Posted on March 16th, 2012
1661 views Christmas is almost coming. Everyone prepare theirshelves to welcome the session. Putting in a special banner on thewebsite has become ubiquitous thing. In this lesson I'd like to introduce a simple way to create banner forChristmas.
Step 1 Install and Run IncrediFlash XTreme from here Step 2 From startup menu, choose "Blank Project" & set the dimension of the project file to 600 x 320. Step 3 Under Background property menu, set the background to "image(fit)" and choosebackground.jpg as the background of the project file. Step 4 Insert the following cliparts into the scene: For duplicated cliparts in the scene you can import the clipart several times as needed. Step 5 Apply Fade effect to all cliparts above with duration 1 second as shown below: Step 6 Insert text object twice into the scene sounding "Merry" and "Christmas" respectively. Arrange their appearingby setting the effect property to "Fade" with duration 1 second as shown below: Step 7 Lastly, insert layer effect object into the scene. Choose the layer type as shown below, that's the one withred corners. Step 8 Congratulation! You have just made a simple flash banner for Chritsmas. Here is the result:
Click here to play the flash file |
