -1));
function oopsPopup() {
if((navigator.language && navigator.language.indexOf("ja") != -1) || (navigator.systemLanguage && navigator.systemLanguage.indexOf("ja") != -1) || (navigator.userLanguage && navigator.userLanguage.indexOf("ja") != -1)) {
var URLtoOpen = "http://www.xfire.com/downloads/";
} else {
var URLtoOpen = "http://www.xfire.com/download/now/";
var windowName = "oops";
var popW = 540, popH = 305;
var scrollB = 'no';
w = screen.availWidth;
h = screen.availHeight;
var leftPos = (w-popW)/2, topPos = (h-popH)/2;
oopswindow = window.open(URLtoOpen, windowName,'width=' + popW + ',height=' + popH + ',scrollbars=' + scrollB + ',screenx=' +leftPos +',screeny=' +topPos +',top=' +topPos +',left=' +leftPos);
return false;
if(typeof(detected) == "undefined" && activex) {
document.write(
['<script language="VBscript">',
'Function isXfireInstalled()',
'on error resume next',
'Set oXfire = CreateObject("Xfire.Detection")',
'isXfireInstalled = IsObject(oXfire)',
'Set oXfire = nothing',
'End Function',
'</script>'].join("\n")
function xfireCheck() {
if(CantDetect) {
return true;
} else if(!activex) {
var xfireMime = navigator.mimeTypes["application/x-xfire"];
detected = true;
if(typeof(xfireMime) == "object") {
return true;
} else {
return oopsPopup();
} else {
if(isXfireInstalled()) {
detected = true;
return true;
detected = true;
return oopsPopup();
function loadDetection() {
if(document.getElementById && document.getElementsByTagName) {
if (window.addEventListener) window.addEventListener('load', addDetection, false);
else if (window.attachEvent) window.attachEvent('onload', addDetection);
function addDetection() {
var pageLinks = document.getElementsByTagName("a");
for (var i=0; i < pageLinks.length; i++) {
if(pageLinks[i].childNodes[0] && pageLinks[i].childNodes[0].src) {
pageLinks[i].onclick = function sChk() { return xfireCheck(); }
loadDetection();
It's like I am "almost" done but can't finish it for some reason. Any help would really be appreciated.
