hey guys. Can someone tell me how to change psd file to jpg file?
NEED HELP BAD!
Started by _*Denduron_*, Jul 08 2005 12:42 AM
4 replies to this topic
#1 _*Denduron_*
Posted 08 July 2005 - 12:42 AM
Posted 08 July 2005 - 01:08 AM
File - Save as...
or. if you were planning on saving a sliced psd.
File - Save For Web...
Posted 08 July 2005 - 04:59 AM
coolaid, on Jul 8 2005, 06:08 AM, said:
File - Save as...
Posted 08 July 2005 - 02:38 PM
if im correct, there should be boxes that open up after you save telling you what quality you want the jpg to be and you can check the preview option to see how its going to look.
Posted 10 July 2005 - 12:17 AM
CTRL+ALT+SHIFT+S
Save for web is the best, it allows you to compare differen't formats and compression rations, and give you a preview of the output.
