Problems centralising my website
6 replies to this topic
#1 Paneth
  • 8 posts
Posted 11 September 2008 - 02:55 PM
Hello everyone
So to set the scene, I've currently been working to code my first weblayout, and although progress has been slow it has been steady and I feel I am reaching the final stages of development. However it is at this point that I have reached some difficulty.
I am currently attempting to centrally align my website and I have currently used a technique that I have found suggested on many tutorial websites;
div {margin-right:auto;margin-left:auto;width:800px;}
. However the code seems to extend my background and although it does cause it to become centrally aligned relative to the background a scrollbar is necessary in order to see it.
Here is the layout without the centralising piece of code;
And here is the layout with the centralising code and resultant problem;
(sorry about the image quality but they are just to show the problem)
Finally here is a section of the code relating to the alignment;
HTML
<body>
<div id="wrapper">
Content etc
</div>
</body>
CSS
body {
text-align: center;
background-image: url(images/bg_gradient.gif);
font-family: verdana, arial, helvetica, sans-serif;
font-size: 0.8em;
color: #616161;
margin: 0;
padding: 0;
#wrapper {
position: absolute;
width: 800px;
margin: 0 auto;
text-align: left;
I apologise for taking so long to explain but I hope you have a clear enough description to be able to help me with my problem and I really look forward to your solutions!
Paneth
#2 rc69
    PHP Master PD
  • 3,827 posts
  • Interests:Web Development
Posted 11 September 2008 - 05:55 PM
1. Remove the text-align properties from both the body and #wrapper (they aren't needed, though they aren't technically hurting anything either).
2. Remove position:absolute; from #wrapper.
#3 Arsenal19
  • 41 posts
Posted 11 September 2008 - 07:44 PM
Try this....
This is the code I use to align my website.
#wrapper {
width:800px;
margin-right: auto;
margin-left: auto;
text-align: left;
clear: both;
height: 100%;
The text-aligns weren't hurting you. You can leave them in if you want the text to show up left inside your wrapper.
Margin-left and right use to auto to align the div inside its container (ie. body). Hope this helps let me know if you have any more problems.
Arsenal19
#4 _*MasterMind_*
  • Guests
Posted 12 September 2008 - 06:00 AM
Thats the proper piece of code ;)
I am sure it will work for Paneth
All the best dude :P
#5 Paneth
  • 8 posts
Posted 13 September 2008 - 09:57 AM
Hey everyone,
Thank you so much for all of your replies but unfortunately for me none of them seem to be working :friends:. After trying each method I have found that in fact the only attributes which do make a change to my layout are the text-align elements. (however I understand that my IE7 browser should infact not require the text-align elements and it was only for previous browsers which would not have accepted the margins on the divs, which is also confusing!)
I have attached below my HTML and CSS files, and I would be extremely grateful if you could have a look so that you can see if there is anything I'm doing wrong; I'm sure you'll find alot but primarily about the centralisation would be really great :flowers:.
Attached File  medweb.html   7.92K   133 downloads
Attached File  medstyle.1.css   11.57K   139 downloads
Thank you!
Paneth
#6 Ghost
    Honored P2L Member
  • 675 posts
Posted 14 September 2008 - 08:56 PM
The code I use is:
CSS
body{
text-align: center;
margin: 0;
padding: 0;
#wrapper{
margin: 0 auto;
text-align: left;
width: 900px;
The text-align:center; centers the layout in IE6 because IE6 doesn't read margin: 0 auto like Firefox does. The text-align: left; then corrects the text alignment.
#7 Paneth
  • 8 posts
Posted 19 September 2008 - 12:05 PM
Hey everyone
Thank you so much for the help!
Just in case anyone else ever happens to experience the same problem; and I know this forums are really helpful for people who want to learn, the issue I was having was as a result of using absolute positioning.
The absolute positioning was overriding the "wrapper", which meant that the pictures/content etc all went to the exact left and top attributes. In order to centralise the website using a wrapper you will have to use relative positioning.
Now for me relative positioning was another hurdle I wasn't ready to face, so what I would suggest is that use the following html:
<body>
<div id="wrapper">
Content
</div>
</body>
</html>
and corresponding css:
body{
text-align: center;
margin: 0;
padding: 0;
#wrapper{
position: relative;
margin: 0 auto;
text-align: left;
width: 800px;
With the position: relative; element in the wrapper of your css you are now free to use absolute positioning in the width that you have set! :P
For more information I found this
site really helpful!
Once again thank you to everyone for your help and I hope this helps anyone else with the same difficulty.
Paneth
