Photoshop Tutorials | Photoshop Contests | Photoshop Forums
Go Back   Photoshop Tutorials | Photoshop Contests | Photoshop Forums > Member Photoshop Tutorials
CLICK HERE to become a member and see no ads.
Reply
LinkBack Thread Tools Display Modes
Old 04-16-2008, 05:58 AM   #1
tx51210
Old Bag of Crap
tx51210's Avatar
Diggs: 21
Strength: 44254tx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond repute
tx51210's gallery
Awards Showcase
Weekly Contest 2nd Place Weekly Contest 2nd Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 1st Place 1st Place - Member of the Month Weekly Contest 1st Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place 3rd Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place
Total Awards: 26
Mellon Baller
I created this tutorial because I have seen baseballs and various objects combined and I wanted to see how I might go about re-creating these images.
I came up with this as the final image.
I started with a couple of stock art photos and inserted the baseball in a layer over the melon.
Reduce the baseball layer's opacity and align and resize the baseball to fit on top of the melon using the transform tool.
Restore the baseball layer opacity to 100% and change the layer blend mode to "multiply" to get the laces to appear part of the melon.
This gets you pretty far down the road and you could stop here to have a fair chop. I chose to add a layer mask to clean up some of the surface grunge from the baseball image that the red arrows are indicating. A quick layer mask can reduce the baseball to where only the laces show along with some white leather near the laces.
This helped clean the image but the laces looked a little dull to my eye. I added a Hue/Saturation adjustment layer above the laces to help restore the dullness created by the layer blending. If you did not create the adjustment layer as a clipping mask (like I normally do), it will also affect the baseball layer below. Right click the adjustment layer and select "Create Clipping Mask" to limit the affect of the adjustment layer to the layer below.
The adjustment layer helped, but when you look closely at the image, you can see where the red laces blend with the dark green stripes of the melon and give an undesirable transparent feel.
To correct the laces without loosing the effect needed to make the rest of the image work, I duplicated the baseball layer and mask and placed it above all the other layers, changing the blend mode of this layer to "Normal". I filled this layers mask with all black and then painted quickly in the layer mask to hit the tops of the laces with white to restore their solid un-tinted look.
That was all that was needed to complete the effect and make a fairly convincing chop.
__________________
"A government big enough to give you everything you want is strong enough to take everything you have." - Thomas Jefferson
tx51210 is offline
Sponsored Links
Old 04-16-2008, 05:59 AM   #2
thediceman
uber-mod
thediceman's Avatar
Diggs: 0
Strength: 100000thediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond repute
Send a message via Skype™ to thediceman
thediceman's gallery
Awards Showcase
Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 1st Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 3rd Place 2nd Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 1st Place Head 2 Head Contest Winner Weekly Contest 2nd Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 1st Place Weekly Contest 1st Place Weekly Contest 3rd Place
Total Awards: 34
this looks great ima give it a try almost looks like you used a displacement map
great job great tut.
__________________
thediceman is offline
Old 04-16-2008, 02:19 PM   #3
twiztedtony
PeckerWood
twiztedtony's Avatar
Diggs: 0
Strength: 29650twiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond repute
Send a message via AIM to twiztedtony Send a message via Yahoo to twiztedtony Send a message via Skype™ to twiztedtony
twiztedtony's gallery
Awards Showcase
Weekly Contest 2nd Place Head 2 Head Contest Winner Weekly Contest 1st Place Weekly Contest 1st Place 1st place Tutorial of the Month 3rd Place - Member of the Month Weekly Contest 3rd Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 3rd Place
Total Awards: 15
ok i did one but mine didnt turn out very well
__________________
Quote:
Originally Posted by Skelz View Post
Tony is officially an O.G.
Quote:
Originally Posted by The Bro View Post
Wanna chill and play some gamecube?
Video crew hotline
questions and concerns
Tt 734 444 6960
Video Crew Fo LIFE
twiztedtony is offline
Old 04-16-2008, 02:20 PM   #4
thediceman
uber-mod
thediceman's Avatar
Diggs: 0
Awards Showcase
Total Awards: 34
Quote:
god dammit my firefox is fuck ed and keeps loging on tony instead of me
i did this one.not tony
__________________
Old 04-16-2008, 02:29 PM   #5
tx51210
Old Bag of Crap
tx51210's Avatar
Diggs: 21
tx51210's gallery
Awards Showcase
Total Awards: 26
OK, now your scaring me.
With this place, I never know who is jacking around and who is really this strange.
That is one odd looking melon. Did it start out that color or do you have a blend mode or mask issue? Also looks like you left off the last step to work on the laces.
And who the hell should I rep?
__________________
tx51210 is offline
Old 04-16-2008, 02:33 PM   #6
thediceman
uber-mod
thediceman's Avatar
Diggs: 0
Awards Showcase
Total Awards: 34
i did it and yeah the last step i left out i might try it again later right now im doing some restorations
__________________
Old 04-16-2008, 03:59 PM   #7
joshbond
Admin
joshbond's Avatar
Diggs: 19
Strength: 100000joshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond repute
Send a message via MSN to joshbond
joshbond's gallery
Awards Showcase
Weekly Contest 3rd Place 3rd Place Tutorial of the Month Head 2 Head Contest Winner Weekly Contest 1st Place Post whoring award Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 1st Place
Total Awards: 10
Wow! awesome tutorial! thank you.
I'm gonna give this one a try too.
joshbond is offline
Old 04-16-2008, 11:11 PM   #8
PottieMouff
Senior Member
PottieMouff's Avatar
Diggs: 0
Strength: 313PottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond repute
Send a message via MSN to PottieMouff Send a message via Yahoo to PottieMouff
PottieMouff's gallery
Awards Showcase
Total Awards: 1
ok i'ma give this a try right now
edit:
i just threw one together.
PottieMouff is offline
Old 04-17-2008, 01:42 AM   #9
tx51210
Old Bag of Crap
tx51210's Avatar
Diggs: 21
tx51210's gallery
Awards Showcase
Total Awards: 26
Nice One
"Threw one together" I like the pun.
__________________
tx51210 is offline
Old 04-17-2008, 02:58 AM   #10
Dookie
Voice of Nonsense
Dookie's Avatar
Diggs: 0
Strength: 15050Dookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond repute
Dookie's gallery
Awards Showcase
Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place 2nd Place Tutorial of the Month Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 3rd Place
Total Awards: 10
Nice one tx51210.
Quote:
Looks like you probably went past Multiply & ended up with with Color or Linear Burn.
Quote:
You must spread some Reputation around before giving it to tx51210 again.
Dookie is offline
Old 04-24-2008, 12:35 AM   #11
Bath1c
I am BathLovin
Bath1c's Avatar
Diggs: 0
Strength: 16057
