A few weeks ago a friend of mine had published an article on my blog about Light painting. I was really impressed by all the effects these guys can create taking photos with long exposures. Then I thought it would be a nice idea to do that in Photoshop. So in this tutorial I will show you an easy, and very fast way, to create a light painting in Photoshop.
Create a new document and place the photo, you can download the one I used at: Photo 1.
Here I placed a second image. I will use it to create the light effects. Here is the link for the next image: Photo 2.
With the Pen Tool(P), create a path for one of the figures.
Select the Brush Tool(B) and go to Window>Brushes or F5 to create our brush. Use 8px for the diameter and select Dual Brush and Other Dynamics. Follow the image below for reference.
Go to the Layer Palette, create a new folder, and rename it to lights. After that create a new layer inside this folder, name it "dude", and select it.
Go to the Path Palette and select the first path. Then with the Path Selection Tool(A), select the path and right-click. Choose Stroke Path. A dialog box will open; select the brush and use Simulate Pressure.
After that go to Filter>Blur>Gaussian Blur, use 1.6px for the amount.
Duplicate the "dude" layer three times.
Select the Rectangle Tool (U) and create a rectangle. Then duplicate the rectangle several times. After that align and distribute them horizontally.
Create a new layer inside the lights folder. Rename it to "xing". Repeat Step 6 and Stroke the paths. After that select the "xing" layer and go to Edit>Transform>Distort. Now just move the vertices until the perspective is good—just follow the street lines.
That's probably the easiest way to create this type of light effect; however, it depends on the color of the background. If the background is too dark, the blend mode won't work. You'll probably have to use another one with an Outer Glow.
You can make the lights brighter by just duplicating the layers. You can even use the Eraser Tool(E) to make some adjustments. The original concept image can be viewed at Light Graffiti In Photoshop. The final tutorial image is below.
User Comments
( ADD YOURS )Rich April 30th
Nice!
Has.n April 30th
Cool one its very useful for other effects!!!! Thanks man!!
Sean Hodge April 30th
The original concept Fabio submitted to us has a higher cool factor, but we decided not to use the Beatles image due to copyright issues. You can see the original concept on Fabio’s site. Thanks Fabio for working through the copyright issues with this tutorial. Good job. Thx.
NESC April 30th
Simple nice work
Seraphim Collective April 30th
NICE!! I can see a plethora of ideas coming out of this technique.
Godonholiday April 30th
wow, well done covering the copyright!! This is nice, but the original photo was so good to start with its going to be hard to make this my own! hahah i nice challenge though. great work.
Nick April 30th
I’ve done this with real photography, but it’s awesome to know how to translate that into photoshop! Great job! Thanks!
D. Carreira April 30th
Another great tutorial with the quality of PSDTUTS.COM!
Thank you very much!
David Carreira
Ben Griffiths April 30th
Cool effect, thanks!
pica April 30th
very cool effect
im just surprised by the copyrigth issue, i know it’s a big one but i didnt think the first attempt was that close…
anyway nice one
one thing:
i almost didn’t find the blending mode used on the brush, i can imagine some people might not read it and wonder why it wont work
… and some might not know you can use it on a brush
Brent April 30th
This has been done in the glow tutorial
1984 April 30th
Good !
Markus April 30th
Yes! I was waiting for this ;)! Easier than i thought, but still nice!
Daniel April 30th
Why we had to create a path for each one of the figures when we duplicate the first dude layer 3 times
Daniel
Harry April 30th
Awesome tut
danneil April 30th
not very cool…
i love all fabio’s tutarial but this one is just too simple and not cool…
Fabio Sasso April 30th
@Daniel, Sorry that was my mistake… it’s not necessary to create a path for each figure…
Thanks
Bruno Mendoza April 30th
Very, very nice!!!
Basic elements can make awesome effects. Sometimes, I think as I did not think before about this. It’s so logic…
Fabio is a greatest design!
