This site was last updated:Monday 13 October 2008, 11:30 GMT
Educational Community
INTRODUCTION TO OPEN GL
(2 votes, average: 3.00 out of 5)
Written by Christopher
Thursday, 12 June 2008 18:24
WHAT IS OPENGL?
OpenGl is an API similar to direct3D. However, OpenGL (Open Graphics Library) is not supported by Microsoft and is a cross-language, cross-platform API used for writing applications that produce 2d or 3D graphics. Over 300 functions are implemented in this API which can help you draw complex 3D scenes from primitive data such as polygons and triangles. Mesa 3D is an open source library API which is also compatible with the OpenGl protocol. OpenGl aims at two key goals:
  1. To present to the programmer a uniform API that hides the complexities of interfacing with different 3D accelerators.
  2. To hide the different capabilities of hardware platforms.
OpenGL converts primitives into pixels that are depicted on your screen. Primitives can be polygons, triangles or lines. The transformation is accomplished by a graphics pipeline.
OPENGL BASICS
As mentioned, OpenGL is a library for rendering computer graphics. Generally,
there are two operations that you do with OpenGL:
• draw something
• change the state of how OpenGL draws
OpenGL has two types of things that it can render: geometric primitives and image primitives. Geometric primitives are points, lines and polygons. Image primitives are bitmaps and graphics images (i.e. the pixels that you might extract from a JPEG image after you’ve read it into your program). Additionally, OpenGL links image and geometric primitives together using texture mapping, which is an advanced topic. The other common operation that you do with OpenGL is setting state. “Setting state” is the process of initializing the internal data that OpenGL uses to render your primitives. It can be as simple as setting up the size of points and colour that you want a vertex to be, to initializing multiple mipmap levels for texture mapping.
A typical OpenGL procedure is the following:
1) Choose the type of window that you need for your application and initialize it.
2) Initialize any OpenGL state that you don’t need to change every frame of your program. This might include things like the background color, light positions and texture maps.
3) Register the callback functions that you’ll need. Callbacks are routines you write that GLUT (OpenGl implementation) calls when a certain sequence of events occurs, like the
Window needing to be refreshed or the user moving the mouse. The most important callback function is the one to render your scene.
4) Enter the main event processing loop. This is where your application receives events, and schedules when callback functions are called.
CALLBACKS
GLUT uses a callback mechanism to do its event processing. Callbacks simplify event processing for the application developer. As compared to more traditional event driven programming, where the author must receive and process each event, and call whatever actions are necessary, callbacks simplify the process by defining what actions are supported, and automatically handling the user events. All the author must do is fill in what should happen when. GLUT supports many different callback actions, including:
glutDisplayFunc() - called when pixels in the window need to be refreshed.
glutReshapeFunc() - called when the window changes size
glutKeyboardFunc() - called when a key is struck on the keyboard
glutMouseFunc() - called when the user presses a mouse button on the mouse
glutMotionFunc() - called when the user moves the mouse while a mouse button is pressed
glutPassiveMouseFunc() - called when the mouse is moved regardless of mouse button state
glutIdleFunc() - a callback function called when nothing else is going on. Very useful for animations.
Trackback(0)
Comments (0)add comment
Write comment
quote
bold
italicize
underline
strike
url
quote
quote
smile
wink
laugh
grin
angry
sad
shocked
cool
tongue
kiss
cry
smaller | bigger
busy
User Menu
None
Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor KNOGE.com offers free video and text tutorials on various softwares also free resources to improve your economy and start making money online. THIS IS ONLY A TEST AD TO DISPLAY HOW IT MIGHT LOOK Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor Become a sponsor
Adobe InDesign CS3 - Working with objects
Objects in Adobe InDesign CS3 are the basic building block of any design that you do. In this video tutorial you will learn how to create those blocks easily in...
InDesign Videos | Christopher
Read More
Adobe InDesign CS3 - Working with Panels & More
In this Adobe InDesign CS3 video tutorial you will learn how to set keys and work with panels, you will also learn how to create customized keyboard shortcuts for optimized...
Read More
Adobe Photoshop CS3 - Create customized rust on cars
This Adobe Photoshop CS3 video tutorial will teach you how to create your own customized rust on cars for a more grungy and perhaps dusty effect. This technique does also...
Photoshop Videos | Christopher
Read More
100%
3
Show options
