GiveUpAlready.com
Go Back   GiveUpAlready.com > Entertainment > Art > Art Tutorials
Notices
Reply
Thread Tools Display Modes
Old 28th May 2008, 05:10 AM   #1
Shards
blackisbackisbackisback
Member
Shards's Avatar
GUA Level: 46
HP : 2/146099
MP : 1/181047
PP : 1/81932
EXP: 94%
Commitment: 50%
Element: Spirit Spirit
Rep Power: 9 Shards has a spectacular aura aboutShards has a spectacular aura aboutShards has a spectacular aura about
Send a message via MSN to Shards
Rain, Rain, Go Away: Photoshop Tutorial
This tutorial will teach you how to add a rain effect onto a particular image. I will be going through a few old and well known techniques that when put together can create a convincing rain effect.
We will be using this image by Kevin Beyrit, 2004:
Let's begin with the raindrops.
1. Create a new photoshop document of height: 200px Width: 400px.
2. Make your main colour on your pallete black and fill background layer.
3. Create a new layer over that.
4. Go to brushes and make sure it is on airbrush (has soft edges). Change the pen weight to 9.
5. Paint a single dot towards the left of the image.
6. Go to Filter > Stylise > Wind.
7. Repeat this five times times, or press [CTRL F] five times.
8. Go to Filter > Blur > Motion blur. Set Angle to 0 and Distance to 25 pixels.
9. Press Edit > Free Transform or CTRL T and rotate so that the rain drop is about 70 degrees to the ground plane.
10. Press Ctrl + I to inverse the image.
11. Press Ctrl + A to select the entire image.
11. Go to Edit > Define Brush Preset.
12. You now have a raindrop brush.
Adding an effect to the background
Now go back to the image of the werewolf. We need to prepare the background and either make it blurred or give it a light texture. For this particular picture, we will make a very simple rain effect.
1. Make a new layer above the picture.
2. Go to Filter > Render > Clouds.
3. Go to Filter > Noise > Add Noise.
4. Go to Filter > Blur > Motion blur.
5. Turn the blend mode to 'vivid light'.
6. Take the opacity down to 30%.
After experimenting with the Noise and Blur settings, I got something like this:
Darkening the image
Now for the sake of making this picture look more dramatic we will modify some of its tones.
1. Go onto the picture's layer.
2. Press CTRL L.
3. Change according to image:
Now we add the rain onto the image.
1. Go to the Brush Tool and look for the rain brush you created before in the Brush Palette.
2. Select Shape Dynamics in the Brush Palette.
3. First lets begin with the midground rain.
Under the Brush Presets Tab, change the master diametre of the brush to 90.
In the Shape Dynamics tab, change the Size Jitter to 50% and Angle Jitter to 1%
In the Scattering tab, change the Scatter: 1000%
Brush all of that on as desired.
Then turn the layer opacity to 50.
6. Next is the foreground rain. Change the master diametre of the brush to 180-250.
Size Jitter: 100%
Angle Jitter: 1%
Scatter: 1000%
Brush that on as desired.
Now for the best part....
1. Spashes can be created by selecting a 1px brush with a white colour.
2. Go to the Brush Palette.
3. Change these settings:
Scattering 1000%
Space: 580%
4. Now begin to brush it onto the fur. Direct splashes need to be more defined with a higher opacity. Light splashes need to have a lesser opacity. Change the spacing of the dots for indirect splashes, for example where the water is lightly covering the fur. Some splashes can be thrown into the air as if the werewolf is in movement. Be creative, every picture will require different brushing applications.
Light is the most important factor to consider in showing water, especially during the night. Water also flows downwards (crazy huh), so where water culminates and drains off, show this with more dense dots.
Add a colour balance over it to make it bluish.
1. Go to the bottom of the Layers window to the circle with half white and half black. Then go to Colour Balance...
2. Slide the bar slightly towards blue as desired.
And there we have it: a werewolf in the rain.
For even more dramatic effect, some hot mist could be added to come out from his nose and mouth and some highlights can be added on parts of the fur. This is what I got:
Shards is online now View Shards's Photo Album   Reply With Quote
Old 28th May 2008, 09:31 AM   #2
eth
rudely awakened
Member
eth's Avatar
GUA Level: 78
HP : 0/127784
MP : 0/347942
PP : 0/163196
EXP: 7%
Commitment: 50%
Element: None None
Rep Power: 13 eth is just really niceeth is just really niceeth is just really niceeth is just really niceeth is just really nice
Send a message via MSN to eth Send a message via Yahoo to eth
Active IMG tags would've made that so much easier to follow. Nice tutorial, though. Nothing groundbreaking, but it's easy to follow and pretty useful.
eth is offline View eth's Photo Album   Reply With Quote
Old 30th May 2008, 09:20 AM   #3
Shards
Member
Shards's Avatar
GUA Level: 46
HP : 2/146099
MP : 1/181047
PP : 1/81932
EXP: 94%
Commitment: 50%
Yay for image tags.