@Daniel & @Fabio - I edited Step 3. I think that fixes the issue. Thanks.
riq pepino April 30th
i dont understand step 4,5,6… need explaination
Razvan April 30th
Nice effect, good work Abduzeedo!
LOSWL April 30th
This is sweet!!..I can see me using this technique in many ways, thanks!! :o)
Danny April 30th
Very nice effect! I really like it
Grafiko April 30th
realy nice, and easy
Joe April 30th
weird but cool tut, thanks!
giackop April 30th
Cool!!
Constantin Potorac April 30th
Hah… that was really easy. I love it. You have such an artist mind :))
Wouter April 30th
Hot tutorial nice outcome nice idea
Greetz
Lamin Barrow April 30th
Amazing and inspirational work as always Fabio. Thanks for all the time and effort.:)
Rom April 30th
I love this tut!!! thank you Fabio
Qbrushes April 30th
nice outcome.
Nate April 30th
Score!
Snorri3D April 30th
nice one and also great to have this kind of tutorial again.
can April 30th
ohh super and nice
goldenthunder April 30th
way cool - thanks fabio
Terry April 30th
fabio!!!
enter the tutorial writer job thing!!!!
K3v April 30th
Really cool to see how easy it is to achieve this effect…
Well done Fabio!
eli April 30th
It’s easir to make the real thing, but can be usefull, thanks
James April 30th
Wow. amazing, always looking forward to your tutorials man
the picture reminds me too much of the Abbey Road album
MONSTER April 30th
Clever!
Bobsandor April 30th
I was a little confused on this one too.
1. I couldn’t seem to finagle my brush to look the same as shown in step 4, like how it tapers. I did confirm each and every setting was the same. Although I did have to select a different but slightly similar secondary brush.
2. I didn’t see where the brush color was specified.
3. I didn’t see where the blend mode for the dudes was specified.
I played around and found that a yellow color with Color Dodge kinda did the trick, but I didn’t get the fading that Fabio got.
Hopefully someone can help.
Joefrey Mahusay April 30th
Awesome. Thanks a lot Fabio.
glsmaster April 30th
Pretty cool tut dude.
Cheers Fabio!!!
Website Design April 30th
Great and Unique tutorial!
LouieP April 30th
cool, but i got a problem on step 4, about the dual brush :p
Dr. Dirty Mind April 30th
Oddly cool. I so wasn’t expecting that as a tutorial.
Jonathan Solichin April 30th
Nice, that’s one cool effect. Good job as always Zee
jeff April 30th
Hi,
Thanks for the tut,
I have a problem when I try to add pen pressure, It doesn’t work for me.
I use CS3 Extended and installed wacom.
How can I solve it?
Regards
Aminur Rahman [aka Tom R] April 30th
nice
arnaud April 30th
Thx fabio
Daniel April 30th
very cool one ! thank you for this nice tut!
Shane April 30th
Great effect - thanks for posting.
mbithi April 30th
Thanks Fabio!Excellent tut once again!
Elodesign April 30th
I have a big issue on this tut step 6 : my Stroke Path is WHITE (the foreground color in the example), I don’t have this kind of overlay color mode ….
I have to choose afterwards the overlay color mode for the dude layer and duplicate it to get something just OK …
And YES I do have the color burn set for the dual brush, and I checked 10 times ALL the steps, so … what do I do wrong ?
Thx to help me …
jonasbmf April 30th
nice tut, but i got a problem on step 4 on the dual brush too.
Sam April 30th
Super nice!
KillaBoY April 30th
i like it!
Martin April 30th
not really cool!
André Sugai April 30th
which blend mode you used to create the effect in step 6? congratulations on tutorial!
Josh May 1st
another great effect!
Adil May 1st
how did the dude layer got brifhter and brighter as u went along, pls explin tht step agin more clear like the colour u used, the blending mode used!
fantastic tutorial after all
regards
adil
aGS May 1st
Is the first time that I see here something like.. “very cool and very easy to follow” and then “Which blend mode is this guy using” or “I’m lost with this and this”… LOL
Andrew D May 1st
Awesome I love this effect!
