Making ice cube material in cinema 4d
3 replies to this topic
#1 scagger
  • 1 posts
Posted 17 May 2005 - 10:30 AM
hi i am a N00B to cinema 4d but i would like to know if anyone could help me to make a material for an ice cube thanks
Scagger
#2 funkysoul
    The Funky Stuff
  • Publishing Betazoids
  • 2,307 posts
Posted 20 May 2005 - 02:46 AM
Search for some 3dsmax tutorials on making Ice Cubes.. There should be one or two around, I don't have the link bookmarked
You can transfer the settings used in max to cinema (more or less)
Have a try
Funkysoul
#3 i-pixel
  • 5 posts
Posted 20 May 2005 - 05:32 PM
just open up photoshop, and render some clouds, then give them a heavyish gaussian blur, next up, make a new white layer, and get some grunge brushes and DELETE the white, and drop the opacity.
Not sure if this will work, but worth a try :P
#4 Subversive
  • 8 posts
Posted 21 May 2005 - 05:26 PM
never tried, but a grunge with a light blue balance should produce something...
also, C4D material files are commonly shared in p2p networks. if you cant do it, I suggest you search for it.
