Apr
15
Making an MP3 player in AS3
Music Credits:
Title: The Best Day Ever
Artist: SpongBob
Album: The SpongeBob SquarePants Movie: Music From the Movie and More
Creating an MP3 Player in ActionScript 3.0 is fairly straight forward. The complexity varies greatly depending on what kind of features you want your player to have. I don’t plan on getting into ID3 tags here, but otherwise (as you can see) I will be going over the full functionality of a normal MP3 Player.
The first step is setting up the display and graphics. I went into the FLVPlayback skin SkinOverAll.fla file and fetched all the button graphics I needed (I’m not a very good artist). It was only a little trouble to recreate the buttons in a way that satisfied me (The only important thing to note about my buttons is that I gave them frame labels on the keyframes to make it easier to remember while writing the code).
Setting up the framework:
Now for the code! You can approach code like this from a number of different directions. I chose to start with making my button instances look like buttons, even though they don’t do anything yet. It’s really just a matter of setting up a LOT of event listeners (4 for each button):
stop_mc.addEventListener(MouseEvent.MOUSE_OVER, StopOver);
stop_mc.addEventListener(MouseEvent.MOUSE_OUT, StopOut);
stop_mc.addEventListener(MouseEvent.MOUSE_DOWN, StopDown);
stop_mc.addEventListener(MouseEvent.MOUSE_UP, StopUp);
private function StopOver(event:MouseEvent):void {
var obj:Object = event.currentTarget;
obj.gotoAndStop(’stop_over’);
private function StopOut(event:MouseEvent):void {
obj.gotoAndStop(’stop’);
private function StopDown(event:MouseEvent):void {
obj.gotoAndStop(’stop_down’);
private function StopUp(event:MouseEvent):void {
playPause_mc.playing = false;
playPause_mc.gotoAndStop(‘play’);
At this point most of the buttons are the same. The only difference might lay in the MOUSE_UP event or how the play button has to switch between play and pause, so I have the boolean property playing in my PlayPauseBtn class.
Bringing in a PlayList:
Now that we have basic working buttons that don’t do anything, it feels like the framework is in place to start making our MP3 player play music. To do this we will need a few elements:
public var xmlLoad:URLLoader;
public var musicXML:XML;
public var song:Sound;
public var channel:SoundChannel;
public var sndTrans:SoundTransform;
public var position:Number;
Our song:Sound will load the song and play it. The play() method in the Sound class returns a sound channel which we need to store in our channel:SoundChannel in order to pause/play/stop, or change the volume of our music.
The SoundTransform class is what is used to change the volume through the channel. It can also change the pan (balance of left and right speakers), but I’m not going to get into that.
What we are going to do is load an external XML file with our playlist in it… something like this:
<song id="/url/TheBestDayEver.mp3" disp="The Best Day Ever"/>
<song id="/url/come_away.mp3" disp="Come Away"/>
<song id="/url/nightmares.mp3" disp="Nightmares and Dreams"/>
<song id="/url/override.mp3" disp="Override"/>
<song id="/url/rescue.mp3" disp="Rescue"/>
<song id="/url/stick_em_up.mp3" disp="Stick’em Up"/>
<song id="/url/trogdor.mp3" disp="TROGDOOOR"/>
<song id="/url/you_are.mp3" disp="You Are"/>
</music>
Then we want to add each song on that playlist to a list component on the stage (I’ve called it playList). After we have the URLs of our songs, then we can start to load and play them.
In our xmlComplete(event:Event) event handler (handling the COMPLETE event from loading our XML file with a URLLoader) we need to parse the playlist into our List:
var item:Object;
musicXML = new XML(event.currentTarget.data);
for each(var prop:XML in musicXML.song){
item = new Object();
item.label = prop.@disp;
item.data = prop.@id;
playList.addItem(item);
song = new Sound();
song.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
song.load(new URLRequest(playList.getItemAt(0).data));
this.addEventListener(Event.ENTER_FRAME, updateSeek);
playList.selectedIndex = 0;
The for each..in loop is one that not everyone knows about. It’s very useful for getting all the elements of an XML object when you aren’t sure how many elements there will be. Basically it’s assigning each song tag from the XMLList musicXML.song to prop and then runs the code within the curly brackets {}.
