Awesome Photorealistic Coloring Techniques
May 1st in Photo Effects by Kyle Pero
In this tutorial we will color a black and white photo using gradient maps, solid colors, and the Color blending mode. Using these techniques, you will be able to hand color any black and white photo in a way that looks photorealistic.
Author: Kyle Pero
Kyle Pero has worked in the creative fields for many years now. With a background in photography and graphic design he naturally became a Photoshop whiz. Now he works in advertising doing photographic retouching, but also does freelance design and illustration work.
Final Image Preview
Before we get started, let's take a look at the image we'll be creating. Before and after images are shown below. Click the screenshot to view a large color version. As always, the full Photoshop file is available via our PSDTUTS Plus membership.
Double-click on the background image to make it an active layer. Create a new group by clicking on the little folder icon located at the bottom of the layers palette and put the layer in the group. Name the group "girl". Draw a path around all the hard edges of the girl. This includes the face and the shoulders. Don't worry about the hair for now; we will do that separately. Save the path. Make a selection of the path by holding Command-clicking on the path thumbnail in the paths palette. Hit Alt+Command+D and Feather the selection by 0.5px. Apply the selection as a mask on the "girl" group.
Disable the mask on the "girl" group by holding Shift-clicking on the mask thumbnail. Now in the Channels palette, duplicate the red channel by dragging it to the New Channel button at the bottom of the palette. Apply a harsh curve, like the one below, to separate the hair from the background as much as you can.
Hit Command+I to invert the red copy channel. Re-enable the mask on the "girl" group. Load the selection of the red copy channel with your background color set to white. Hit Delete(backspace) to fill the selection with white on the "girl" mask. If you hit Alt+Click on the mask thumbnail, you can see the mask as a channel. Clean up anything that looks as though it shouldn't be there, like that line between the hair and the face.
Now let's start to add some color using a Gradient Map. In the "girl" group, make a new Gradient Map adjustment layer just above layer 0. Hit OK without doing anything and set the Gradient Map layer's blending mode to Color. Now double-click on the Gradient Map's layer thumbnail to open up the settings again.
A Gradient Map uses the grayscale data from the image below it to apply the gradient that you create. The left side of the gradient represents the darkest parts of the image. The right side represents the light parts. We need to make a gradient that represents what the woman's skin tone might look like from dark to light. I used the gradient below.
Draw a path around the eyes. Load the selection of the path and Feather it 0.5px as we did before. Make a Curves adjustment layer just above the skin layer. Then lighten the eyes a little bit. Now make a Gradient Map layer just above the curves layer and hit OK before adjusting any settings. Set the new Gradient Map layer's blending mode to color. Now hit Alt+Command+G to apply it as a clipping mask to the curves layer. Now change the Gradient Map's settings to a pink-to-white fade like below.
Draw a path around just the iris of the eye. Note that we need only the path to follow that one curve between the iris and the whites because the adjustment we are making will be applied as a clipping mask. Load the selection and Feather it 2px. Make a solid color adjustment layer just above the Gradient Map from the previous step. Then set it to a dark faded green. Hit Alt+Command+G to apply it to the same clipping mask you made earlier. Set the blending mode of the green layer to color. You might have to go back and adjust the green until you get a color that looks real.
Repeat all the previous steps for the lips, except for this one we'll leave the blending mode of the Gradient Map to Normal, and set the layer's Opacity to 65%.
We need to get more variance of color in the skin tones to make it look more real. I made some selections around the eyes, nose, and cheeks. Then I feathered them 20–40px, created solid color adjustment layers, set the blending modes to Color, and brought the Opacity way down to 10-20%. Below you can see my selections as quick masks. The layer palette shows the colors I used for the different areas. As you can see I used some red to add some blush to the cheeks, some red around the nose, mouth and eyes, and some blue to go on the bags of her eyes. These small details make all the difference.
Make a loose selection around the face and neck and feather it 50px. Make a curves adjustment layer just above the 'skin' Gradient Map that we made earlier. I just went in and tweaked the colors a bit to get a little more color variation in the skin tone. You can download the curve file I used here.
Step 10
Now we need to make a selection of the hair. I used the path that I saved from Step 1. Then I modified it a little to line up with the hairline's shape and softness. I did this by using Quick Mask Mode(Q), and using brushes of various sizes and softness to match the hairline.
Make a new Gradient Map adjustment layer at the top of the "girl" group. Make the gradient a similar to the image below. I left the blending mode at Normal for this layer.
Step 11
Make a selection of the shirt. Then make a new Gradient Map adjustment layer. Hit OK and set the blending mode to Color, as we have done before. Edit the gradient so that it looks something like the one below. You will have to play around with the gradient until you get a good separation between the green and white stripes.
Step 12
Choose a Sky image. I used one I shot myself, but there are plenty of stock images you could use. Bring it into the document below the "girl" group. Hit Command+T, and size it to fill the frame. It looks good, but notice that our hair mask still isn't really looking that good against the blue background. The hair turns a muddy gray in the transition between hair and sky. To fix this, make a new blank layer just above Layer 0 (the image of the girl). With a large and soft black brush paint over those areas with an Opacity of 15-25% until the transition looks better.
