Using PHP for HTTP Authentication Single User
Posted on May 8th, 2008
PHP Coding
Ok, in this tutorial, I will show you how to create a very basic script to add to the top of any page you want to restrict access to. This is my first tutorial too, so please C&C.
I will you the code in two sections, then go through and try (as best I can) to explain each part of the code. Ok? here we go:
$login=xxx;
// The username you wish to login with.
$pass=xxx;
// The password you wish to use.
   $host_allow=array("*");
// Set this to "*" to enable connections from any host.
// If you are operating a home server, set this to
// "localhost."
   $tmp=array();
   foreach ($host_allow as $k=>$v)
      $tmp[]=str_replace("*",".*",preg_quote($v));
   $s="!^(".implode("|",$tmp).")$!i";
   if (!preg_match($s,getenv("REMOTE_ADDR")) && !preg_match($s,gethostbyaddr(getenv("REMOTE_ADDR"))))
      exit("<a href=YOUR URL>YOUR PAGE TITLE</a>: Access Denied.n");
   if ($login!==false && (!isset($HTTP_SERVER_VARS['PHP_AUTH_USER']) ||
      $HTTP_SERVER_VARS['PHP_AUTH_USER']!=$login || $HTTP_SERVER_VARS['PHP_AUTH_PW']!=$pass)) {
      header("WWW-Authenticate: Basic realm="YOUR TITLE"");
      header("HTTP/1.0 401 Unauthorized");
Now, both of these codes should be together at the top of any page you want to restrict, alternatively, you can put the first part in a seperate file, and put require_once('file name'); at the top of the second part.
I think the first part is fairly self explanatory, so onto the second part of the code.
   $tmp=array();
This checks to see where the client is connecting from.
Tells the server that if someone connects from an unspecified host, to give the error message "YOUR PAGE TITLE: Access Denies" (with a link to your site).
This says that if the username entered is NOT the same as the one specified OR if the password entered is not the same as the one specified, then to give error message:
Same as before, only with a 401 Unauthorised message attached...
Hope you enjoy this tutorial, and I hope it benefits you in some way :D
CB Productions
