Interior Design with Maya – Small Bed Room
March 14th, 2008
This tutorial will show you how to create interior design with Autodesk Maya and rendering use mental ray.
1. Create base with polygon plane with size 3.5m X 2.5m (in Maya scene
I use 35 x 25 cm).
2. Create wall with polygon plane and shape like picture below.
3. Select every edge on side of object and bevel it.
5. Select wall object and extrude it.
6. Create window with polygon cube and create curtain with polygon plane or use curve and loft it.
7. Create bed, computer and furniture’s.
8. After finish modeling all stuff you must create layer for every object. Like wall object you must create layer for wall. Benefit create layer for every object is you can save render time. You will learn in render part after in end this tutorial.
9. For Lighting I use direction light for sun light and active shadow. Area light for mental ray emit photon. Don’t forget to check global illumination and final gather in render setting.
10. Select area light and see attribute editor > mental ray. You will see caustic and global illumination attribute. Check emit photons, adjust photon intensity (more big your scene you need more big photon intensity).
11. After you add lighting now time to render. If you have read step 8, this my explanation why you must create layer for every stuff.
12. Uncheck all layer except window, wall, floor and curtain and add material for every object.
13. Now time to render and see what we must edit.
14. After I see render result is too bright. I decided to edit floor material.
Floor material Before edited
Floor material After edited
15. And result after edit floor material
16. For another objects do it same technique like step 11 – 15. You must try render until you get nice result.
17. The final render using mental ray.
Find more tutorials and articles on maya tutorials or Subscribe to Maya 3D Tutorial for more tutorials and articles.
AddThis Social Bookmark Button
17 Comments
Comment by ROM
2008-04-09 20:44:15
this tutorial helped me a lot in maya lighting. pls send me some more tutorials on modelling and lighting
Comment by admin
2008-05-17 05:49:56
thanks ROM
Comment by Leaf
2008-05-16 16:57:13
Wow, good!
I need learn how to use maya or 3d studio, is fascinating…
Comment by ???
2008-05-23 22:01:25
Comment by ALi
2008-05-25 19:33:57
hii..!
i relly liked this tutorial..realy helped me alot for learning lighting effects and interior modeling..
well im new to maya n i hope that u gona send some good tutorials so they could help me more learning maya..
plz do send me some tips and link aswell so could download more meterial for my practice..
thanks…!
regards
ALi…!
Comment by admin
2008-05-26 12:42:43
thank ALi
Comment by syam prasad reddy.M
2008-06-03 19:46:21
It’s good knowledge for me and all lighting artists ,Whose having interest to improve themself….anyway thanks…….
Comment by admin
2008-06-05 19:47:52
Your welcome syam prasad reddy.M
Comment by Alaa
2008-07-20 14:41:16
isnt 3ds max much easier to create rooms and architecture like that,i use 3ds max quite alot and kinda new to maya,so am a bit used to 3ds max.
Comment by g2
2008-08-20 13:09:41
nice work!!!…really help full!!!!
Comment by ganesh
2008-09-07 13:33:07
hai sir, this is a good example of beginner’s in lighting,this is very usefull for me sir,really thank u very mush sir, and one more question for u sir,we can create global illumination without mental ray in maya,i need good example in maya software rendering sir,i hope??? thank u sir.
Comment by admin
2008-09-07 13:45:57
ganesh, i think global illumination one of superiority of mental ray and you can find in Maya software rendering.
Comment by Pravha
2008-09-19 23:36:14
WOW!!!!!!!! great!
hay it really help me …helpful!!!!!
Comment by FoX
2008-09-23 17:39:55
One of the fascinating tutorials i have ever come across, real simple and extremely helpful to understand lights and different modeling techniques.Thanks Admin. *thumbs up*
Comment by rump
2008-10-04 17:57:09
the area light doesnt have a caustic and global illumination option in the mental ray folder. i dont understand how everyone else has done it when it isnt even there
help?
Comment by niharika
2008-11-09 02:04:38
WOW!THIS IS GUD……I WANT SOME MORE INTERIOR TUTORIAL.HELP ME OUT OF THS GUYZ.
Comment by karthikeyan
2008-11-26 22:12:33
It is very useful to learn
Leave a Reply
Name (required)
E-mail (required - never shown publicly)
URI
Your Comment (smaller size | larger size)
You may use <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <code> <em> <i> <strike> <strong> in your comment.
Trackback responses to this post
