There's nothing like building an entire site to show you a good overview of how a CSS layout should work. Over at PSDTUTS we've got a tutorial where you design up a sleek, high end web design. In this tutorial we're going to take that PSD file and build it with some nice clean HTML and CSS.
Demo and Source Code
So here's the design we're going to be building. As mentioned you can follow the tutorial over at PSDTUTS to build this design from scratch. In this tutorial we're only going to build this homepage, however using that as a base you would be able to build interior pages following the same layout.
The first thing to do is decide how we are going to structure our build. This process gets easier over time as you learn how CSS layouts can work. For this design I think we can get away with a very simple build which uses quite a bit of absolute positioning and a large background image.
What is Absolute Positioning?
When you place an HTML element on a page (e.g. a <div>, <p> and so on) it has a natural position which is determined by what came before it. So for example if you put a <p></p> down with some text in it, and then you place another <p></p> it will naturally appear just below the first <p>. It will just flow on relative to the last element.
Absolute positioning is different in that you are specifying an exact placement for an object and taking it out of the regular flow of elements. So if you had your first <p></p> just as before, but for your next <p></p> you gave it an absolute position of left:500px; top:500px; Then it would appear precisely in that location regardless of the previous <p>.
You set the absolute position of something like this:
.className {
position:absolute;
top:0px;
left:0px;
Drawbacks to Absolute Positioning
The main problem with using absolute positioning is that your elements don't really relate to one another. So for example if you have one block of text near the top of your page, and another block of text a bit further down, it might look great when each block of text is short. But if the top block were to have a big essay in it, then instead of pushing the next block of text down, it will just go over the top. This is because you are taking the elements out of the natural flow of the page.
So Absolute Positioning is only really useful for objects that you know will always be a certain size, and which don't really need to interact with other elements.
Why it's useful to us today
The good thing about Absolute Positioning, is that it's really, really easy! You tell the browser where to put something and that's where it appears! To top it off, there are far fewer browser compatibility issues when you position things absolutely. After all 100px is 100px whether you're in Firefox, Internet Explorer, or Safari.
SOOO our layout
So the way we are going to make our website is:
- Have a large background image
- Absolutely position the logo, menus, and heading panel precisely where they are meant to appear
- Have all our content appear in a regular <div> tag, but give it so much padding-top that the content is pushed all the way down to where it's meant to be
- Have our footer sitting underneath
If that doesn't make a whole lot of sense yet, don't worry it will as you see the site take shape!
Now in terms of background images, we need two. One is going to be gigantic, and in fact after I saved it as a JPG it is about 56kb in size. There used to be a time where that would have been a bit too big, but these days it's not a big deal.
So that's the main area, then we need a second background image which will be a thin slice. This slice will repeat over and over off to the right so that when the browser window is dragged open it tiles out.
(Note the logo shouldn't be showing below in the background image, that was just some bad screenshotting, sorry!)
You can see the two images I've created here and here.
OK so now let's start our HTML. First we lay out some basics:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title>PSD vs NET</title>
<link rel="stylesheet" href="step1_style.css" type="text/css" media="screen" />
</head>
<body>
<div id="outside_container">
<div id="container">
<!-- The Main Area -->
</div>
</div>
<div id="footer">
<img src="images/footer_logo.jpg" />
<span id="footer_text">
Made for a PSDTUTS and NETTUTS tutorial by Collis!
See the <a href="http://psdtuts.com">Photoshop Tutorial</a>,
see the <a href="http://nettuts.com">Web Tutorial</a>
</span>
</div>
</body>
</html>
As always it's best to work from the outside in with our layout. So what I've done here is place three major <div>'s. The first two are the outside_container / container and the other is the footer. This requires a little explaining:
- I've created the outside_container and container because I need a double background image. That is I need a tiling background image, and then on top of that I need that large background image. So in the outside_container I'll place the tiling background, then on the container <div> which will appear on top of the outside container, I'll have that big main background.
