No sound in flash?
2 replies to this topic
#1 Cup_O_Dirt
  • 4 posts
Posted 05 June 2005 - 07:00 PM
I had a problem a few months ago and i couldnt tell you what exactly happend but what i can tell you is that its resulted in me loosing the ability to hear sound from Flash and other such applications on the internet. If anyone has any idea what it could be, im stumped and it would be very appriciated.
-Corey T
#2 pr0jekt
  • 171 posts
  • Interests:Anything Web.. mostly coding
Posted 05 June 2005 - 11:11 PM
youd have too look through the sound settings on your computer. Try using another browser if it is only a browser issue and see if anything changes... that should narrow down the problems a little.
post your results back here
#3 Cup_O_Dirt
  • 4 posts
Posted 06 June 2005 - 03:44 PM
I tried what you suggested and its not a browser issute unless explorer is having it too. And i check over all the sound settings and everything seems to be normal. i can hear sound from everything else, just not applications like flash on the internet, i must say it is rater annoying..
