How to Disable the DOS 8.3 naming convention to save system resources
If you're new here, you may want to subscribe to our RSS feed. Thanks for visiting!
Windows XP uses two different names for each and every file on your system. One is the name that you see in explorer and in the command prompt, and the other is an MSDOS compatible 8.3 (8 character title followed by a ‘.’ Then three more characters to indicate the type of file) name. If you are intending to run DOS only software, or connect to pre-Windows 95 computers, you will need this second set of names. If not, you are simply wasting resources. To disable the 8.3 naming convention follow this procedure.
Click on Start—>Run type regedit click ok
Navigate the following key from left pane
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\FileSystem
From the right pane double click on NtfsDisable8dot3NameCreation key change the value from 0 to 1
Related Articles
Did you enjoy this post? Why not leave a comment below and continue the conversation, or subscribe to my feed and get articles like this delivered automatically each day to your feed reader.
No comments yet.
Leave a comment
Line and paragraph breaks automatic, e-mail address never displayed, HTML allowed: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <code> <em> <i> <strike> <strong>
(required)
(required)