Yeah thx for the comments eth. The tute isn't anything new, more of a reaction to the many many crappy, unrealistic rain tutes out there. This should be an improvement.
__________________
Old 30th May 2008, 04:02 PM   #4
Nesuke
Senior Member
Member
GUA Level: 54
HP : 0/64807
MP : 0/166199
PP : 0/93031
EXP: 46%
Commitment: 50%
Element: None None
Rep Power: 9 Nesuke will become famous soon enough
I think this is a P2L tute. I think shards should try to submit this.
Also: How come there are more than 5 image files showing up in this thread? It won't let me do that.
This is my attempt, exept my stock brush was slightly different. I had to make a set of angled rain shoots to suit this banner.
Nesuke is offline View Nesuke's Photo Album   Reply With Quote
Old 7th June 2008, 06:41 AM   #5
RazoR_
Mysterious
Member
RazoR_'s Avatar
GUA Level: 39
HP : 0/31571
MP : 0/77814
PP : 0/48471
EXP: 57%
Commitment: 50%
Element: None None
Rep Power: 8 RazoR_ is on a distinguished road
Send a message via MSN to RazoR_
Seen my share of rain tutorials out there... must say that yours cuts the cake when it comes to realism. though I think you darken a bit too much of the background when changing the levels when you're adding your rain to the background (imho). Good job and tut none the less.
__________________
RazoR_ is offline View RazoR_'s Photo Album   Reply With Quote
Old 7th June 2008, 10:26 AM   #6
GekkoPixie
Big Musical Number
Member
GekkoPixie's Avatar
GUA Level: 67
HP : 0/0
MP : 0/0
PP : 0/0
EXP: 73%
Commitment: 56%
Element: None None
Rep Power: 11 GekkoPixie has a spectacular aura aboutGekkoPixie has a spectacular aura about
This really does seem like the best rain tut I've seen. I mean, most of them don't take the render into account at all. RazoR_ said it best, but I echo his sentiments.
__________________
MAT 5:44-45 "But I say to you, love your enemies, bless those who curse you, do good to those who hate you, and pray for those who spitefully use you and persecute you, that you may be sons of your Father in heaven; for He makes His sun rise on the evil and on the good, and sends rain on the just and on the unjust."
GekkoPixie is offline View GekkoPixie's Photo Album   Reply With Quote
Old 10th June 2008, 05:38 AM   #7
Nesuke
Senior Member
Member
GUA Level: 54
HP : 0/64807
MP : 0/166199
PP : 0/93031
EXP: 46%
Commitment: 50%
Element: None None
I want to know how it got so many views. I submitted mine to StumbleUpon and nothing's happened. Maybe it depends on who's submitted it? Or when?
Old 20th June 2008, 11:57 AM   #8
Disasterpieces
Senior Member
Member
Disasterpieces's Avatar
GUA Level: 42
HP : 0/33729
MP : 0/83562
PP : 0/51355
EXP: 31%
Commitment: 50%
Element: None None
Rep Power: 8 Disasterpieces is on a distinguished road
Send a message via MSN to Disasterpieces
This is a really nice tut, and I will definintely be using it sometime soon. Most realistic rain tut that I've seen, well done!
Disasterpieces is offline View Disasterpieces's Photo Album   Reply With Quote
Old 22nd August 2008, 11:43 PM   #9
Hodagz
Junior Member
Member
GUA Level: 2
HP : 0/45
MP : 0/136
PP : 0/46
EXP: 81%
Commitment: 50%
Element: None None
Rep Power: 0 Hodagz is on a distinguished road
Here is my version
I used some of your techniques as well as some of my own...and this is what I came up with...
http://viewmorepics.myspace.com/inde...ageID=10340846
Last edited by Hodagz; 22nd August 2008 at 11:49 PM. Reason: Still no image is showing up
Hodagz is offline View Hodagz's Photo Album   Reply With Quote
Old 23rd August 2008, 12:35 AM   #10
Shards
Member
Shards's Avatar
GUA Level: 46
HP : 2/146099
MP : 1/181047
PP : 1/81932
EXP: 94%
Commitment: 50%
Interesting work Hodagz, thanks for sharing. Did you find the tutorial easy to follow?
For the claw, maybe have the water build up and pour down, like this?:
__________________
Reply
Bookmarks
Tags
tutorial
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
