help
4 replies to this topic
#1 ScubaSteve
  • 10 posts
Posted 26 June 2005 - 10:36 PM
ok well i need to make a font like camo...
as if there was camo fabric and someone cut out the words
CONCLAVE
out of the camo...
so how do i do that on photoshop
#2 BeaverElfeater
  • 640 posts
Posted 26 June 2005 - 11:05 PM
find a camo picture on google (one with small camo spots should work better), paste the camo picture in photoshop, click on edit>define as pattern
type the text in white, then go to layer>>later style>>>blending options, check pattern overlay, and select the pattern u just made in photoshop, ur done now mess with any settings u want
Edited by BeaverElfeater, 26 June 2005 - 11:09 PM.
#3 Bryco
  • 8 posts
Posted 26 June 2005 - 11:26 PM
Learn something new everyday. :) Nice little tidbit of info there.
#4 ScubaSteve
  • 10 posts
Posted 26 June 2005 - 11:46 PM
thanks that worked awesome.
i will have plenty of questions in the future, im just getting into photoshop.
heres anohter one lol...
how do i make a silouette (sp?) of like a solider...
:P
#5 Silent Chaos
  • 72 posts
Posted 27 June 2005 - 08:45 PM
about the silouette you need to make a selection around him with either the pen, marque, or magic wand tool. then you create a new layer and fill the selection with black. then delete the picture layer and you will have a silouette. you can now feather it (select-> feather by about 5 pixels then select-> inverse and hit delete a few times. i hope this helps