- The footer needs to be outside the containers because if the browser window were stretched lengthwise, the footer should go on and on. Since it has its own background, it can't be in the containers - if it were and you stretched at some point you'd see the container background and not the footer!
Also you'll see I've added some content inside the footer, that's just the mini logo, and the text. I've wrapped the text in a <span> tag so that I can manipulate it. There's no reason to give the <img> tag an id or a class, because we can just say #footer img and since it's the only image in there, we can call it that way. This keeps our HTML a little simpler.
Now the CSS for our code so far:
body {
margin:0px; padding:0px;
background-color:#11090a;
font-family:Arial, Helvetica, sans-serif;
#outside_container {
background:url(images/background_slice.jpg) repeat-x #000000;
#container {
background:url(images/background_main.jpg) no-repeat;
min-height:800px;
#footer {
border-top:1px solid #3f2324;
padding:30px 50px 80px 50px;
So going through one at a time:
- First we are redefining the body tag. This is almost always the first thing I do. We get rid of any default margin and padding, set a background color and a font-family for the page. Notice that the background colour is in fact the footer background colour. As I mentioned previously this is so that if you stretch the browser window vertically you'll keep seeing footer.
- Next we have the outside_container tag. I've given it that slice background, it's going to repeat only along the x axis (i.e. from left to right) and wherever there's no background image we'll see straight black (#000000). So basically as the page gets longer the tiles won't keep going because we said to only repeat left-right, instead we'll get the black background. This is perfect because our tiling image fades to black!
- Next we have the container. Here we have the gigantic background image set to not repeat - so it only appears once. Notice we didn't specify a background colour, if we had it would have covered our outside_container over. That's because this <div> tag is inside the previous one, and will automatically be stretching out to fill it up completely. So our background image appears on top and then outside that area you can see the outside_container background showing through.
- I've also given the container a minimum height, this is just so that when we look at the HTML page at this point you can see roughly how it's going to look when there is content. Later on our content will produce the minimum height anyway.
- The footer is basically just a single line border and some padding. There's no need to give it a background colour, because we set that in the <body> earlier. Remember with the padding definitions it goes like this: padding: top right bottom left (clockwise!)
Here's where we are up to now...
View The Site So Far
Next we'll finish off that footer by adding a few extra styles like this:
Footer
#footer {
color:#674f5d;
font-size:9px;
line-height:14px;
#footer img {
float:left;
margin-right:10px;
#footer span {
display:block;
float:left;
width:250px;
#footer a {
color:#9e8292;
text-decoration:none;
#footer a:hover { color:#ffffff; }
So here I've added a few bits to our #footer class and created a few more classes. Let's go through it one piece at a time:
- First of all the bits between /* and */ are CSS comments. It's nice to have comments in your CSS file as it really breaks it up and helps keep things intelligible. Actually on larger projects I find CSS files can get pretty out of control if you're not careful. So it's really good to try to get into good habits early: name your selectors well, add comments, keep like things together, break into multiple CSS files for larger projects and so on.
- In #footer I've added a font color, font size and line-height to our previous definition. Line-height is a really useful text attribute as it helps you space out your text. Without good line-height text can look bunched up and harder to read. Too much line-height and the text will be so spaced out it looks weird. So you might want to experiment to find the right heights for different fonts and sizes. Here 14px seemed like a good fit.
- Next I've set the #footer img and #footer span to both float:left. Because they are both set to float left, they end up in columns next to each other. I'll talk more about floating and columns later in this tutorial.
- Finally we tell the browser what to do with <a> tags (i.e. links) that appear in the footer. Namely that they shouldn't be underlined, and should change color when you hover over with a mouse.