ZaFaR May 1st
Great! Like it Interesting keep it up fabio, thank for sharing.
Jad Limcaco May 1st
Great Tutorials, like always. I will try to incorporate this into one of my designs.
Jad Graphics
Constantin Potorac May 1st
I love you tutorials Fabio. Keep them coming
Siva May 2nd
V.Cool!
Phodana May 3rd
Looks cool… thx
Ivan May 3rd
This is wicked! Going to give it a try right now!
Hell May 4th
Could you Update the tutorial with the infos that some people have asked up this coment ??
Layer mode, color, etc…
The effect NEVER gets like yours because you’ve didn’t explained it soo good.
Fabio Sasso May 4th
@hell I’m sorry for that, I simply forgot the most important thing, the blend mode for the Lights folder, use COLOR DODGE, the rest remains the same
Blame May 5th
which brush do we use? i dont have that brush.
aznmonk May 6th
I also do not have the brush that you use, could you please supply the brush or give us a link on where u got it? Thank you.
Selya May 6th
Hello Fabio, thank you for a great tutorial! but I also curious about brush question above:)
Mohammad May 7th
Thanks Fabio …
we are waitting more from your creative !
Hell May 7th
@Fabio
Thanks for that, now it gets similar to your result.
Jauhari May 7th
Perfect Tutorial
DarkMonk May 14th
Thanx a lot, cool tutorial, but please update this tut with missing stuff about chosen color and blending modes - these are most confusing parts, yet most important.
Scorpiono May 16th
Hot stuff!
Fabio Sasso May 20th
@blame - you can use a basic brush, but make sure and use 0 for hardness, or you can apply a Gaussian blur as well.
Thanks a lot for the comments.
RUGRLN May 20th
Could u plzzz explain how to get the brush, I can’t get that faded effect on sides.. Other than that, great tutorial!!
Mathiasa May 22nd
The same effect can easily be created with a camera and a flashlight!
christiant May 31st
Nice work buddy, I used this for a project it came out awesome man, this effect works great with so many applications. All around great TUT,
-Christian
smartguy June 1st
I’m stuck at part 4, i don’t see any options to set a brush like that. I am using CS3 xtended but i don’t how he setup that brush ? but nice tutorial.
sb179 June 11th
great brother, i want to learn lots of thing about photoshop. Can u help me???
sb179 June 11th
great brother, i want to learn lots of thing in photoshop. Can u help me???
anonymous July 2nd
This tutorial is really vague, especially the brush part. You don’t even say color the brush should be. That’s kinda essential stuff in a tutorial.
Alex July 11th
woow esta genial! muchas gracias esta increible, lo intentare, saludos desde mexico.
Mansoor July 24th
Thanks for Posting.
Good Tut.
Matt R. July 29th
For anyone struggling to create the brush I just opened the download on the bottom of this page : http://psdtuts.com/tutorials-effects/advanced-glow-effects/
and selected the glow layer and copied its layer style.
Next I pasted the layer style into my dude layer and it appeared pretty similar.
Nate July 29th
Did you pay him for this tutorial? It’s lacking essential information, as a lot of people are having trouble. you should assume that everyone reading this is a complete photoshop newb. How do you get the tapered brush? I set hardness to zero, applied all the settings you are using, and the brush is a solid width the whole way through.
kevin August 26th
dude. i cant do this thing on cs2.. huhuhuhuhuhuhuhu…
loon September 7th
dude. you have the most ridiculously ingenious tutorials ever.
you are god.
mithun September 18th
Verry nice
beta November 16th
The brush in Step 4 is in the Assorted Brushes load it into your brushes and click Append. I am confused about the chosen brush colour. Great tutorials, thanks so much.
Add Your Comment
( GET A GRAVATAR )Your Name December 1st
Trackbacks
