Posted on March 22nd, 2012
3145 views Easter will be coming. Usually we send e-card to friends, family and partner. It's not easy to make an animated card. You need the other program to do it. We want to show you how to make an animated e-card easily.
Step 1 You can start creating your Animated Easter E-Card by downloading the trial version from here Step 2 Run InAlbum Step 3 From menu, click on "E-Card" button. Then click "Create Project" button. Fill in the "Show name" and the folder location. Click on "OK" button to continue. Step 4 InAlbum will let you to choose the template. For this tutorial, we choose "Easter Bunny" template. Then click OK button. Step 5 To change the photo, click on a photo and replace it with your own. Theother way, you can click on the object dropdown and choose "Photo". Youwill see the photo properties appear on the bottom part of the window.Click on the Browse button to replace the photo with your own. For this tutorial, we use the default. To change the text, you can clickon a text and retype your own text over it. It is as simple as that. If you wish you can add more photos, text and cliparts. Step 6 Once you are done, click on the Music and Settings to customize furtherby selecting thumbnail and music then click the Save Show button. Step 7 Congratulation!, your E-Card is done. You can send your E-Card by email or upload it into your own website.
Here is the result:
Click here to play the flash file