So with the addition of the footer here's where up to:
Now with the footer out of the way, let's add some more content to the page inside the main container areas. First we need two new images that we make out of our PSD file:
Notice that I've used an image for the big text block. In general it's best to use text for these things as it makes the page much more searchable and is good practice. But it would have been much harder to do as we'd need to use a bit of Flash and SIFr to achieve that effect. So since this is a fairly straightforward tutorial I've opted to just use a big image :-)
Here's a snippet of our HTML code - just the containers bit:
<a href="#"><img src="images/logo.jpg" id="logo" /></a>
<ul id="menu">
<li><a href="#">Retouching</a></li>
<li><a href="#">Digital Effects</a></li>
<li><a href="#">Web Work</a></li>
</ul>
<ul id="right_menu">
<li><a href="#">About</a></li>
<li><a href="#">Contact</a></li>
</ul>
<img src="images/panel_home.jpg" id="panel" />
<div id="content">
<!-- THE CONTENT GOES IN HERE -->
</div>
</div>
</div>
So inside the container area we've added five things:
- Our logo: It's linked, so clicking it should take you to the homepage, and has id="logo"
- Main menu: This is simply an unordered list with id="menu"
- The right hand side menu: This is the same as the other menu, just different id="right_menu"
- Big text panel image: This is our main heading text saved as an image, id="panel"
- Content Div: And this is where we are going to place all our page content later on. I've left it empty right now except for an HTML comment.
So before we start styling it up, it's worth having a look to see how the page looks with just everything dumped on like this:
As you can see we're going to have to do some serious shifting around to get everything into place. As you'll recall we're going to use Absolute Positioning to do this quickly and easily.
Here's the CSS we add to make our elements start to fit into place:
#container {
min-height:800px;
width:1000px;
position:relative;
Logo / Menu / Panel Positioning
#logo { position:absolute; top:58px; left:51px; }
#panel { position:absolute; top:165px; left:51px; }
ul#menu {
position:absolute; top:145px; left:75px;
ul#right_menu {
position:absolute; top:145px; right:75px;
So again let's go through each bit piece by piece:
- First of all, you'll see an old bit of our code - the container. I've shown this as I've added two more lines to it now. It now has a width:1000px and position:relative. This is important because when you set position to be relative, anything absolutely positioned inside, is done so relative to that container tag. So this means I can position things inside this box, using the fact that I know it's 1000px wide. Namely I'll be using that for the right_menu.
- Next because this is a new set of CSS, I've sectioned it off with a comment
- With the logo and panel I've given both an absolute position on the page. How do I know what numbers to use? Simple go back to the original Photoshop document and measure out where they are meant to be! You can see it's a really simple class definition, which is why absolute positioning is so easy.
- Next with the two menus, these are also absolutely positioned, but here I've also given them margin:0px; padding:0px; definitions to make sure we clear away any default margins and padding which unordered lists have.
- Next notice that on the right_menu when I have specified the absolute position to be right:75px. This means that it will appear 75px away from the right hand side of its container. Ordinarily that would be the browser window, but because remember earlier I set the container to have position:relative that means it will be 75px away form the right hand side of <div id="container"></div>.
Now you might be thinking, well what's the point, can't I just position things using left only? Well you can, but with our menu, if you were to add extra menu items you would need to reposition it again and again so that it was still 75px away from the right hand side. Whereas by using right the extra menu items flow left when you add them. Try it and see!
So here's where we are at:
As you can see in the previous image, the logo and heading element are now looking like they are in the right position. But the menus are looking kinda weird. Before we style those, a quick word on the logo / image panel. You might be wondering, if they are both images, why not make them part of the background image?
The answer is that the logo we want to make linkable, so that clicking it will take you back to the homepage (makes the site more usable), and the main text panel, well that would probably change from page to page. So by having it a single image, we can have lots of HTML pages using the same CSS stylesheet but simply positioning a different image there with different text.
Now let's style the two menus and make our page really start to take shape. To do that we need the following CSS:
ul#menu {
position:absolute; top:138px; left:75px;
ul#right_menu {
position:absolute; top:138px; right:110px;
ul#menu li, ul#right_menu li {
list-style:none;
margin-right:10px;
font-size:9px;
text-transform:uppercase;
display:inline;
ul#menu li a, ul#right_menu li a {
color:#bd92b2;
ul#menu li a:hover, ul#right_menu li a:hover {
color:#ffffff;
The first two bits of this code are the same as before (although I adjusted the positions a little to make them look right after styling). Notice that these two definitions are separate as they have different positions, but after that we've combined the two into the same class definitions as the menu items themselves should look the same. The format for defining two classes together is:
.myClass, .myClass2 { ... }
This is very different from this definition:
.myClass .myClass2 { ... }
Because the second definition says, all elements with class="myClass2" inside an element with class="myClass".