As an added bonus, I applied the techniques from the Super Quick and Easy Facial Retouching tutorial to smooth out her face a little bit. As you can tell, I decided to make her red haired, but you can make your gradients whatever color you would like. She just seemed like a redhead to me. Here is the final image.
Enjoy this Post?
We'd love your vote!
User Comments
( ADD YOURS )
  1. Mike William May 1st
    Awesome tutorial.
    Learned some techniques. Good outcome.
  2. sarah May 1st
    wow…great tutorial. Thanks for sharing!
  3. Razvan May 1st
    Good stuff, thanks!
  4. Doug Neiner May 1st
    Great tutorial. Like the detail and the methods!
  5. Andrei Constantin May 1st
    perfect one
  6. Craig Schlewitz May 1st
    This is possibly one of the most amazing things I’ve seen on the site so far.
    Love it.
  7. Nate May 1st
    Really nice tutorial, thanks.
  8. Tyler Bramer May 1st
    Amazingly fast technique to color a black and white image!
  9. LOSWL May 1st
    Excellent, Excellent tutorial, the technique I learned in school was close but not as easy, this is way easier and looks like a better outcome, thanks!! :o)
  10. I have a tutorial like this written. But not like this. This one is better. ;)
  11. Jad Graphics May 1st
    Great post! I always wondered how to this… Now I can finally apply this technique.
  12. Jared May 1st
    This is a fantastic tutorial. One of the most well written and technique-full that I’ve seen. Keep up the great work Kyle!
  13. scmtngirl May 1st
    That’s pretty amazing. Great tutorial.
  14. ZaFaR May 1st
    AWESOME AWESOME, GREAT, TREMANDOUS ,EXCELLENT,FANTASTIC.ONE OF MY MOST LIKE TUTORIAL HAS COMES IN, VERY VERY THANKS FOR SHARING, AMAZING SITE, AMAZING PEOPLE, AMAZING WORK, WONDERFUL TALENTED MIND, KEEP IT UP TO KYLE PERO, AND ALL……….
  15. Lamin Barrow May 1st
    WOW.. thats amazing stuff. I have never thought it was possible to make a colored version out of a black and white photo but now i know. My sincere thanks to you Kyle. :)
  16. Ben Griffiths May 1st
    Amazing result and fantastic tutorial, many many thanks!
  17. Christian Mejia May 1st
    This one will surely make my grandmother happy once I bring back life to her old photos!
  18. glsmaster May 1st
    Awesome… this is huuuuge!!! (:
    Thanks for this! ^_^
  19. goldenthunder May 1st
    so cool!!!! i love it! thanks!!!!
  20. giackop May 1st
    very cool indeed!!
  21. Snorri3D May 1st
    just a fantastic and well written tutorial and a great technique.
    THX :D
  22. Wow, I didn’t even know it was a colored B&W pic at first. Great job!
  23. Mason May 1st
    Nice job man. There’s lots of potential with Curves and Fill Layers.
  24. Fachia May 1st
    Her face becomes so silk and soft. Great tutorial ..
  25. Danny May 1st
    Simply a great tutorial, thanks a lot man!
  26. Colin May 1st
    excited! can’t wait to try it!
  27. Gleb May 1st
    Excellent.
    Great Tutorial. Thanx a lot.
  28. now this is enhance example
  29. vidya May 1st
    please elaborate ths apply the selection as a mask on the girls layer?
  30. vidya May 1st
    i understand ,now no prob….. m trying…
  31. D. Carreira May 1st
    THANKS!!! Another great tutorial!
    David Carreira
  32. Shane May 1st
    To be honest, this isn’t something I can see myself needing to do in the near future (I’ve said *that* before though!).
    I’m amazed at the quality of the final colour image - is there anything photoshop can’t do?
  33. xavier May 1st
    IN-CRE-DI-BLE!!
  34. Daniel May 1st
    Wow :-o
    Daniel
  35. Jesús May 1st
    Great tutorial.
    Thanks!!
  36. César "cche" May 1st
    Nice tutorial, my first try:
    http://img146.imageshack.us/img146/8681/bellbv5.jpg
    keep the good tutorials coming :)
  37. Dain May 1st
    wow, it is very good. really nice i think
  38. Ariful Khan May 1st
    Simply Great. Thanks
  39. kailoon May 1st
    this is amazing … wow..
  40. JPH May 1st
    Awesome.
  41. Soelberg May 1st
    Such an awesome tutorial.. It have really made me figure out how to do this in a even prettier way than i used to.. Thanks for this lovly tutorial :D
  42. Kortnee May 1st
    Sigh! I wish I had checked the site before I did my Digital Imaging final, one of the components was to color a black and white image, mine sucked, comparatively!
  43. You rock :)
  44. Stanley May 1st
    There are several ways to do this and this is a good one
    thanks
  45. Nitin May 1st
    Wow! That’s a totally new way of colorizing a photo that I have learnt today. Thanks a ton for sharing!
    Cheers.
  46. Terry May 2nd
    i would imagine, shane, that some of this could be used for color replacement schemes in ad building too?
    just a thought.
