Posted on August 22nd, 2012
985 views Compact Flash Memory and Data RecoveryFlash memory gets its name due to its microchip arrangementin such a way, that it is section of memory cells gets erased in asingle action or "Flash". Flash memory is a form of non-volatile memory that can beelectrically erased and rewrite, which means that it does not need powerto maintain the data stored in the chip. In addition, flash memoryoffers fast read access times and better shock resistance than harddisks. These characteristics explain the popularity of flash memory forapplications such as storage on battery-powered devices. Both NOR and NAND Flash memory were invented by Dr. Fujio Masuokafrom Toshiba in 1984.The name 'Flash' was suggested as the erasuretechnique of the memory contents reminds a flash of an camera, and namewas coined expressing how much faster it could be erased "in a flash".Dr. Masuoka presented the invention with the International ElectronDevices Meeting (IEDM) locked in San Jose, California in 1984 and Intelrecognizes the potentiality of the invention and introduced the initialcommercial NOR type flash chip in 1988, with long erase and write times. How to Recover Data from Flash Memory CardMost of people use flash memory card on their business or anyother works, such as store their important document files or cherishedphotos taken for their family or friends. Have you ever considered thatif your files or photos on the flash memory card were lost or deleted byyou accidently? Do you know the method to recover data from flash memory card?When you search on google.com, there will be tons of results for you tochoose, and I suppose you probably select one of them on the firstgoogle page. However, your this problem can not be fixed either, as thearticle or product description on the google first page are not the onethat can solve the problem for you. Here I will tell you a fast andefficient way to restore data from flash memory card. First of all, you need to type keyword “data recovery fromflash memory card umacsoft” on google.com, there will be more than10,000 results displayed for you. Choose any one of them to accessuMacsoft webpage or article page, you will get a brief solution. Secondly, when reading the tutorial of uMacsoft data recoveryprogram, you need to download and run this software. You can freedownload this application on your Mac OS. Just launch it and run it justlike any other Mac application installation. Thirdly, plug your flash memory card into Mac, then apartition displayed on the program interface, you need to click it andlet data recovery software scans it to find out your lost files on thecard. Only a few minutes later, you will get a list of scanned datafiles shown on the left side of program interface. These files are theones you lost or deleted on this card. You can preview them in advanceby clicking “Preview” button, and get them back by clicking “Recovery”button. That’s it! With the tutorial above, you are able to recover files on Mac by yourself with ease and effectively. In spite of each one of these clear advantages, worse mayoccur because of system failure, battery failure, accidental erasure,re-format, power surges, faulty electronics and corruption due tohardware breakdown or software malfunctions; as a result your data maybe lost and damaged. Flash Memory Data Recovery is the procedure of restoring data from primary storage media if itcannot be accessed normally. Flash memory data recovery is a flashmemory recovery service that restores all corrupted and deletedphotographs regardless of whether a storage device was re-formatted.This can be as a result of physical damage or logical damage to thestorage device. Data even from damage flash memory may be recovered, andmore than 90% of lost data may be restored. |
