Hi in 3ds max how to i add more matrials becuase it the matrial editor ive ran out of spaces to add more textures i know there is a way to save over the ones i am already using and start fresh but it doesnt seem to be working.
anyone have any ideas?
Problem Please Help
Started by High Definition™, Jul 18 2005 09:24 AM
2 replies to this topic
Posted 18 July 2005 - 09:24 AM
Posted 18 July 2005 - 04:06 PM
are you really sure that you don't have any more free slots???
I never used all 24 slots in my life
and I thought max 7 had already the capability to handle more slots.
Nevertheless, you can grab a plugin from Medit48 at http://www.scriptspot.com or from http://membres.lycos...zz/scripts.html.
Or what I would do in your case, is to use Multi-Sub Materials, they are limited to 1000
but even then with your 24 slots, you would have the possibility of using 24000 textures... without scripts..
Posted 18 July 2005 - 06:41 PM
cheers man thanks ill do that right now