Anyhow so back to our styles, let's go through some important points:
- We've set the <ul> elements themselves to 0 margin and padding, and absolute positioning, as we discussed previously
- Then we've said for all <li> elements inside those <ul>'s we want them to have no list-style (i.e. no bullet points), we want them to 9px, all upper case, and importantly they should display:inline. Inline display means instead of being blocks that appear one below the next, these will appear next to each other!
- The next definition says that for <a> link tags that appear inside an <li> tag that are inside <ul id="menu"> or <ul id="right_menu">, they should be a certain colour and have no underline.
And with that, our page is now looking pretty good!
Step 10
Next it's time to add some content! First let's add some dummy text, set up so that we can make columns. Here's the HTML:
<ul id="menu">
</ul>
</ul>
<div id="content">
<div class="column1">
<h2>a sleek design</h2>
<p>Dummy Text: This design was produced for a photoshop and web development tutorial. You can see the first part up at PSDTUTS.com where you learn how to create a beautiful, but simple design using an abstract background and type.</p>
<p>The second part of the tutorial is available via NETTUTS.com where we do a quick build of the PSD into a viable, working HTML/CSS site.</p>
<p>This design was produced for a photoshop and web development tutorial. You can see the first part up at PSDTUTS.com where you learn how to create a beautiful, but simple design using an abstract background and type.</p>
</div>
<div class="column2">
<h2>tutorials</h2>
</div>
<div class="column3">
<h2>recent work</h2>
</div>
</div>
</div>
</div>
OK so in this snippet, you can see I've added 3 new <div>'s inside the content area. Each one has a <h2> title element and them some text. They have class names column1, column2 and column3. The reason I've added all the extra text is to show you something about making columns.
First let's add some CSS to make them appear like columns:
Content
#content {
padding-top:435px;
padding-left:85px;
width:815px;
color:#674f5d;
font-size:13px;
line-height:20px;
.column1 { float:left; width:230px; margin-right:30px; }
.column2 { float:left; width:230px; margin-right:30px; }
.column3 { float:left; width:270px; }
As usual I've sectioned off our new bit of CSS with a comment. Then I've set some styles for #content. Notice how much padding-top there is ... 435px! This is to make space for all those absolutely positioned elements earlier. Unlike those elements this content area is in the normal flow of the page.
It needs to be in the regular flow because as you add more content to it, it should push the footer down. If this was absolutely positioned it would just go over the top of the footer.
Now the three column classes, notice they are each set with a width and with float:left. This tells them that they should drift to the left of the page aligned next to any other left floating elements. I've given the first two a right margin so they aren't stuck to each other.
Floating an element makes it drift to the left or right, and tells everything else to wrap around it. When the other elements are also floated, they form into columns. Generally any time you see a column layout, it's using floats.
Unfortunately there is one weird problem with floats. Namely that they have a problem with their containers. Instead of pushing the next elements down, they just drift over the top. The way to solve this problem is to have an element that comes after them which has the property clear:both.
The Clear property says to stop wrapping stuff around the floating <div>'s. It's a bit hard to explain, so let's look at what happens with and without the clearing.
Without Clearing
Here is how the layout looks as is:
See how the columns have drifted over the top of the footer, and the footer itself has started wrapping around them. That's not right!!
With Clearing
The solution is reasonably simple, we need to add a <div> after the three columns like this:
<div id="content">
</div>
<h2>tutorials</h2>
</div>
</div>
<div style="clear:both"></div>
</div>
See the <div style="clear:both"></div> down the bottom? It's just an empty <div> that says to clear out the three columns. And it fixes our problem,
View the Site Here.
