CSSgallery.info
04 2008
A beginner’s mootools - select and create elements
In previous tutorial we learned how to add events to elements in webpage. In this one we will learn how to select elements - or better said how to access an element from page, and how to create new elements in page.
In mootools we have two functions that select an element:
function $ - this is equivalent of document.getElementById and returns the object selected.
if we have an element with id = ‘my_element’, the expression $(’my_element’) will return that element, then we will be able to manipulate it.
and function $$ - this one allows you to select multiple objects, and return an array with selected objects.
$$(’a') will return all the ‘a’ elements in document.
A nice trick done by $$ is that you are able to select all the elements with same class:
$$(’.my_class’) will select all the elements in page that have class=’my_class’.
The creation of an element is done by declaration:
var my_element = new Element( type , { options }) ;
Let’s explain a little:
type - define the type of the element, for example img, li, input, div, etc..
options - this lets you specify at the moment of creation the attributes the new element has.
options is not mandatory, the equivalent html code being - let’s say for div - “<div></div>”
An example:
var my_img = new Element ( ‘img’ , { ’src’ : ‘aa.jpg’ , ’style’ : ‘width:200px; border:3px solid red’ }) ;
As u see, we create an img element and we set the src as aa.jpg and the style as above. Please note the way options are declared:
{attribute: value , attribute:value}
so pairs of attribute:value coma separated.
Ok, now we have the element my_img, but is not yet viewable. The new created element exist in browsers memory, but is not inserted yet in page. For this we need to use one of:
injectBefore( element) ;
injectAfter(element);
injectInside(element);
injectTop(element) ;
Remember the selectors we explained at the beginning of this tutorial? The element object is exactly an object select using $, or created previously,using new Element();
What each inject does?
injectBefore( element) ; - injects the new created element just before the passed element;
injectAfter(element); - injects the new created element just after the passed element;
injectInside(element); - injects the new created element inside the passed element, at the bottom. Be carefull you have to pass an element that support subelements - you cannot insert an ul in an img for example
injectTop(element) ; - injects the new created element inside the passed element but at the top.
Take a look at the example page , and in source to see practical implementation.
Leave a Reply
« Submit yours web development on OS X »
