XCF
XCF is a framework you use to write your POJOs (plain old java objects). It provides a mechanism to adapt your application to a variety of technology stacks, thus the POJO system you write can be easily deployed into a variety of environments (web app, client app, mobile app, etc.). The first question to ask is does the world need another java framework? The answer, of course, is no. So why build it? First and foremost, a framework is a complex application. Building one is an excellent opportunity to learn about common design patterns and on how to apply those design patterns. Furthermore, by building this framework not only will you understand better how to translate design ideas into implementation, you will also gain insight into how decisions translate to code that is either hard or easy to maintain down the road. But the most important reason is that when it comes down to it, we are a bunch of propeller heads and what can be more fun that building a framework?
XCF is available on sourceforge here.
XCF was developed by Dataskill, Inc. and Eternal Adventures, Inc. I would like to personally thank Nigel Hook for his support and faith. Without that this project would not have been possible, nor available to the open source community.
XCF was initially developed from 2000-2003 by:
Framework 101: Building XCF
If you are new to this series of articles, I recommend you start with the walk through in lesson 05. The first five lesson’s are heavily related to each other. The walk through will give you a good idea of what you are leading up to in all those articles. I recommend you skim the walk through, then move onto Lesson 01.
Framework 102: Using XCF
Framework 201: Adapting XCF
7 Comments Add your own
Leave a Comment
You must be logged in to post a comment.
Trackback this post  |  Subscribe to the comments via RSS Feed