A Few Last Words on Floats & Clearing Them
You might be wondering why I didn't place the "clear:both" into the <div id="footer"> definition, but unfortunately that doesn't work out because of the background we're using ... here's a screenshot:
Apparently there is a solution that doesn't involve inserting a useless <div> tag, and you can read about it at QuirksMode. Personally I've been using this method for a while, and it works well and consistently so I keep doing it.
Step 11
OK, almost there now!! The main layout is all sorted, all we have to do is add and style our content. Here's the HTML for it:
<div id="content">
</div>
<h2>tutorials</h2>
<p>Psdtuts and nettuts provide tutorials on the following topics (sorta):</p>
<img src="images/adobe.jpg" />
</div>
<ul class="work">
<li>
<a href="">
<img src="images/work_1.jpg" />
<h4>Working Within Limitations to Achieve Great Designs</h4>
Sean Hodge
</a>
</li>
<li>
<a href="">
<img src="images/work_2.jpg" />
<h4>Create a Slick Tabbed Content Area using jQuery</h4>
Collis Ta’eed
</a>
</li>
<li>
<a href="">
<img src="images/work_3.jpg" />
<h4>Creating a PayPal Payment Form</h4>
Collis Ta’eed
</a>
</li>
</ul>
</div>
</div>
It's basically the same structure as previously except in the third column I've created an <ul> element to contain the recent work. Notice that in this <ul> element I've set it up so that there is a link <a> tag wrapping up the image, the heading and the text. So the whole thing will become a block link. That means if you roll over the image, the text associated with it will still change colour.
So here's the CSS for our content:
#content h2 {
font-family:Georgia, "Times New Roman", Times, serif;
color:#dbaa70;
margin:0px 0px 20px 0px;
font-weight:normal;
ul.work {
ul.work li {
list-style:none;
clear:both;
ul.work li a {
color:#e0b882;
display:block;
padding:5px 10px 5px 10px;
font-size:10px;
ul.work li a img {
float:left;
margin-right:20px;
margin-bottom:20px;
ul.work li a h4 {
color:#674f5d;
margin:0px;
font-weight:normal;
font-size:13px;
ul.work li a:hover, ul.work li a:hover h4 { color:#ffffff; }
Lets go through the classes one by one:
- First we are redefining what <h2>'s that appear inside <div id="content"> look like. We could have just redefined all <h2>'s, but you never know when we might have a <h2> that appears somewhere else, so it's good practice to be reasonably specific. All I've done here is change the colour, font, weight and margins to make it look the way I need.
- Then we have the <ul class="work"> definitions. The first <ul> definition just gets rid of the margin and padding.
- Then the <li> definition says there should be no list-style (i.e. no bullet point). It also says clear:both. As you recall from the last step this is to clear floating elements. And if you scan down a little you will notice that the img definition later on has a float. So here we're saying each new list element <li> should be clear and not wrapping around parts of the last one.
- Next in the <a> part, we're saying that the <a> tag should display as a block. That is to say we want our links to be a big block that encloses the image and text. We give it some padding to flesh out the block and set some styles for how text should appear.
- Next we say that the <img>'s inside our <a>'s should float over to the left with a bit of a margin.
- Finally we define the colour of the text in the <h4> bits.
And that's it! We're done!
Finished!
And with that the site's homepage is complete. You can download a ZIP of the site files to look through - it contains the HTML for different stages of this tutorial. And of course you can see the final HTML document:
View the Final Page Here
Internet Explorer
Now you should always be doing cross-browser testing. Alas I have just switched from Windows to a nice new Mac and haven't got a Parallels/Win install yet, so I can't! I did a quick check via BrowserShots.org and can see it's mostly working fine in IE6/7, however there is a problem with the three columns forcing the footer much further down than they should. Anyhow should be an easy fix, but until next week when I've installed Windows, IE users you're on your own :-)
I will update here once I've had a chance to iron out the crinkle but I didn't want to hold off publishing until then!
Related Posts
Check out some more great tutorials and articles that you might like
User Comments
( ADD YOURS )Adam April 25th
Great Stuff!! I have been looking for a tut like this for a long time.
