Need help with printer driver
  • Please log in to reply
1 reply to this topic
#1 thedanphillips
thedanphillips
  • 8 posts
Posted 28 March 2011 - 04:09 PM
Hi, I need a printer driver that doesn't require me to have the printer connected via usb. Trying to connect this over a network to a server in another office and can't install the driver because it asked the device to be plugged in via usb and that isn't geographically possible since it's 600 miles away. Long distance relationships are so hard! Anyway, if you could help me find it I'd greatly appreciate it! My skill with Google is very feeble, could just be that I'm stupid also.
Model:
HP LaserJet p1006
Edited by thedanphillips, 28 March 2011 - 04:16 PM.
#2 digital signage
digital signage
  • 6 posts
  • Interests:Digital signage software solutions
Posted 15 December 2011 - 01:15 AM
To connect to a printer on a network
  • Open Printers and Faxes.
  • Double-click Add Printer to start the Add Printer Wizard, and then click Next.
  • Click A network printer, or a printer attached to another computer, and then click Next.
  • Connect to the desired printer using one of the following three methods.
    Searching for it in the Active Directory
    If you are not logged on to a domain running Active Directory, this method will not be available.
    • Click Find a printer in the Directory, and then click Next.
      If needed, change the default printer location listed in the Location field by clicking the Location Browse button, and then choosing the appropriate location.
    • Click Find Now.
    • In the list that appears, click the printer you want to connect to, and then click OK.
    Typing the printer name or browsing for it
    • Click Connect to this printer, or click Next to browse for a printer.
    • Do one of the following:
      • Type the printer name using the following format, and then click Next:
      \\printserver_name\share_name
      • Browse for it on the network by clicking Next, locating the printer in Shared printers, and then clicking Next.
    Connecting to an Internet or intranet printer
    Connecting to a printer using its URL allows you to connect to printers across the Internet, provided you have permission to use that printer. If you cannot connect to your printer using the general URL format above, please see your printer's documentation or contact your network administrator.
    • Click Connect to a printer on the Internet or on a home or office network.
    • Type the URL to the printer using the following format, and then click Next:
      http://printserver_name/Printers/share_name/.printer
  • Follow the instructions on the screen to finish connecting to the printer.
    The icon for the printer appears in your Printers and Faxes folder.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • You can also connect to a printer by dragging the printer from the Printers and Faxes folder on the print server and dropping it into your Printers and Faxes folder, or by right-clicking the icon and then clicking Connect.
  • After you have connected to a shared printer on the network, you can use it as if it were attached to your computer.
Information about functional differences
Your server might function differently based on the version and edition of the operating system that is installed, your account permissions, and your menu settings. For more information, see Viewing Help on the Web.
