Posted on December 20th, 2012
Christmas will be coming. Usually you send grettings to your family and friends. It's more easier if you can send it by email. We will let you know how to make it easily.
Step 1 Install and Run InAlbum from here Step 2 InAlbum will show you a startup menu, choose "SHOW" button, then click "Create Project" button. Fill in the "Show name". For this tutorial, we use a Theme template from InAlbum. Step 3 Click on "Add photo" button and select photos from your computer. Step 4 To choose the template, Go to tab 3 "change Template", then choose Event and Christmas Collage Template. Step 5 To add the other object, Click on tab 4 "decorate Show". Clipart, we use "Event". The others, we use the default. Step 6 Go to tab 5 "music & Settings" to fill in the show title, directed & starring. You can change the musictoo. In this case, we use Original template music. Click on "Finish Editing" button to play this slideshow. Step 7 To publish your animted slideshow, click on "make HTML files" button.
Step 8 You can change the format & output option. Then click "Next" button. You can change the "Page Title", "File name", "Background" and the "Settings". You can compress your photo quality & music. Step 9 Congratulations! You have created your photo slideshow.
Here is the result: |
