hey, i made a new header for my website and the way i made it was by making a multi layer image in photoshop then inputed that into image ready, from there i sliced it up to make buttons and then i animated it. But the problem now is that each image loads at a different time, so that means the animation dosnt line up correctly (see what i mean here My Webpage nrek). if anyone could give some ideas on how to fix it ,that would be great.
Sliced .gif Loading Problem
Started by nrek, Apr 27 2005 07:50 PM
3 replies to this topic
Posted 27 April 2005 - 07:50 PM
Posted 27 April 2005 - 07:53 PM
Well I don't know What I think I would do is make it all one picture, then for the buttons I would use hot spost that are placed over top of the button and then you link them. I will try and think of other ideas of what you can do.
dEcade
dEcade
Posted 28 April 2005 - 02:11 AM
the load time on that is awfull, size it down if you can
Posted 28 April 2005 - 07:10 PM
only flash can do something like that.
if everyimage loaded at exactly the same time then you would get what you want. but thats impossible. even a 1 second lapse in 1 image loaing at a differnt time doesnt work wright.
or u can do what decade said and make hot spots?(imagemap) and maybe it will make the load time even longer!
you should just not go animation heavy, are u a new user that just learnt to do that or something anyway?
its played out.
its played out.
