Create a simple php quiz system
Posted on July 8th, 2010
PHP Coding
In this tutorial I am going to teach you how to create a simple quizsystem. I saw that in these days, a lot of websites have this type ofthings. In this way, you can keep a track of what your users desires, soyou can implement it in the following versions of your site. Thisscript can also be implemented in any type of php script.
First of all, you will need to create a database in your phpmyadmin andthen run the following sql command:
CREATE TABLE `quiz` (
`id` mediumint(8) NOT NULL auto_increment,
`questions` varchar(255) NOT NULL default '',
`answers` varchar(255) NOT NULL default '',
PRIMARY KEY(`id`),
UNIQUE(`questions`)
) ENGINE=MyISAMDEFAULT CHARSET=utf8;
CREATE TABLE `money` (
`id` int(20) NOT NULL auto_increment,
`money` varchar(250) NOT NULL,
`data` text NOT NULL,
PRIMARY KEY(`id`)
Next, go into your config.php file and copy thefollowing code:
session_start();
error_reporting(0);
// Database Information
 $AdresaBazaDate = "localhost";// DB ADDRESS ( usually localhost )
 $UtilizatorBazaDate = "";// DB USER
 $ParolaBazaDate = "";// DB PASS
 $NumeBazaDate = "";// DB NAME
 $conexiune = @mysql_connect($AdresaBazaDate,$UtilizatorBazaDate,$ParolaBazaDate) or die("Nu ma pot conecta la MySQL!");
 @mysql_select_db($NumeBazaDate, $conexiune) or die("Nu gasesc baza de date ".$db."!");
 @mysql_close($AdresaBazaDate,$UtilizatorBazaDate,$ParolaBazaDate);
I assume that you already know a little bit of php since you are a socalled “webmaster” and I am not going to explain the code. If you needhelp just drop me a line through the contact form.
Next we are going to wrap up the index.php file:
include("config.php");
$sql = "SELECT * FROM quiz ORDER BY rand() LIMIT 1";
$result = mysql_query($sql);
$row = mysql_fetch_object($result);
$question = "$row->questions";
$correctanswer = "$row->answers";
$money = '20';
$today = date('Y-m-d');
if (isset($_POST['submitted'])) {
if (empty($_POST['answer']) || empty($_POST['id'])) {
echo '
You must enter an answer!
'; } else { $answer = $_POST['answer']; $sql_answer = "select * from quiz where id = '".addslashes($_POST["id"])."'"; $result1 = mysql_query($sql_answer); $row1 = mysql_fetch_object($result1); $correctanswer = $row1->answers; if (strtolower($answer) == strtolower($correctanswer)) { echo 'Congratulations, your answer was correct!'; $sql3= "INSERT INTO money VALUES ('','$money','$today')"; $res3 = mysql_query($sql3); } elseif (strtolower($answer) != strtolower($correctanswer)){ echo 'Bad answer! The correct answer was '.$correctanswer.'.'; } } } ?>
<?php echo "Question: $question"; ?> Answer:
Also, if you want to have a top.php file so you canshow for example how much money was raised, just use the following code:
include ("config.php");
$query1="SELECT money, data, Sum(money) AS SumOfMoney FROM money GROUP BY DATE_FORMAT(data, '%M %d, %Y') = NOW()";
$result1=mysql_query($query1);
$row1=mysql_fetch_assoc($result1);
echo 'Total: '.$row1['SumOfMoney'].' dollars
There you go, you have created a sexy simple quiz system. The only thingis that you have to manually put your questions with your answers inyour database. In the future maybe I will develop a better version ofthis script.
zuwebmasters
