Indesign basic questions
indesign pages master page resize text
  • Please log in to reply
1 reply to this topic
#1 Trinacria
Trinacria
  • 1 posts
  • Gender:Female
  • Interests:Architecture, Art & drawing, travelling, books+cinema+music
Posted 26 July 2013 - 12:25 PM
Hi to all!
I am a new user, I hope to do not make mistakes.
I have some questions to ask, about basic characteristic of this software.
1 - how can I reduce all the pages on Indesign, transforming also all the object that they contain? I know that I can go on 'file -> document setup' and modify the dimensions, but all the object remain the same. It is a problem when I should print a portfolio/book in different measures.
2 - how can TEXT label be expressed on cm rather than pt? Perhaps in Indesign this isn't possible?
3 - Master page contents are always below page objects? There isn't a way to bring to front the master page objects?
4 - is there a way to have guides in every page when I drag one from the rule?
Thank you in advance and sorry for my english :)
#2 WSimpson
WSimpson
    P2L Admin
  • Admin
  • 59 posts
  • Interests:P2L admin, graphic designer, cat lover, books and comics addict.
Posted 29 July 2013 - 08:29 PM
Hello Trinacria,
1 - You may want to check this link (from the Adobe website). Maybe liquid layouts can be useful to you.
2 - Typeface size is measured in points by default in InDesign, but you can enter your size in cm in the Character panel (or go to Type > Size > Other) and InDesign will convert centimeters to points automatically. If you enter a 2 cm size, it will be converted to 56.692913386 points. I recommend using points since its the standard.
3 - Plenty of great info here on master pages. You may want to use layers for what you want to do.
4 - Drag a guide on your master page, it will appear on all your pages.
Also tagged with one or more of these keywords: indesign, pages, master page, resize, text