I don’t like it when music or sounds start playing on the internet without my consent. So, whenever I make something like and MP3 Player, I set it up to NOT automatically play.
Still, I want it to be ready to play as soon as the user tells it to. So, I needed to add those lines after my for each..in loop. What is happening might be obvious enough. I’m creating a new Sound object and storing it in song. I always check for load errors so that the end user doesn’t get annoying pop-ups telling them that I’m a bad programmer. Then I’m loading the first song on the playList and making that song highlighted in my List component.
The event listener with a handle of updateSeek is needed for my seekbar. I will get to that later.
Playing the music and traversing out PlayList:
Great! So, now we have everything set up to look like a complete player. We even have our first song loaded. But, there is no way to get it to play yet. Our PLAY button doesn’t work yet.
This is where we have to start giving those buttons some functionality. Most (if not all) of the functionality for each button is going to be in the MOUSE_UP event handlers:
if(obj.playing) {
obj.gotoAndStop(‘play_over’);
position = channel.position;
channel.stop();
obj.playing = false;
} else {
obj.gotoAndStop(‘pause_over’);
channel = song.play(position);
channel.soundTransform = (mute_mc.isMute)? new SoundTransform(0) : sndTrans;
channel.addEventListener(Event.SOUND_COMPLETE, soundComplete);
obj.playing = true;
channel.stop();
position = 0;
playList.addEventListener(ListEvent.ITEM_CLICK, SnglClick);
private function SnglClick(event:ListEvent):void {
var item:Object = event.item;
try
{song.close();}
catch(error)
{trace(error);}
try
{channel.stop();}
catch(error)
{trace(error);}
song = new Sound();
song.load(new URLRequest(item.data));
channel = song.play();
position = 0;
playPause_mc.playing = true;
playPause_mc.gotoAndStop(‘pause’);
private function soundComplete(event:Event):void {
if(playList.length > playList.selectedIndex + 1){
playList.selectedIndex++;
playList.scrollToSelected();
} else {
playList.dispatchEvent(new ListEvent(ListEvent.ITEM_CLICK, false, true, 0, playList.selectedIndex, playList.selectedIndex, playList.selectedItem));
private function ForwardUp(event:MouseEvent):void {
obj.gotoAndStop(‘forward_over’);
} else {
My Play/Pause button, if playing, will save the current position and then stop the music through the channel. Otherwise, it will play from position and set the volume and add a listener for the end of the song.
The Stop button obviously just stops the song and sets the position back to zero (0). I guess it also resets the Play button.
The ListEvent.ITEM_CLICK is when we click on a list item (a new song in the playlist). The handler closes any open stream that might be there (thus the try..catch) and if not then to simply stop the channel. It then loads the song URL stored in that items data provider and starts it playing.
The forward and back buttons are almost exactly the same. They just change the selection in the List component and then dispatch a fake ITEM_CLICK event.
The soundComplete() method, as you can see, is also very similar to the forward button. This event handler is called when a song played right to the end.
Working with volume:
Since I’ve already mentioned setting the volume, I might as well get into that next. The volume is a property of the SoundTransform class. We already made a SoundTransform variable, we just haven’t stored an ST object in it yet.
My main volume control is sndTrans:SoundTransform; After setting the volume property within it I can assign it to the channel.soundTransform and it will take effect. My volume bar has it’s own class to handle the effect of dragging the handle around:
import flash.display.MovieClip;
import flash.events.*;
import flash.geom.Rectangle;
public class VolControl extends MovieClip {
private var bounds:Rectangle;
public var percent:Number;
public function VolControl() {
percent = 1;
bounds = new Rectangle(0, 10, 50, 0);
volBar_mc.hit_mc.addEventListener(MouseEvent.MOUSE_DOWN, dragHandle);
volHandle_mc.addEventListener(MouseEvent.MOUSE_DOWN, dragHandle);
volHandle_mc.addEventListener(MouseEvent.MOUSE_UP, endDrag);
volHandle_mc.addEventListener(MouseEvent.MOUSE_OUT, endDrag);
private function dragHandle(event:MouseEvent):void {
volHandle_mc.startDrag(true, bounds);
this.addEventListener(Event.ENTER_FRAME, changeVol);
private function endDrag(event:MouseEvent):void {
volHandle_mc.stopDrag();
volBar_mc.fullness_mc.fill_mc.x = volHandle_mc.x - volBar_mc.fullness_mc.fill_mc.width;
percent = volHandle_mc.x/50;
dispatchEvent(new Event("volume_change"));
this.removeEventListener(Event.ENTER_FRAME, changeVol);
private function changeVol(event:Event):void {
This is simply letting you drag around the little pointer within its bounds and dispatching an event to let the main class know that the volume has been changed. I needed to repeat some of the code from changeVol() in endDrag() because if you just click quickly then the ENTER_FRAME event never gets handled before it’s removed.
