![]() You can now bring your show to life everywhere, not just in front of computer. Ones is publishing your show intoportable device such as XBox, PSP and Zune. Simply use the portable device syncing software to import the resultingvideo file into those devices.
Step 1 Donwload and install InAlbum from here Step 2 InAlbum will show you a startup menu, choose "SHOW" button, then click "Create Project" button. Fill in the "Show name". For this tutorial, we use a Theme template from InAlbum. Click on "OK" button to continue. Step 3 Then select your photos. To select your all photos, Click on "select all". Step 4 To choose the template, Go to tab 3 "change Template", then "Carousel => Collage" template. Step 5 To add the other object, Click on tab 4 "decorate Show". In this case, we leave it as default. Step 6 Go to tab 5 "music & Settings" to fill in the show title, directed& starring. You can change the music too.In this case, we download it from InAlbum site. Click on"Save Show"" button to save and click on "Finish Editing" toplay this slideshow. Step 7 Now, your slideshow is done. We will show you how to publish this slideshow into Portable Device. Click on"Publish to Portable device". InAlbum will let you to choose the type of your video. We choose "Sony PSP" from the dropdown. And we change the outputfile. Then click on "Next" button to process it. InAlbum will process it. When the process is done, InAlbum will give you confirmation windows. Step 8 Your flash photo slide show is done. You can copy the video file into memory card and insert it into your Portable device.
Here is the result: ![]() |
