Posted on November 9th, 2012
891 views AVI File ExtensionCompressed audio file similar to a .MP3 file, but offersseveral performance improvements; these include a higher codingefficiency for both stationary and transient signals, a less strenuousfilterbank, and better handling of frequencies above 16 kHz; maintainsquality nearly indistinguishable in the original audio source. Advanced Audio Coding (AAC) may be the default encoding utilized by Apple iTunes as well as the iTunes Music Store. While the ".aac" extension is sometimes used for AAC-encoded files, they are typically saved having an .M4A file extension. AVI audio files are so common in the multimedia market, thereare lots of players can recognize this kind of audio file extension, soif you download or purchase music files online, you would find out thatthese files might be .aac format. And if you are music fans orcollectors, you must keep tons of music on your computer for eitherentertainment or business. Have you back up those important files moreoften? Do you have some useful or efficient method or service to keepyour data safe? This article will tell you how to keep AVI audio filessafe and recover .avi files on Mac successfully. AVI Audio RecoveryTo keep your AVI audio files safe, you should know whichreasons or cases could make you lost or delete audio files. Generally,the following cases may occur. • Accidentally deleted files from memory card • Formatted memory card or hard drive • Memory card got corrupted or inaccessible • Virus inflection • Power failure • Your office breaks out a fire, and your computer damaged Sounds terrible experience. But there is the reality. If youdon’t have good habit of backing up your data on computer, you may losethem someday. So from now on, backup important files periodically, justin case. Well, what if your data has been damaged or lost? Do you know how to recover data? Let me tell you. First of all, to choose professional and easy-to-use datarecovery software is your urgent task to complete. If you searching datarecovery related keywords on google.com, you will see there aremillions of results for you to choose, however, I suppose you won’t tryto click them one-by-one. Now, how to find out your target software withexact keywords searching? There is simple and directly way for you torefer to. What you need to do is to type keywords + OS system + brand,here is example for you, I type keywords like "avi recovery software Mac umacsoft"on google, then more than 9000 results would display on the screen foryou, any of them are the target result to choose. So, what you need todo is click any one of them to access its official website to downloadthe software. Generally speaking, you can free download the trialversion of recovery software to have a try to use it before you decideto purchase. Secondly, when downloading and launching recovery program,there will be a hard drive shown on the interface of software, which isyour computer partition. Then let the software scan it to find out yourlost of damaged avi audio files completely. Only a few minutes later, you can see a list of files on thesoftware, among them you are able to see your AVI audio files staythere. If you want to review them, clicking "Preview" button, "Recovery"button can help you get AVI files back with ease. |