Back in the main class we are handling that “volume_change” event:
private function updateVolume(event:Event):void {
sndTrans.volume = vol_mc.percent;
Another thing that a lot of new programmers don’t know about is the conditional ? : operator. It’s shorthand for an if..else statement. Basically these two bits of code are the same:
num = 5;
}else {
num = 0;
//OR THIS NEXT PART DOES THE SAME THING
num = (num>5)? 5 : 0;
Isn’t that great?
Getting back to our MP3 player. We should add our Mute button while we are working with volume. You’ve already seen that I take the mute condition into account when I set that volume. Here is where I set the mute condition:
if(obj.isMute) {
obj.gotoAndStop(‘mute_over’);
obj.isMute = false;
channel.soundTransform = sndTrans;
} else {
obj.gotoAndStop(‘unmute_over’);
obj.isMute = true;
channel.soundTransform = new SoundTransform(0);
I never want to set sndTrans.volume to zero (0) just because I pressed the mute button. I would rather leave that as it is so that I can unmute back to the original volume again.
*phew* About this time I’m thinking to myself, “It sure takes a lot of code to get a simple MP3 Player to work correctly.” But, there is light on the horizon so we must press on.
Making the seek bar to search a song:
Now for the most complicated part of our player. The seek bar. The seek bar isn’t THAT bad, but it’s definitely worse then what we have done so far.
First of all we will give the seek bar the same drag or click functionality that we gave to volume control bar:
public var seeking:Boolean;
public function SeekControl() {
seeking = false;
percent = 0;
bounds = new Rectangle(0, 12, 100, 0); //I made the seek bar 100 wide for convenience
seekHit_mc.addEventListener(MouseEvent.MOUSE_DOWN, dragHandle);
seekHandle_mc.addEventListener(MouseEvent.MOUSE_DOWN, dragHandle);
seekHandle_mc.addEventListener(MouseEvent.MOUSE_UP, endDrag);
seeking = true;
seekHandle_mc.startDrag(true, bounds);
seeking = false;
seekHandle_mc.stopDrag();
fillBar_mc.x = seekHandle_mc.x - fillBar_mc.width;
percent = seekHandle_mc.x/100;
dispatchEvent(new Event("seek_change"));
public function moveSeekPos(perc:Number):void {
fillBar_mc.x = (fillBar_mc.width * perc) - fillBar_mc.width;
if(!seeking)
seekHandle_mc.x = 100 * perc;
The biggest difference here is that I don’t want a live update while dragging the pointer around. Otherwise, a few values have changed, some var names have changed, but it should look familiar (well it would if you had written this code yourself).
The moveSeekPos() method is going to be updated constantly from our main class. This is here so that we can see the play progress when listening to a song.
Getting back to the main class again, we have to write a thing or two about our seek bar there:
is added when we start to load a new song.*/
seek_mc.addEventListener("seek_change", changeSeekBar);
private function changeSeekBar(event:Event):void {
position = song.length * seek_mc.percent;
if(playPause_mc.playing){
channel.stop();
private function updateSeek(event:Event):void {
if(playPause_mc.playing) {
var perc:Number = channel.position / song.length;
seek_mc.moveSeekPos(perc);
display_mc.timeDisp.text = formatTime(channel.position) + "/" + formatTime(song.length);
public function formatTime(time:Number):String {
var min:String = Math.floor(time/60000).toString();
var sec:String = (Math.floor((time/1000)%60) < 10)? "0" + Math.floor((time/1000)%60).toString() : Math.floor((time/1000)%60).toString();
return(min+":"+sec);
I went ahead and added the code here to display the current play time and the total play time in a dynamic text field on the stage. That seemed to be closely related to the seek bar, so I figured showing it here is suitable.
