Convert Flash to Microsoft Zune movies with SWF to Zune Converter
Comments: 0
Posted: 10-18-2007
based on 0 votes.
Faves: 0 | + Faves
Page(s): 1
Want to upload the pop songs with flashes to your Zune? Want to listen music whiling watching the fantastic flashes? Want to watch your favorite flashes again and again? Want to watch it anytime, anywhere? If Yeah, come with me. Here I recommend you a magic converter tool, which enables us to convert the swf file formats to video formats, whatever video formats you can get for your Zune. Here I will show you how to do this with  Moyea SWF to Zune Converter.
1. Input the Flash Files
On opening the software, you will get the following window, which is for the batch mode conversion. If you have many a file to convert, please go on with it. If only one, you can click the “Single Mode” tab on the top left to shift to the single mode conversion.
Click “Add” to add the files from your computer folder. Click “v” immediately after “Add”, there will be a drop list cascade automatically. Choose from the “From Folder”, “From IE cache”, “From Projector” to input your flash files.
Click the file name to play it. On the right top of the playing pane are the properties of the current flash file. Click the “Export” tab in the menu to the export settings.
2. Export
① Click the box under “Profile”, and a drop list will cascade, choose your output file format from it.
② Click the “folder” in the “Export to” box to set the output destination, and click “Locate”, the destination folder will pop up immediately.
③ Select the check box before the “Rip Audio”, and the audio will be extracted and generated as a single file. Click the folder on the right to browse for the audio destination folder, and click “Locate”, the destination folder will pop up itself.
④ Click “Converter” tab in the menu to convert.
Tips: On choosing each item in the box under the “Profile”, and the values in the table on the right will change in accord. Change the video and audio parameters by clicking each item and selecting the value. Click “Save As” immediately after the box to save the profile you set as a new one. Click “V”, you can save, rename, or delete the newly set.
3. Convert
On clicking the convert button, you will get some twinkle interfaces. One is the testing of the capture speed, the second is the capturing of the screen for the program, and the last is the encoding window. That is the whole process of conversion. The conversion process is fast, however, it depends on the file size, the smaller the faster. As the batch mode is automatic, you can ever choose to wait, or to leave for a rest.
Well, this converter software can also convert files in the single mode, and it is much easier.
On starting the software, click the “Single Mode” button on the top left.
1. Input Flash Files
Click “Browse” to input your flash files on your computer, and click “V” immediately behind to choose from “From Folder”, “From IE Cache”, and “Flash Projector”, and there will be a dialog box pop up accompanying with each preference. In it, click the file name, and it will play automatically, then click “OK”. On the left of the playing pane are the properties of the flash file. Click “Export” to set the export settings.
Tips: Click the “Original” in the box to set the background color. You can set the basic color or the DIY color as the background color.
2. Export Settings
All are the same to the “Batch Mode”, except that you can choose to convert in a “Manual Mode” or “Automatic Mode”.
Tips: Manual Mode can help to get a better result for the interactive or AScript controlled files with few frames.
3. Convert
If you have chosen “Automatic Mode” conversion, then the process is the same with “Batch Mode”. If you have chosen the “Manual Mode” conversion, the following window will pop up, you can do according to the instruction on the top. Then the program will play the file for you to set start and end points of the capture.
Then the encoding process begins, and the conversion will complete, you can enjoy
Page(s): 1
More tutorials from this author:
» No tutorials by this user.
View All Tutorials
blala - n/a
Close
