Text with catchy glow
Posted on October 15th, 2009
Adobe Photoshop
Morning Guys,
Today i woke up and while started to browse pixel2life.... suddenly I thought to write a tutorial.
So here we go.
This is the final image i have got.
Before beginning the tutorial...
I want to remind you that the two shades of glow used here are professionally used in many ways. Reminding you about proxicide's MKvsSF-3. He used the both glow effects in his movies to make it more catchy. But here is a quick reference to those glow shades.
Final text
 So start with a 640 x 480 document with Transparent Background and click on OK.
new page
Now Press D*. (D to make your foreground color "Black" and Background color "white). Use Alt+Backspace to fill the foreground color to background. Now you have a black background.
Now type your text:- Anything you like to type (your name or girlfriend's name whatever)
Fiolex Girls text
Now click on Layer -> New Adjustment Layer -> Color Balance
Now adjust the color balance settings as shown below.
Note:-Ensure that "Preserve Luminiousity" is checked.
shadows midtones highlights
 Click on Ok and now Select the text layer
Text Layer Selected
Click Ctrl+J to duplicate the Text Layer.
Duplicate text layer
Now duplicated text layer is selected. Click on Layer -> Rasterize -> Type
Now still selecting the rasterized layer Click on Filter -> Blur and enter the following settings in it.
blurred rasterized text
Now what you see here is giving 10 pixel blur to Rasterized text layer.
The color we see here is due to the color balance adjustment layer above the Rasterized text layer.
Now Press Ctrl+A. It will select the whole canvas.
Now Press Shift + Ctrl +C. It will copy all the layers objects in a merged clipboard data.
Now press Ctrl + N. It will open a new document......... click on OK
Now Press Ctrl + V to paste the content
Now select half of the canvas and give it a feather of 120px like this.
selected new layer
Make sure the selection is active.
Now Press Ctrl+U to open Hue/Saturation or Image -> Adjustment -> Hue/Saturation
Enter the following values Enter 125 in Hue and Press OK
hue values
 Here is the Result.
Half colored
See how easy it is .
Now you are done
Enjoy!
khote
www.freewebs.com/khotebabu
Nothing much to tell.
Depends on My mind.