  47. Josh May 2nd
    I’m looking for a site with more of this type of info. anyone know of any!
  48. pixlpusher May 2nd
    Absolutely great tutorial!
  49. Great tut. I was already familiar with a lot of this, but I saw a few other techniques in there as well. ;)
  50. Josh May 2nd
    WOW! When I first saw the before/after picture, I assumed you just found the color version, then made it b&w… Very well written tutorial with a great result.
  51. Thats a cool technique of coloring in photoshop. I can really put this to use at work.
  52. Grafiko May 2nd
    Very nice, the selection of the hair is very good, thx fot this tut.
  53. Daniel May 2nd
    great job! very nice technique !
  54. Josef May 2nd
    awesome! can’t wait to trying this out when i get home…
  55. Iris May 2nd
    WOW!!!!
    incredible, really! thanks very much for sharing.
  56. olivier lalin May 2nd
    Discoverig the site and it ROCKS!
  57. Fynn May 2nd
    Wow, this looks really cool! Can’t wait to start on it this weekend.
  58. Martin May 2nd
    Can’t wait to do this! Awesome
  59. Pitrus May 2nd
    If i want the girl’s photo without background to follow much easier the tutorial, do i need to join “psd tuts plus”??
    Bye Dude..
    jazznoise AKA Pitrus
  60. Joefrey Mahusay May 2nd
    Wow great tutorial. I like the finish product.
  61. Bob May 2nd
    Final product looks great but who wrote the tutorial? Jee whiz! Mighty confusing at times.
  62. Qbrushes May 2nd
    thanks
  63. therapix May 2nd
    Good work!
  64. Ali May 2nd
    really cool
  65. jesse May 2nd
    very helpful stuff
    jesse wright photography
  66. Nunis May 4th
    That is one of the coolest Photoshop tutorials I have ever seen.
  67. Jenny May 5th
    that’s pretty nifty.
  68. Kanna May 6th
    wow,looking for this for sometime
    thanx for the tutorial,i am learning a lot from the site
    thanx again keep up
  69. Great job. These tutorials on your site really help a newbie in digital slr camera photography like me, to enhance my photography works. Thanks a lot.
  70. Sophie May 7th
    This tutorial is nowhere near specific enough for beginners..
  71. Jdonner May 7th
    Nice, but realistic skin color? No.
  72. Oakeem May 8th
    I’m not to evaluate this excellent tutorial, so impressive indeed. I’m trying to find my way through this and I’d really appreciate it if you could just give me some detailed steps about paths; saving and applying’em. Thanks a million in advance.
  73. designtrends May 9th
    Cool good stuff, thanks!
  74. Andrew D May 9th
    Great tutorial, one of my favs on the site thus far!
  75. Mido May 10th
    Wow .. It’s wonderful .. Thanks dear :)
  76. Cizan May 11th
    WoW!
    Very Fantastic
    Really Fantastic
  77. rosevirus1990 May 15th
    very good you idea, You are good tincique
  78. Dynsy May 21st
    I dont get it can you make the tutorial more simpler please?? like saying exactly what buttons to pree..
    I am really very new to photosoph and will appreaciate the help
  79. Rodrigo (Brazil) May 23rd
    Sensacional! Explêndido! Magnífico!
  80. Nicholas May 23rd
    I can’t belive it…you explaiined it so simply that even a newbie like me was able to understand…
    I have just joined and yours is the first tutorial I have seen. I don’t know about the rest of material, but this was really amazing….
    Much appreciated.
    Nick
  81. pHeR-d May 29th
    Really amazing!!
  82. menteil June 23rd
    great tutorial!!
    thanks..
  83. ashley June 23rd
    yeah im not really understanding all of this photoshop jargon. i need the lesson to be a little more simpler. i’m definitely lost at just step 3! my hair won’t show up…
    please help!
  84. Max June 26th
    thank you!!
  85. Vlad July 4th
    Best tutorial about photo editing/enhancing i’ve seen this year , and it still is nr 1 .. awesome work and very good detailed tutorial . hat’s off m8
  86. Robin July 5th
    I’m not a beginner, but I had a hard time following this tutorial. It could definitely use a lot more specifics.
  87. Santa Clause July 10th
    Hey Einstein, next time try to make it a bit more understanding. Very inacurate tutorial though, what if the picture is not this exact photo, then what? Different lighting conditions, different colors???
  88. starlight July 10th
  89. Mansoor July 24th
    Thanks for Posting.
    Great Tut.
  90. zvonko August 16th
    THE BEST TUT ABT PHOTO MANIP I HAVE COME ACROSS…I AM INSPIRED FOR A WEEK NOW :)
  91. zaloo00 August 29th
    hi Kyle ! Great Tut
    i have a question.
    how do i select “red copy” channel in curves channel
  92. dave October 5th
    I dont think i will be able to that. it’s just too much
  93. lateef October 18th
    great i luv it do u av video version of it that one can watch over and over again
  94. May Tove October 20th
    Great, thank you.
  95. brent November 28th
    Been looking through tutorials all day and these are perfect.
Add Your Comment
( GET A GRAVATAR )
  • Gravatar
    Your Name December 1st
Arrow
