I have this problem in corel... I'm creating a sign that I will import in a picture later. I have to change the perspective view of the sign so it will look realistic in the picture. Ok... I use the rectangle tool in corel to create the frame of the sign with, let's say, 3pixels witdh. When I add the perspective effect on the sign the text changes perspective and the rectangle around it changes too.... but... the pixel dimension of the rectangle does not change at all. the closest and the furthest part of the "project" has the same 3pixel widht all around. That makes this look very unreal. And yes I have tried to check in the "scale with image". Is there a way to convert the rectangle, that is made of one line, into two lines with fill between? That way it would work wery well in perspective view.
Please try to help me on this one.
Regards,
Skarphedinn
Iceland
Perspective problem
Started by sksig, Jul 07 2005 11:05 AM
3 replies to this topic
Posted 07 July 2005 - 11:05 AM
Posted 07 July 2005 - 11:25 AM
Corel Draw or Photopaint? You should use the 3D perspective tool.
Faken
Faken
Posted 07 July 2005 - 11:45 AM
Faken
Faken
hmmmm...
Posted 07 July 2005 - 11:49 AM
Húha... I've found it... arrange -> convert outline to object... thanx anyway ;-)
