Posted on September 7th, 2011
1961 views This is a tutorial in how to design a laptop from scratch using Adobe Photoshop. The laptop what I will try to design was taken from Dell's laptops page. Start by creating a new document of 640 x 480 pixels. Click on the screen to draw a rectangular From the top menu, go to Select -> Modify -> Smooth Select a sample radius of 20 pixels and press ok. Use the Paint bucket tool and paint the selected area with the colour of your choice. Go to Select -> Deselect so you can deselect the selected area. Tick the Inner Shadow option, change the Spread and Distance to 0 and set the Size 6 Tick the Gradient Overlay change the Angle to -145 and Press on the Gradient colour bar. Add three colour points and set their colours to: 3c3f48 232428 545760 (Starting from right to left) Choose a desktop image that you want, resize it and place it on the middle of the screen. Then go to the screen layer and delete the selected area. Using the rectangular marquee tool with Fixed Style of 517px width and 20px Height,
Now, try to move and merge the layers one above the other so the result will look like the picture bellow. Go to Layer -> Layer Style -> Blending Options Duplicate the body layer, go to Edit -> Free transform and reverse it so it will look like the image bellow On the same layer, Go to Layer -> Layer Mark -> Reveal all, choose the Brush with the black coluor selected I'm curious to see how you would do it! go to laptop deals page, choose your favourite laptop and paste your results in here.Good Luck! |
