Posted on May 26th, 2012
1453 views There is question about LG Data Recovery goes: My phone (LG Optimus V) was accidentally wiped of all data, Ibelieve. I was trying to flash my phone with a new ROM and in theprocess I must have deleted all of my data and everything. However, Ijust figured out that all the data including videos, ringtones and myphotos were gone at all; I can't find them any more on both computer andmy LG when plugging in to PC. In addition, my SD card is not workingbecause I tried to burn and .img file to it but that didn't work either.Is there any service or method can let me retrieve files form LG as soon as possible? Cell Phone Data RecoveryMobile or cell phones are used in each day for our life, as aconstantly increasing variety of functions; the need of data recoveryon cell phones is necessary and growing. Generally, mobile phone data recovery service is a kind ofprofessional field in which an engineer accesses lost data on mobile viaa variety of means. It can be something as simple as quickly accessing acell phone with a broken screen to remove SIM card information, orsomething as complex as the recovery of corrupted or deleted textmessages, phone records, and even data files on newer phones. Therefore, mobile phones have to use several of operatingsystems and unique file systems; standard consumer level software isusually not a viable option. Some damaged or corrupted cell phones cannot be accessed by standard USB connections, and dedicated computersmust be used a flash data for recovery. In this case, it's necessary tochoose a data recovery software or tool retrieve damaged data for phones like LG Optimus. A good tutorial of performing data recovery for mobile phones at uMacsoft -> tutorial, you can do mobile phone data restore task by yourself at home with ease. LG Optimus TLike most Android phones available today, the LG Optimus Truns a proprietary skin over the Android OS. You get seven homescreensto customize with widgets and shortcuts (which almost seems excessive),and an app called the LG App Organizer. The Optimus T also has a featurecalled Voice Actions, which lets you use voice commands to controltheir phone. This feature is similar to iPhone Siri. Other than these unique features, however, the Optimus Tisn't all that exciting when it comes to specs. It sports a 3.2-inchdisplay, a 3.2-megapixel camera, and comes loaded with Swype for fastertouch keyboard typing, as well as all of the usual Google programs likeMaps, Talk, and Gmail. |
