Posted on June 3rd, 2013
Do you want to make an outstanding website slideshow in fast way? I have a good idea for you to create a photo slideshow for your website and you don’t need any code requirements. Kvisoft Web Slideshow Makercan create slideshows for websites from your digital photos such as iPhone cases and music or videos. With this slideshow creator, you can drive more new visitors and bring back old visitors to your website. So your visits of website will improve soon and the sales of products will increase in a short time. Then how to create a slideshow for your website: Step 1, add your files. After installing, you need add your files (product photos, relating music, videos) to web slideshow software. Just click Add File(s) button, and choose your selected files. Find the Music tab and insert your song to slideshow software. Step 2, choose the web slideshow template. Double click to select your template. If you want to design your own slideshow, you can personalize your theme. Step 3, set the transition effects. There are 100+ transitions for you to choose. You can set different transition effects for every picture. It allows you to change the duration between images. Of course, you can edit your photos by adding text and description, etc. Finally, publish as HTML. After previewing, publish it. You’ll find the following window. Then you just click Copy Code tab to create slideshows for websites without any code skills. With easy-to-use web slideshow creator, you can make awesome flash slideshow for website with easy 4 steps to promote your sales. |
