3D Gallery |
Blender Tutorials |
Dance Workshops |
Essays |
Quantum Entanglement
Blender Tutorial
by Dave Jarvis
Last Updated: Saturday, 15-Dec-2007 13:24:07 PST
Blender Version: 2.43
Geothermal Layers
This tutorial shows novel mesh editing techniques, including:
Fast vertex, edge or face (de)selection.
Loop cuts.
Vertex groups.
Region extrude.
Perimeter selection.
Setup
Press CTRL-X then Enter
to create a new model.
Press Del then Enter
to remove the box.
Press NUM7 to change the view.
Press SPACE then
Add » Mesh » UVSphere.
Press CTRL-Tab then
2.
Select and Scale the Vertices
Press a to deselect all vertices.
Press b for the selection cross-hairs.
Click RMB and drag to select 1/4 of the sphere.
Click NUM1 to see the half-selected sphere.
Press CTRL-Tab then 1 to
be in Vertex select mode.
Click MMB and drag to deselect bottom 1/8 of sphere.
Press F9 for the Editing buttons.
Click New to create a new Vertex Group.
Provide a name for the vertex group (e.g., Cut-away).
Click Assign to associate the selection of vertices (1/8 of the sphere)
with a name.
Press . or click the Pivot Menu to change the
Pivot to 3D Cursor:
Press e then
1 then
Enter then
to extrude the region (but do not move it).
Press s then
0.193 then
Enter to scale the region.
Press CTRL-Tab then
3 for Faces selection mode.
Cut and Scale
Rotate the view.
Click the Image Selection to Visible icon:
Click SHIFT-RMB to select each of the three faces.
Press SHIFT-G then
4 to select the desired faces
(Similar Perimiter).
Alternatively, you could select all the faces by hand ... if you are
masochistic.
Press CTRL-+ to increase the selection of faces.
Zoom into the core and deselect the Cut-away faces.
Press b then b again.
Click MMB.
Carefully drag the red circle along the edges.
Press SPACE.
Click Select » Inverse.
Click Set Smooth to smooth everything except the inside faces.
Press SPACE.
Press CTRL-Tab then
2 to go into Edge select mode.
Create a new Vertex Group called Faces (don't forget to
click Assign).
Press CTRL-r to make a Loop Cut.
Press Enter to accept.
Move the mouse (without clicking) until Percentage equals 1.
Click LMB.
Press s then
.547 then
Enter
to scale the Loop Cut.
Cuts are made from the smallest to the largest.
Click LMB.
Press s then
.577 then
Enter
Repeat the previous five steps but use .994 as the
scale factor.
Press a to deselect the faces.
Assign Materials
At this point, you can use the Vertex Groups to assign materials for
the different layers.
This feature is covered in the
next
tutorial. You can download and review the .blend file, as
well.
THE END - Download
3D Gallery |
Blender Tutorials |
Dance Workshops |
Essays |
Copyright © 2007-2008 by Dave Jarvis
