Posted on March 21st, 2012
2841 views At this moment, There is an easy way to create a photo collage. You don't need to build the template.You just need to click on the template that you want, add your photos and the other cliparts. It is so easy, isn't?
Step 1 Install and Run InAlbum from here Step 2 InAlbum will show you a startup menu, choose Collage button, then click "Create Project" button. Fill in the "Show name" and the folder location. Click on "OK" button to continue. InAlbum will let you to choose the template. For this tutorial, we choose Wedding. Step 3 To change the photo, click on a photo and replace it with your own. The other way, you can click onthe object dropdown and choose "Photo". You will see the photo properties appear on the bottom part of the window.Click on the Browse button to replace the photo with your own. For this tutorial, we use the default. To change the text, you can click on a text and retype your own text over it.It is as simple as that. If you wish you can add more photos, text and cliparts. Step 4 Once you are done, click on the Music and Settings to customize further by selecting thumbnail and musicthen click the Save Show button. Step 5 Congratulation!, your E-Card is done. You can send your E-Card by email or upload it into your own website. Here is the result:
Click here to play the flash file