A final note:
Now would be a good time to mention that I didn’t bother fixing a “minor” bug. While a song is still streaming (loading), Flash doesn’t know how long it is. Thus, song.length will be growing over time till it’s done loading. This is only an issue for our seek bar, because it uses the ratio between the current position and the total length to decide how to display itself.
To work around this issue (which is really only an issue for slower internet connections), you will need to pass Flash the songs length along with the file path in the XML doc. It seemed like a lot of trouble to me and since this isn’t for a client, I figured I would just tell you about it instead of do it for you.
Wow. This was so long that I wouldn’t be surprised to find later that I forgot something. If I find anything I will make sure to update this post and make a note of what I changed.
Anyways, that is it! I think…
Let me know what you think about it and also let me know if you even use my Player on your site somewhere. I would love to see my work being used.
You can get the source files for this tutorial and the example at the beginning to the page here: MP3 Player Source Code.rar
UPDATE: I have updated the source file to include changes which will fix a few bugs pointed out to me over time. I also added a few new lines to the disclaimer at the beginning of my code which explains that WE DO NOT PROVIDE TECHNICAL SUPPORT FOR OUR EXAMPLE CODE. It is there for reference only. We would hope that you would use our code in conjunction with the tutorial to learn how to do it yourself.
We understand that most people will just download and use the code without much effort towards learn new skills, but we aren’t going to answer your questions in that case. If you notice something wrong with the code and want to bring it to our attention that would be appreciated, but any questions on how to use the code will be answered with “Read the tutorial.”
Tags: Intermediate, MP3 Player, Sound, XML
April 16th, 2008 at 13:57
Dont like the graphics in the player, but the source code is great, thanks!
April 18th, 2008 at 13:34
Woo hoo!!! :-)
April 18th, 2008 at 17:00
Hi,
If you had to fix that minor bug about sound length, how would you go about fixing it? I’m loading especially long mp3s (40+ minutes) and I need a good way to get the length of the mp3 dynamically.
-Shant
April 18th, 2008 at 18:04
Well, I’ve thought of a few ways. Probably the best way to do it would be to have a “length” attribute in your song tag. This would have to be the approximate length of the sound file (round to the nearest second) in seconds or milliseconds… whatever will allow you to know the length before it’s even started loading.
Add the length to the item given to the DataProvider for the list…
item.data2 = prop.@length;
If that works then you should be able to use that length for all calculations and even show the load progress right in the seek bar like on youTube videos.
ClickPopMediaApril 23rd, 2008 at 8:03
How come I can’t figure out how to change the color? That neon blue makes my eyes cry. Any help would be appreciated.
April 23rd, 2008 at 9:32
I copied the interface controls from the FVLPlayback component skin SkinOverAll.fla
The buttons, seekbar, and volume control are all just an alpha gray. There is only a few things that have color. The background is a square of light blue (change that and you are 90% done) and the button’s over and down states have the purplish outline.
All of that should be changeable without any code. You can change the style colors of the list using listInstance.setStyle(”styleName“, value);
ClickPopMediaApril 25th, 2008 at 12:29
How would you go about changing the displayed text color?
The song name.
April 25th, 2008 at 15:19
var myFormat:TextFormat = new TextFormat();
myFormat.font = “Georgia”;
myFormat.color = 0×00FF00;
var b:List = new List();
b.dataProvider = [{label:"Hello World"}];
b.setStyle(”textFormat”, myFormat);
addChild(b);
Something like this will add a new List to the stage with one item labeled “Hello World”. What you (wilson) wanted to know (I think) is that .setStyle(); function where I am changing the font and font color.
ClickPopMediaApril 26th, 2008 at 11:36
Thanks for your help. That is an awesome player thanks for sharing it.
April 27th, 2008 at 20:09
Thanks for the source code, info and really great help. This makes as3 ALMOST understandable, even for an old BASIC stick in the mud like me.
Thank you
April 28th, 2008 at 11:20
Hello again, I’ve been testing the player on several browsers, and with internet explorer i get TypeError: Error #1009: Cannot access a property or method of a null object reference.
at Mp3Main/::updateSeek()
any idea how to fix this?
April 28th, 2008 at 12:00
Actually one of my friends informed me of this issue…
I’ve just gone about fixing it in the tutorial and source zip.
What was happening was Flash Player was trying to access channel.position while channel was still null. channel is only defined when a song is playing.