Gino April 25th
This is so incredibly helpful! I’ve been trying to brush up on my coding skills and this has helped a ton!
Andrew D April 25th
Great tutorial
Constantin Potorac April 25th
Great Tutorial Collis. Thank you
Brian April 25th
You guys should do one that explains the other types of positioning in the future too! I would LOVE to read it. I’ve been making all of my pages in iWeb because I can’t seem to grasp how the positioning works. GREAT TUT though….
Shane April 25th
As I’ve just commented over at psdtuts.com, thought I’d have a look over on nettuts! Another great tutorial
Thanks.
Diego April 25th
good job great tutorial
Razvan April 25th
Thanks for the tutorial, coding isn’t really my thing..
Manuel Merz April 25th
Good stuff Collis but why not making it valid? I mean you’ve used a simple and good structure so don’t get stuck on things like this. I think its important to tell beginners that they should check their code with the validator to correct and fix errors. It’s also important for further SEO checks,
Another thing is to use the three images on the “recent work” as background images and use a span tag for the textlink to give them a padding with the size of the image. There are most of the warnings/errors coming from…
Regards
Manuel
Lamin Barrow April 25th
Very nice. Thank you for all the design and coding effort.
Qbrushes April 26th
coding isn’t really my thing but its made so simple in these tutorials that its fun and just great to see the outcome.
Shawin April 26th
hey there.
thanks a lot. I’ve been looking for a complete photoshop to CSS/HTML tutorial for a long time to help me start with CSS.
university only taught me html, slicing and tables and I hated that.
now I can finally start making websites again.
cheers.
LongyZ April 26th
Really great tutorial! I’ve never tried HTML code before but this tutorial has inspired me to give it a go!
macias PL April 26th
psd / html / css - excellent 4 me … thx a lot…
HDCase April 26th
Thanks guys!
This one is the best tut i’ve ever seen. Period.
mike April 26th
Excellent coverage of the basics. Where were you when I needed you? My own site will be going live this weekend or early next week. Only thing I would like to point out is that for something like a portfolio site that would be regularly updated it is probably best to build it on a CMS platform, perhaps Drupal or Joomla or even Wordpress, but then I suppose that is a whole other tutorial.
Nice one!
Ben Griffiths April 26th
That looks cool - way better than my portfolio!
Markus April 26th
You are god!!
Mark Provan April 26th
Nice tutorial
Thanks
Harry April 26th
I have not done it yet but it will be awesome!
Hendri April 26th
Great Tuts Collis! we love u
David April 26th
I cannot wait to try this material out. I’m not skilled in CSS or the coding end of things, so this is way exciting…
1984 April 26th
This tutorial is finally complete.
You showed how we as creates the design and then how this design incorporated through XHTLM and CSS.
I do I say that this tutorial will be highlighted on both sites ! PSDUS and NETTUTS.
Again thank you !
giackop April 26th
thanx.. the most useful tutorial ever.. love it
Misa April 26th
this looks awesome. if I create a wordpress theme using this tutorial, would you mind? I mean, regarding copyright and that stuff.
Daniel April 26th
Great tutorial here, very useful! thanks a lot collis !
arnaud April 26th
Very good thx
Nick April 26th
AWESOME! Thank you for starting to do these!!!
tony April 26th
Great work! I really hope you’ll make a similar tutorial for the “Designing a family of websites” tutorial. Thanks,
will April 26th
Very nice.
A few things I would change about this though:
The large image (panel_home.jpg) with the text “By keeping a sharp polished…”.
Instead of using an image here I would have used an H2 tag and used image replace methods to hide the text but still leaving it visible to search engines and use the image as a background for the H2.
For example:
h2{
display:block;
width:851px;
height:199px;
text-indent:-5000px; /*Hides the text*/
background:url(/images/panel_home.jpg);
The second thing is the use of a ul for the work. I would suggest using a dl (dynamic list) which supports the dt (title) and dd (content) tags. It makes more sense that way as each work item has a title and then content.
