![]() In this tutorial we will talk about basics of SQL Server, its history, versions and many more things that will be beneficial for a newbie. The aim of this tutorial is to give you an overview of SQL server in the simplest terms. What is SQL? SQL stands for Structured Query Language. It is a programming language designed to access and manipulates data in database (RDBMS). What is SQL Server? SQL Server is a RDBMS (Relational Database Management System) designed by Microsoft for enterprise environment. It is mostly used as back-end system and supports thousand of users simultaneously. SQL Server History The first version of SQL Server was released in 1989 by Microsoft. In 1990, Microsoft developed a new version of SQL Server for NT platform and in 1993 SQL Server 4.2 was released. After that Microsoft was recognized as second most popular vendor of relation database software. SQL Server Versions:
Why SQL Server is better than other databases?
Some Popular SQL Server commands Select statement: It is used to select data. Select column_name from table_name; Create database: It is used to create a database. Create database [database_name]; Create table: It is used to create a table. Create table [table_name] ( column_name1 data_type, column_name1 data_type, .... ) Insert into: It is used to insert new records. Insert into table name Values (value1, value2...); Update Statement: It is used to update existing records. Update table name set column1 = value1, column2 = value2 where some-column = some_value; Delete statement: It is used to delete records. Delete from table_name where some_column = some_value; Corruption in SQL server database Like all other database SQL database also got corrupted due to various reasons. The main reason behind SQL database corruption (90% cases) is problem at I/O level i.e. problem with drivers, controllers etc. To prevent this type of corruption you should know the use of CHKDSK command that helps in scanning bad sectors, incorrect entries and other storage issues. Other reasons of corruption might be hardware malfunction, power failure, firmware bug etc. If you can't handle this type of corruption yourself then call your hardware vendor immediately. Hardware vendor should check firmware’s, drives versions to make sure that latest and recommended version is being running. What are the consequences of SQL database corruption? To check database for corruption first you need to run DBCC CHECKDB command and if it finds corruption in your database then go for its repair options. In case of damage, the response of SQL Server will depends on the level of corruption in database. If the level of damage is high then it might be possible that SQL Sever won't be able to load your database. In that case you may need to restore the whole database. If the level of corruption is not that high and only one or two pages are affected then SQL Server might be able to load your database. These types of corruption can be handled easily with the help of DBCC CHECKDB repair options. DBCC CHECKDB Repair Options
How to prevent corruption? The simple answer of this question is that you can't actually prevent database corruption. As I told you above, most of the time corruption occurs at disk subsystem level so you really can't prevent it. But that does not mean you can't do anything about corruption. SQL Server provides a number of great tools that you can use to detect and repair corruption. One more thing, the best way to deal with corruption in SQL database is to detect it early. Sometime it happens that corruption issue goes unnoticed for a long time and later it becomes very difficult to deal with. What to do when corruption happens?