So, to fix this I just moved the one line of code still remaining outside the if loop within updateSeek() inside the if loop in updateSeek(). It’s a very quick solution and it does the job just fine.
The reason I had that line outside of the if loop was because I was hoping to show the position that you where dragging to live as you drag. It didn’t work anyways… I do have a way to do that in mind, but I’m not going to bother right now.
ClickPopMediaMay 4th, 2008 at 5:53
Hi! I’m trying to use your mp3player and i’m having problems… :P Can you write an example with http://www.example.com/modules/mp3/ ? Thankyou!
May 4th, 2008 at 6:01
Donty worry it’s working fine! GOOD JOB!
May 5th, 2008 at 15:07
When I roll over the components how can I change it to a hand pointer? Is this possible?
May 5th, 2008 at 21:04
nk,
I would think that it might be possible to use the hand cursor, but I’m not sure how. I’ve just tried a few things, but none of them are working.
The problem I’m running into is that I don’t have easy access to the children of the List component.
Setting buttonMode to true for the component itself doesn’t work. You have to do it for each of the items, which I’m not sure how to do right now.
Maybe if you edit the component itself you could probably get it to work that way.
ClickPopMediaMay 6th, 2008 at 19:29
Hello, and thanks *very* much for your hard work in creating this valuable tutorial. I have 2 questions I hope someone can help with:
1. Where specifically in the FLA does it link to the AS file? I’m an idiot, can’t find it.
2. How could I add a dropdown menu populated with the XML instead of the list?
Thanks again!
-sPlat
May 8th, 2008 at 8:52
Can you confirm that you solved memory problem with flash streaming? In similar application I have streamed music for 24h and after that, computer become useless. Problem is that Flash player will store all downloaded material until you close opened application.
Is it solved or I’m not up to date :) ?
mladen
May 10th, 2008 at 16:34
i keep getting this error message:
Error: Error #2029: This URLStream object does not have a stream opened.
what does that mean and how do i fix it?
May 11th, 2008 at 9:25
Much better way: find the percentage that’s loaded, then divide the current song length by it - if 50% has loaded, and it’s giving a length of 100000 milliseconds, then 100000/0.5 = 200000 (the proper length).
It works, trust me.
May 11th, 2008 at 12:36
For the first time ever, I tried to view this tutorial with a slow (dial-up speed) connection. That minor loading issue seemed MUCH bigger then.
I like your suggestion Harry. I guess sometimes I just don’t realize the obvious. There is probably a few things I could do to make this MP3 Player work better on a slower connection machine.
ClickPopMediaMay 12th, 2008 at 18:33
Any chance you can show us how to add album art in the playlist?
May 12th, 2008 at 20:07
Wow! Album art? Now that’s a whole different ball of wax. I suppose you could have a simple gallery that switches to the appropriate image in the SnglClick(event:ListEvent) function.
I which case you would need to have the album art image’s URL in the XML somewhere. I will write a tutorial on making a gallery later today…
ClickPopMediaMay 12th, 2008 at 20:41
You are so totally awesome and a scripting genius at that! Thank you for this tutorial : )
May 14th, 2008 at 6:10
Bump.
Hi, can anyone please offer suggestions as to the following?
Thanks again!
-sPlat
May 14th, 2008 at 7:36
I did it the easy way (downloaded the zip-file).
This is what I get when I test the fla:
Error #2044: Unhandled ioError:. text=Error #2032: Stream Error. URL: file:///url/music.xml
at Mp3Main$iinit()
…and this when I press the play button:
at Mp3Main/::PlayUp()
Why and how do I fix the problem?
May 14th, 2008 at 9:16
s’PlatterKep, if you click on the stage and then check out the propertes, you will see “Document Class” next to an input box. That is where you set the Documents AS file.
As for your other question, s’PlatterKep, the easiest way to use a dropdown menu instead of a list would be to use the combobox component. You would have to make a few changes to the code to make that work, but not a lot.
Ottis, I didn’t provide any music with the ZIP and so I also didn’t use real URLs in my URLRequests. You are going to have to put those in yourself if you want to test this MP3 Player out.
ClickPopMediaMay 14th, 2008 at 10:02
I forgot I had do change the xml-file too. It´s done now and the music is playing. However I get this message. Is something wrong or can I ignore the error..?