Will
Engage Interactive - Web Design Harrogate
Ali April 26th
This is an excellent tutorial, very helpful
D. Carreira April 26th
Thanks!
David Carreira
Bryan April 26th
Seriously helps me understand everything I’ve been trying to teach myself. Thank god I kept up on PSDTUTS!
Ben April 26th
Amazing! Thanks so much for posting this.
daniel lopes April 26th
Hello Collis, please open up to contributions. I had hundred topics to write about CSS, XHTML, FLASH, FLEX and Javascript.
Great tutorial, bye.
Nate April 26th
Collis strikes again! Thanks bro for this awesome tutorial, it will definitely come in useful.
Chris Voll April 26th
Have you tried ies4osx? It’s basically Internet Explorer running on a Mac under Darwine. The IE7 port is still a bit buggy, but it works well nonetheless, doesn’t require a PC (or Windows, for that matter) to use, and, best of all, it’s free.
http://www.kronenberg.org/ies4osx/
endorphine April 26th
I personally think the logo should be and the panel a styled .
Having raw text hidden will help you with search engines.
Still a very good tutorial
TheMystical April 26th
Very nice, thank you.
Mantero April 26th
Great Tutorial! Thank you so much!!
Hope u can work for wordpress themes coding tutorial next time..
Thanks a lot
Nico April 26th
Awesome! Thank you!
Doug Avery April 26th
You’ve done a great service to new web designers with this post. Good job!
Kyle April 26th
Great job. Especially like the integration between PSDtuts and NETtuts.
Please, do some more collaboration tutorials.
Kakumei88 April 26th
WOW!!! I have been needing a CSS tutorial! I thank you A LOT, and I mean A LOT! I am going to have to get to work on making that website for my friend!
Michael Castilla April 26th
Fabulous tutorial Collis. Really great work and nice design
ZaFaR April 26th
Really awesome work collis! Very much interested nice work! great work at right time, thank for sharing,
Hats off to collis.
godonholiday April 26th
Great!!
Just a note to those who say you should build this around a CMS… well that is not always the case, you can look at building your own CMS with some basic PHP and MySQL…..
and a recently linked site cushyCMS…. this option is great for those who are new to web design and content management systems.
this was such a great tutorial i cant wait to see how everyone bends it to suit their needs….
would be cool to have a flicker pool for these?
Andrei Constantin April 26th
I have to admit that nettuts already starts to look hot, and not that i had any doubts about it
however i would like to see a tut about slicing up a psd
Derek April 26th
Should you really have used absolute positioning?
It seems like it would have been simpler and easier to add things later if you hadn’t…
ashvin April 26th
thanx a lot man! you rock!
Gale April 26th
Great Staff! Thank you for publishing it!
Lukas Orgovan April 26th
Pretty cool tutorial, you really make things so clearly and light and simply so powerfull… Just amazing.
But I have one question. Why you created the ‘outside_container’, when you could easilly add background to the body??? I think, it was needless.
Anselmo April 26th
Great explanation and result.
Thanks
Sean April 26th
Thank you, Thank you, Thank you! Great work!
gen April 26th
Very nice tutorial Collis! We need more practical full-length tutorials like rather than the theoretical stuff you find about building beautiful sites.
ud2008 April 26th
Collis mentioned that he was planning on installing Parallels and I a, wondering which people preferred to use on their Mac , parallels or fusion?
Thanx.
Taylor Satula April 26th
WOW great keep up the psd css lovin.
Catherine April 26th
Thanks so much! I was just wrestling CSS on a project this week where your footer explanation would have come in handy! I’ll definitely organize my next project pages this way–it’s great to have the entire PSD through CSS/HTML workflow explained, especially for those of us who take site projects all the way through on our own. Bravo!
Also, I did the pc to mac upgrade and did get Parallels. But you still can’t view/test in IE locally from Dreamweaver. The site has to be loaded live to view in IE. (Which I do my stashing it on a hidden file in my site, but what a pain!)
