Create Flash Banner With Oscillate Effect
Posted on December 27th, 2012
Adobe Flash
Today we will introduce you an Oscillate effect applied to the object in a flash banner. Applying such effect is as easy as applying other effects especially you will do this automatically using a wizard.
Download and Run IncrediFlash Xtreme 4.0 from here
Under Startup window choose Website Banner
Under Style tab menu, set Layout to Landscape and choose template at column 2 row 2.
Under Settings tab menu, you can replace the background either with your own image or with the one from Incrediflash Xtreme library.
Under Text and Logo tab menu, you can add some text to the template and change the default logo with your own.
Click Finish button to exit from Create a Flash Banner window
Congratulation! Your flash banner with Oscillate Effect is done.
Here is the result:
jsebastian
Multimedia Trainer