May 14th, 2008 at 10:27
One last question…
What do I need to do with the script if I want to take away the list component at the very top and instead just show the current playing song in the display window? (No time needed - the progress bar is enough.)
May 14th, 2008 at 11:15
With all the question that have been asked that require a detailed responds, we at ClickPopMedia are going to be putting up a forum soon where I (and others) can answer these questions more appropriately.
ClickPopMediaMay 14th, 2008 at 17:11
Paul, Thanks so much for your response. In terms of changing the code re the combobox, could I please ask you to point me in the right direction? I’m trying to set it up, but keep breaking it.
Thanks again, this is a great FLA.
Cheers,
s’Plat
May 14th, 2008 at 17:25
not sure if something mentioned this before but for the conditional statement
num = (num>5)? num = 5 : num = 0;
you dont need the extra num =
it can just be
cheers
May 14th, 2008 at 18:42
Thanks kyle, I didn’t notice that I did that. I know better then that… OK, I fixed it.
ClickPopMediaMay 30th, 2008 at 11:59
to get the hand cursor:
myButtonName.buttonMode = true;
June 1st, 2008 at 8:49
I love your player, but I am struggling to meld other ideas with it.
I would like to load the lyrics with the song. I believe that I have to use CDATA in the XML, does the current xml syntax in the playlist allow this?
Thanks again
John
June 1st, 2008 at 14:24
John, you don’t have to use CDATA, but you can if you want to and it really is needed if you want to have HTML in the lyrics (bold, italics, etc.)
I would suggest changing the tags so that there is an open and closing tags instead of just the self closing ones. Then you can have the lyrics within the tags and not as attributes.
ClickPopMediaYou will have to add code to the MP3 Player this way, but you should have to change much.
June 2nd, 2008 at 11:25
I am having a memory leak issue here! Great code for a noob to get stuck into and I am slowly adding my bits (equalizer and load bar) but I seem to have a memory leak! I am monotoring it - but dont have a clue where to start - anyone else having this issue?
June 3rd, 2008 at 12:48
its not removing the addeventlistener right? - can these be removed or not? I.e if they are removed then nothing would be listened for so nothing would work…..or maybe remove certain things once they have been activated……hmmmmm
My machine reset due to leaving this on for ages! now thats not a good memory leak
June 3rd, 2008 at 17:30
How many time can one listen to “The Best Day Ever!” by Sponge Bob? Well I know VQ has listened to it at least 100 times according to his iTunes play count…
Anyways, I put this MP3 Player together in about 90 minutes and didn’t thoroughly error check it (obviously I never even bothered to get the loader bar working correctly).
If event listeners are giving memory leaking problems (and they are usually the cause) then you should use a weak reference like this:
myMovieClip.addEventListener(Event.COMPLETE, completeHandler, false, 0, true);
The last parameter is the useWeakReference that you have to set to true.
Someday in the not to far future I will come back to this MP3Player and maybe make it into a component. When that day comes I will do some real thorough debugging and error checking.
ClickPopMediaJune 15th, 2008 at 0:31
OK. Dumb question. How do I make it autoplay the first song in the list? Usually I don’t like thngs to autoplay but I am using it for a Bar.
http://www.intersoltours.com/tequisol/tequisol.html
June 16th, 2008 at 12:48
Dean,
It is very easy. Simply add a line at the end of the function xmlComplete(event:Event) that will make it seem like the play button has been clicked.
playPause_mc.dispatchEvent(new MouseEvent(MouseEvent.MOUSE_UP));
With that, the first song should auto play. There are other ways to do it, but this one takes the least amount of typing on my part.
ClickPopMediaJune 16th, 2008 at 15:23
It makes the button look clicked and displays the pause state until you
mouse over the button.
Doesn’t play a note.
private function xmlComplete(event:Event):void {
var item:Object;
June 16th, 2008 at 20:43
First of all Dean, you have to create your Sound object FIRST then load the song BEFORE you set up the autoclick.
Like this:
song = new Sound();
I did notice that it leaves the Pause button in the mouse over state and so to avoid this, let’s just preset all our variables to the play-state first and then call song.play()
Like this:
song = new Sound();
//the following replaces our event dispatch.
playPause_mc.gotoAndStop(’play’);
OR you can dispatch a MOUSE_OUT event directly following the MOUSE_UP event. It’s up to you.
