![]() IntroThis tutorial is an adaption of a script I have previously made, I have removed most of the hard to understand statements that newcomers to flash probably wouldn’t understand. It involves a small amount of triginometry so some may not understand whats happening some of the time. For this tutorial I will be using a car but you can do whatever object you like like a helicopter or whatever, and thanks to flash you can also edit it the design of your object later by double clicking it. If you would like to use the car then you can download it in the .fla file mentioned at the end of this tutorial The Tutorial1. First we create a shape to represent the car and then convert it to a movieclip make sure your movieclip is pointing upwards for example the front of the car is pointing upwards 2.. Next normal click your movieclip so that a little circle with a cross in it appears.. then open the Actions panel. If you do not know how to do this simply go WINDOW->DEVELOPMENT PANELS->ACTIONS or WINDOW->ACTIONS in some versions of flash. 3.. Now type or copy/paste the following code into the actions panel. onClipEvent (load) { //listen for key presses downCapture = new Object(); downCapture.onKeyDown = function () { switch (Key.getCode()) { case Key.LEFT: left = true; break; case Key.RIGHT: right = true; break; case Key.UP: up = true; break; case Key.DOWN: down = true; break; } } Key.addListener(downCapture); //listen for key returns upCapture = new Object(); upCapture.onKeyUp = function () { switch (Key.getCode()) { case Key.LEFT: left = false; break; case Key.RIGHT: right = false; break; case Key.UP: up = false; break; case Key.DOWN: down = false; break; } }; Key.addListener(upCapture); rotateBy = 9; //how much we should rotate every frame (L/R key is pressed) accelleration = 5; //how much we should move every frame (when Up key is pressed) function radtodeg(deg) { //convert radians to degrees (for later) return (deg/180) * Math.PI; } } onClipEvent (enterFrame) { if (left) { _rotation -= rotateBy } //rotate counter-clockwise if (right) { _rotation += rotateBy } //rotate clockwise if (up) { if (accelleration < 10) { //if is below accelleration limit then allow to accellerate accelleration++; } //calculate where the car will move to: angle = _rotation; angle = radtodeg(angle-90); by_x = accelleration * Math.cos(angle) by_y = accelleration * Math.sin(angle) _x +=by_x //move the car here _y +=by_y // and here } } The Movie should now work but if your interested in what happened then ill explain it here.... onClipEvent (load) { The script inside this is executed ONLY when the movieclip first appears in the movie downCapture = new Object(); downCapture.onKeyDown = function () { switch (Key.getCode()) { case Key.LEFT: left = true; break; case Key.RIGHT: right = true; break; case Key.UP: up = true; break; case Key.DOWN: down = true; break; } } Key.addListener(downCapture); This "captures" when the user presses down on one of the arrow keys (left, right, up and down) and stores the result in a variable.. for example when the down key is pressed the d variable is set to true upCapture = new Object(); upCapture.onKeyUp = function () { switch (Key.getCode()) { case Key.LEFT: left = false; break; case Key.RIGHT: right = false; break; case Key.UP: up = false; break; case Key.DOWN: down = false; break; } }; Key.addListener(upCapture); This "captures" when any one of the arrow keys (left, right, up and down) spring back up, or are released as some say. for example when the down key is released by the user the d variable is set to false rotateBy = 9; accelleration = 5; function radtodeg(deg) { return (deg/180) * Math.PI; } rotateBy is the number of pixels the movieclip will rotate when the left or right buttons are pressed. accelleration is the accelleration of the movieclip (how fast it moves) when the up button is pressed function radtodeg(deg) { bit is for converting radians to degrees, we need this in order to make the trig functions to work the way we want to later in the script. onClipEvent (enterFrame) { this executes the script inside every time the frame is loaded (by default 12 times per second) if (left) { _rotation -= rotateBy } if (right) { _rotation += rotateBy } every time the left button is pressed the movieclip will rotate by rot number of degrees (counter-clockwise) same for the right button, but the other direction (clockwise) if (up) { Executes the script inside whenever the up button is pressed if (accelleration < 10) { accelleration++; } If accelleration is less than 10 then the acceleration will increase by 1. This prevents the movielip from exceeding a certain speed. change the number 10 to a higher number to allow it to go faster. angle = _rotation; angle = radtodeg(angle-90); by_x = accelleration * Math.cos(angle) by_y = accelleration * Math.sin(angle) _x +=by_x _y +=by_y This part involves triginometry, it basicly determines the amount the movieclip should move horizontally (x-axis) and vertically (y-axis) and then moves it according to the result it got. ConclusionThe movie should now work, to test it simply go CONTROL->Test Movie or hold down the CTRL-ENTER buttons simultainiously Example If you would like to download the .fla source file of this tutorial please go here http://www.pixel2life.com/twodded/staff/pr0jekt/tutorials/CarControl/cartut.fla
