Featured Videos
A useful tutorial for creating an Ethernet or Patch Cable for net..
Interesting artistic video of what happens when you write an emai..
Heres some great inspiration for logo design with examples of mod..
I often use this text effect for intros or as a button roll over ..
Google Analytics is one of the most important tools you can use i..
Popular Tutorials
Futuristic Texture Pack
A collection of futurstic textures used in the Future city project...
Futuristic city, 3D techniques in Flash
See the tricks behing the advanced Flash animation that was used to bring this futuristic ..
Gradient Mapping
How to transform a standard photograph for use with a specific colour scheme or brand imag..
Creating Gradient Buttons
In this crazy new world of web 2.0 some designs call for some bright, shiny gradient butto..
Setting position of an external SWF file in Flash
Loading an external SWF, levels in Flash
For those who don't even know about loading external flash files here's a quick explanation.
You basically start with your main or parent flash movie, now when working with multiple movies you have to remember that each movie including the parent is situated in its own level within the flash environment. The main thing to remember is that all parent flash movies (i.e. the main mo vie from which you wish to load external movies) is running on the _level0. So for example every time you add the action play(); to a frame you are in the eyes of the flash world actually doing this
_level0.play();
When loading a movie into flash you are asked to input the path to your movie for example external1.swf and the level in which you want this to be loaded into:
LoadMovieNum("external1.swf",2)
The above action script will load the external1.swf into _level2 of the flash environment, so after reading the above the way in which you control these movies should be pretty obvious, if not here's some examples:
Once you've loaded the movie with
You can control it like so:
_level2.gotoAndPlay(25);
if (_level2.variable=="yes") {
_level2.play();
Set the position of an external SWF
As some of you may have noticed when you load an external swf into your flash movie it will always be positioned to the top left of the parent clip. This is all well and good for most tasks but heres how you can set the position of a loaded SWF."
First you will need to create a new movie clip (drawing something in this clip like a simple shape or cross will help you with positioning in the final stage)
Now give it an instance name, lets say for this example we call it "Testing"
Next right click on the frame containing our new "Testing" movie clip and go down to the Actions menu. Now this is the part where we would normally add in some action script similar to this:
LoadMovieNum("external1.swf",2);
But because we now want to insert our external clip into our "Testing" movie clip you must use the following action script instead:
Loadintomovie("external2.swf","_level0.Testing",2);
That's pretty much it, all you need to do now is move the "Testing" movie clip to where you want your external movie to appear.
Comments (4)
hello, when i load an external movie "contat _form.swf" into a placeholder movie resided in my main movie, all combobox componets of the external movie wont work. i know that the movies are all loaded into _level0 caus i dont use loadMovieNum. when i load the "contact-form" into _level1 of the placeholder movie it appears in the upper left corner but the comboboxe work. i tried to use _level1._x and _y in the main, in the placeholdr and in the contact movie but it wont work. what am i doing wrong?
Posted by: anonymousshame on 07/08/2008
AS is case sensitive. If won't work. Its if. ;)
Posted by: UnknownFury on 19/07/2008
This works, follow carefully, thanks
Posted by: Anonymous on 17/06/2008
'Loadintomovie ', that doesn't work + there's a comma in the wrong place.. try this: _level0.Testing.loadMovie("external.swf", 2)
Posted by: smartypants on 27/05/2008
Comments:
Author:
What colour is the sky?
Related Content
Web Development Guide
A large selection of expert tips and advice to help you design and market the perfect web ..
Brunette to Blonde, How to change Hair Colour in Photoshop
Here's a great tutorial for those who want to learn more about selections and colour chann..
Road Marking 'Street Art' by Peter Gibson
Heres a collection of amazing photos from street artist Peter Gibson, this work is amazing..
Simple Bad Word Filter in Flash
Learn the simplest way to remove bad words or swear words from a flash input field or dyna..
Set position of external SWF file in Flash
A few tips for using levels in flash when loading swf files, and how to set the position o..
 Subscribe to our feed
Send to a friend