ClickPopMediaJune 17th, 2008 at 18:12
Works grat Paul. You are the man. One thing though, the progress bar no longer functions. I figure I did something wrong. I have an off topice question… you sent a file to me via email with the MP3 plyer that added the class to the mp3 player instead of the Document. I have another similar file and I do not know how to combine the same process to turn it into something I know how to use. It is a cool fog effect and I can not separate it from the original FLA file.
I need help.
June 18th, 2008 at 19:13
Hi
I used your seekbar code to get my own player up and running. I’m currently running into a strange bug that I thought you might be able to shed some light on. I have loaded a mix that is 44 minutes long. I have checked the percent amounts and seekPosition numbers I am sending to it and I get a discrepancy in my sound playback.
Early in the mix, the discrepancy is about a 5 or 10 second difference but as the mix goes on it gets exponentially worse. When the time stamp is showing 44 minutes and the mix is supposed to be over, it is actually ending about 2 minutes early in the song.
Is this a bug that has to do with Flash or am I coding something wrong?
June 19th, 2008 at 1:06
Hi,
First i Thank for this mp3 player.
i am having the problem in loading mp3(40 bitrate). while i drag the seekbar in to end. it doesn’t play
i change 40 bitrate into 64 bitrate and more its work fine.
any body knows why it not play in 40 bitrate?
June 20th, 2008 at 11:46
Hi paul,
Thanks for the mp3player but I have trouble uploading the music because it just doesnt work and I uploaded the xml file but it had errors when loading..
how can I fix this?
July 1st, 2008 at 2:05
Hi Paul,
Do you know where within the code can I add the .setStyle to change the text color?
addChild(b);
thanks!
July 7th, 2008 at 11:22
NICe mp3 player thanks…
BUt is better is ‘Paul’ include the sound spectrum/visualizer… :)
I hope it will post up soon… lol
Thanks…
July 10th, 2008 at 10:12
Hi,
I’m attempting to use this MP3 player and it works perfectly when I place the “url” folder (containing all .swf, .as, .xml, and .mp3 files) at root level (/url/). However, suppose I wish to place the url directory within another directory that’s located at root level e.g. /directory_1/url/. To cater for this I have changed the paths within the following files:
music.xml
… etc
Mp3Main.as - Line 35
url = new URLRequest(”/directory_1/url/music.xml”);
But the player does not now work. Are the paths provided here correct or possiby there are additional paths needing changed? If so which files are they in?
July 30th, 2008 at 7:33
Exactly what do I have to change in the script if I want to take away the volume control and the window that displays the current play time and the total play time (but keep the mute button and keep the seek bar)? I know I can´t just take the two items from the scene.
July 30th, 2008 at 11:01
Johannes,
To get rid of the Volume, but to keep the mute button is almost a simple as a find and replace.
First, look for vol_mc. In most cases we are going to be deleting things with that. Maybe just comment it out.
Anyways, there should be an event listener to remove and an event handler function (updateVolume()) to remove.
For the line - sndTrans = new SoundTransform(vol_mc.percent); just replace vol_mc.percent with 100 to keep the mute button working.
To get rid of the time display you jest need to delete the only line containing this display_mc.timeDisp.text in updateSeek() and that will leave you with a useless function formatTime() which you can delete (but don’t have to).
ClickPopMediaNow that the code is gone, you shouldn’t get any errors when you delete the actual elements on the stage.
July 31st, 2008 at 7:00
Thanks!!!
Three more qustions…
I can´t find any script that specifies the background color in the playlist. I would like to change it from light blue, but where do I change the script?
Is it even possible to make the entire playlist transparent, if yes, how?
You have explaned how to change the text color, but where exactly do I write the script?
PS. I tried 100 instead of vol_mc.percent as you told me to, but that made the music distort big time. I had to change it all the way down to 1 before the music sounded ok. Any clue way?
July 31st, 2008 at 11:15
Oops! yeah sorry about that, I didn’t test what I was telling you and forgot that volume was a value between 0 and 1 (not 0 and 100).
Your not the first person to ask me about the background color of the playlist I think. Components in CS3 are FLA based, which means that they are editable right on the stage. You don’t need any code, just double click it and change the colors by hand.
