Dreamweaver problems
Posted 27 June 2005 - 04:10 AM
I have mad a layout in ps, im very happy with it i have even sliced it in Image ready no problem. I have also set the boxes to bg image to i can type in dreamweaver, but when i type my content in ANY form of text is looks all pixelated.
pixelated - this may not be the correct term but what i mean is, if u use ps texts without anti alias turned on and NO! styles it looks all pixelated or rough, well thats what dreamweaver is doing with everything i type into a content box. I have played around with the styles etc but nothing seems to work.
I use dreamweaver3 and about 1year ago i used to use it and NEVER had this problem so im sure there is a simple soloution,
thanks for taking the time to read this and i really hope you can help
Hex
Posted 27 June 2005 - 04:15 AM
Posted 27 June 2005 - 04:43 AM
http://img178.echo.c...89/htmlq3rl.jpg
also i have tested a few more things when i create a new page the text looks fine with the default page it is ONLY the fonts i put into the font list that are causing me problems but SURELY dw lets you use other fonts than the defaults.
also the screen is the layout i cut does that effect the text? , because im only typing ontop of a background.
thanks again
Posted 27 June 2005 - 05:38 AM
Stick to one of the web safe fonts and try that (arial and verdanda etc). Or replace the text with an image.
Posted 27 June 2005 - 07:09 AM
i was looking through settings like a mad man.
anyway could someone provide me with a list of all the default fonts that can be used on a site so everyone can view them ??
thanks for your help, im at work at the moment so i will report back this evening do tell you if it is working okay.
#6
Posted 27 June 2005 - 07:30 AM
Arial, Helvetica, sans serif
Times New Roman, Times, serif
Courier New
Verdana
etc
#7
Posted 27 June 2005 - 08:22 AM
so if i just use on of those for everything i guess it should be fine.
also this is abit off topic, but do you happen to know what i need to paste into the html style to make all my links without a underline and to only go bold when there is a mouseover. so the effect would be bold when someone moves there mouse over to make links more apparent.
thanks for all the help much apreciated.
#8
Posted 27 June 2005 - 08:52 AM
Do a search on the net, CSS is excellent.
In dreamweaver (not sure on your version), theres a design window, in there should be CSS styles. If you click on "new CSS style", and choose advanced you should be options:
a:link
a:visited
a:hover
a:active
If you alter a:hover and put underline in the tickbox it will affect all links that are attached to the style sheet.
I hope this makes sense, have a play with it:D
#9
Posted 27 June 2005 - 07:29 PM
i have two new ones though
1) how do i create a link in dw that opens in a new page and only shows a image, so for example a 500x500 image in a browser box.
2)is it possible to code in dw so the page shows a thumbnail of a image ie - orginal 500x500 , thumbnail 100x100, rather than rezing around 100 pics.
thanks
#10
Posted 27 June 2005 - 08:14 PM
<a href="http://yourimage.jpg" target="_blank">linkname</a>
2) I'm not sure you can open a new window with a specified image size. Use another page and set the width and heigth of the size smaller. Then make a link to that page.
#11
Posted 27 June 2005 - 11:17 PM
http://www.codydelong.net/ and contact him or something.
#12
Posted 28 June 2005 - 10:12 AM
could someone please tell me a good way of making my site appear as a icon rather than the plain browser logo in peoples bookmarks / favourites.
Hex
#13
Posted 30 June 2005 - 01:44 PM
Hex
I believe it's the "favicon.ico" that you are referring to. Create an image @ 16x16 pixels and save it as a jpg. Copy it to the root folder of your site and name it "favicon.ico" Vola.
**edit** Almost forgot... You need to add this before the </head>:
<LINK rel="SHORTCUT ICON" href="http://www.yourdomainhere.com/favicon.ico"/>
Jon
Edited by jonerator, 30 June 2005 - 03:29 PM.