Aminur RAHMAN April 26th
nice tut,
DT April 26th
Damn good one Collis! I have been looking for something like this!
Josh April 26th
first off, Nice tut!
wouldnt it be much easier and also less space if you just used CSS to make the background color black (or what ever the color of your thin slice) than use the slice that is repeated?
-Josh
Erika April 26th
Nice work, guys.
Sam Wieck April 26th
Very cool tutorial! Would love to see how one would work a design like this to fit in with Wordpress! Using page templates etc.
Jonno April 27th
Not a bad design but your coding leaves a lot to be desired. Noobies will get a kick out of it though.
Tim April 27th
Very nice result! Very professional looking =)
There are a minor few things I would add:
The logo would be more semantically correct if it were placed in a h1 with the span element hiding the text.
html:
Logo text
css:
h1
height: 100px;
background: url(”/images/image.jpg”) no-repeat;
h1 span
display: none;
Also using:
* { padding: 0; margin: 0; }
..at the start of your means you don’t have to keep typing margin:0; padding:0; for everything
Tim
Tim April 27th
ok the form seems to have stripped my html out, it should read:
html:
[h1][span]Logo text[/span][/h1]
Robin April 27th
Not how I would have positioned or laid things out to be honest.
You will find that the only way to get everything looking the same in every browser, is to use floats. Left floats. With a fixed width, adding up to the same width as the main content. Especially if you are center aligning something.
I wont bad mouth absolute positioning because it is quite useful when you’re working with a element inside a relative positioned element.
I like the design but it doesn’t seem very practical. Black on white is pretty much the only thing corporate business want these days, and if it doesn’t look and the same in all browsers then you can kiss your contract/paycheck goodbye.
Sam April 27th
Really nice, great guide from start to finish.
Roberto April 27th
Absolutely stunning work and for free, definitely one of the most useful tutorials I found in the net. Thanks so much for sharing!
Johan April 27th
Thumbs up!
Acronyms April 27th
Great one for all those who are learning.
Ariful Khan April 27th
Great!! I was looking for such type of tutorial. I must practice this after my exam. Carry on….
sebastian April 27th
i agree, great tutorial. Been looking for a tutorial like this for a while too.
Brandon April 27th
Another gem! Keep ‘em comin’!
Liam Morley April 27th
absolute positioning + pixel-defined font sizes = bad accessibility/design, the last thing you want to highlight in a portfolio. as someone else commented, not specifying everything absolutely and letting things naturally flow around each other actually might save you time in the long run, it just requires you to think more about how things relate to each other.
Fubiz April 27th
Impressive tips !!
RedesignYourBiz.com April 27th
Thank you soooooooooooooooooooooooooooooooooo much
very well written tutorial.
http://www.redesignyourbiz.com
Nikhil April 27th
Way da Go!!
Following this up!!
Rolando Murillo April 27th
Really cool stuff my friend! This kind of design is what I like in websites.
Action discrète April 27th
And the level goes up.
Inspiration Up April 27th
I like the way you code the CSS its very clean and the class names are make sense.
James De Angelis April 27th
Great tutorial to cover the basics. However, as others have mentioned it would be great if you were more mindful of accessibility. Replacing chunks of text with images without an option for those with CSS/images turned off is not a good lesson for the kids.
drumkeyjw April 27th
Great tutorial! Thanks!
ud2008,
I’ve used both Parallels and Fusion and I like Fusion a lot better. Plus I believe it’s about half the cost as well. I only need it for basic stuff. I think Parallels has more features, but Fusion works for me just fine…
GeminiArt April 28th
great tutorial
thxxxxxxxxxxx
Alberto April 28th
This cross-site thingy is really great. From scratch to final result. Neat!
Danny April 28th
Hello
Nize one, but why do you use 2 different classes for colomn one and two, they are exactly the same (correct me if i’m wrong) . I would say give them the same class, that should be the purpose of xhtml and css I guess.
Tom April 28th
Thanks for this gorgeous double tutorial which gonna help me a lot !
Chris April 28th
