Shoutbox Help
1 reply to this topic
#1 balofagus
  • 54 posts
Posted 16 April 2005 - 11:11 AM
I'm using a shoutbox from myshoutbox.com. I was wondering if there is any way to make the background of the shoutbox (through some fancy wonder code) transparent because it kinda disrupts the grapiednt and looks funny. I know that their are codes to make your own shoutbox/ tagboard w/e. But I plan on using geocities till I can afford something else and I am pretty sure that geocities doesn't support that kinda stuff, right?
Well heres a pic of what the shoutbox looks like:
Thanks for the Help,
Balofagus
#2 Spooky
    Rooster
  • 463 posts
  • Interests:Web Design, Programming, Client Management, Web Hosting, Tutorial Writing
Posted 16 April 2005 - 12:19 PM
To be quite honest, www.saybox.co.uk is a lot nicer. Although, do they not support the transparent name? Try putting transparent where the hex code is. I know this works with some shoutbox providers, and I do believe that saybox supports it.