Of course the text color would be a little different, because that’s something created with code inside the component. I haven’t tried changing the text color or font size/type yet, but I would probably put the code right in the constructor (the function with the same name as the class). Anywhere in there should be fine since that’s the first code executed when the movie is created.
ClickPopMediaJuly 31st, 2008 at 17:26
Stupid, or..?
Finally I found the place to change the color for the play list: (Scene->Instance of List->Instance of CellRenderer). However, even though I pick “no color” as fill color the play list wont be transparent. Why?
July 31st, 2008 at 20:13
Johannes,
Do you want it transparent like this?:
http://www.clickpopmedia.com/projects/paul/ListExample.html
To do that I also set the List_Skin’s fill to transparent. It’s white by default.
ClickPopMediaAugust 1st, 2008 at 16:35
That´s exactly what I was looking for!
Regarding your previous answer: “I would probably put the code right in the constructor (the function with the same name as the class)”.
Are we talking about Mp3Main.as and could you please explain what you mean by “in the constructor (the function with the same name as the class)”?
Sorry ´bout all the questions…
August 1st, 2008 at 17:00
/*The constructor mainly sets up the event listeners, but it also starts loading the XML playlist file.*/ public function Mp3Main() { index = 0; position = 0; sndTrans = new SoundTransform(vol_mc.percent); ... }The class’ name and constructor function are both Mp3Main. The constructor is called automatically on creation of a new Mp3Main instance (and since this is our doc class, that’s when the flash movie is loaded).
ClickPopMediaAugust 4th, 2008 at 5:16
I´m ashamed, but can´t get it done…:( This is what it looks like now:
position = 0;
sndTrans = new SoundTransform(1);
url = new URLRequest(”music.xml”);
xmlLoad = new URLLoader(url);
xmlLoad.addEventListener(Event.COMPLETE, xmlComplete);
addChild(b);
playList.addEventListener(ListEvent.ITEM_CLICK, SnglClick, false, 0, true);
/*vol_mc.addEventListener(”volume_change”, updateVolume, false, 0, true);*/
seek_mc.addEventListener(”seek_change”, changeSeekBar, false, 0, true);
I copied the middle part from earlier posts here, and I still don´t see the new list on the scene. But actually I don´t want to create a new List but rather just change the text format on the existing one. How do I apply the format to the play list?
August 15th, 2008 at 8:33
hey everyone
i am facing a bit of a problem with the xml part. Am i supposed to put the songs in from the web or from my computer. when i try to play it, for some reason it just wont play. help me please
example of xml format that i am using
song id=”K:\MP3 Player Source Code\songs001 - Marvin Gaye - Let’s Get It On .www.lokotorrents.com.mp3″ disp=”Let’s ge it on - Marvin Gaye”/>
everything else is in the same format
when i try to play it i get this
false eventPhase=2 text=”Error #2032: Stream Error.
thanks a lot
August 15th, 2008 at 14:01
Rubin,
First of all, try and avoid spaces in your file names. Secondably, that file path is all messed up.
switch the backslashes (\) with forslashes (/),
get rid of any spaces… and rename the file to something a little simpler, like “song001_Lets_Get_It_On.mp3″ (that’s not required, but it will be nicer).
Also, avoid apostrophes in file names.
If you are testing this on your computer (or online) you only need the relative path to the file. So, if the song and the player are in the same folder, you just need id=”/filename.mp3″
Hope that helps.
ClickPopMediaAugust 21st, 2008 at 20:21
hey sorry i’ve been busy
first of all id like to thank you for your help above. I finally got it to work. Now i just have one more question; why cant i play the swf file on its own,for some reason it does not recognize the song list. in order to play the songs i have to open the fla file and hit control+enter. if i were to put the swf file in a dreamweaver file would it work? thanks a lot i appreciate your effort.
August 21st, 2008 at 21:21
Hmmm… I was just testing it on my computer and it was working fine. Try it online and see if it works in a webpage. If it doesn’t then we’ve got some more issues going on, but I’m not sure what they are yet.
ClickPopMediaSeptember 6th, 2008 at 15:16
i tried it not really working my guess is that its not reading the mp3main.as file
October 9th, 2008 at 15:27
Everything’s working great … I was hoping for some insight on how to add an additional field to the player to display the song title (or possibly one more for artist). Would you be able to shed some light on how to alter the .AS files to do this? I’m hacking away on my own, but any ideas would be great.
