Photoshop Tutorials | Photoshop Contests | Photoshop Forums
Go Back   Photoshop Tutorials | Photoshop Contests | Photoshop Forums > Member Photoshop Tutorials
CLICK HERE to become a member and see no ads.
Reply
LinkBack Thread Tools Display Modes
Old 06-14-2008, 03:45 PM   #1
tx51210
Old Bag of Crap
tx51210's Avatar
Diggs: 21
Strength: 44253tx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond reputetx51210 has a reputation beyond repute
tx51210's gallery
Awards Showcase
Weekly Contest 2nd Place Weekly Contest 2nd Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 1st Place 1st Place - Member of the Month Weekly Contest 1st Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place 3rd Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place
Total Awards: 26
Displacement Mapping and a little Masking
Displacement Masking is one of those things that sounds hard but when you go thru the steps you realize it really is not a big deal, but it can make some really cool effects. Here is the process I used to generate this chop. Sorry for the large quantity of pics, but there are a number of small steps.
I started with this source picture of the beautiful Angelina
To create a displacement map for her face I toggled to the channels tab and duplicated the channel that had the best contrast range (in this image the RED worked) Click the New tab and you can create a new image containing just the duplicated Red Channel.
Working on the new file we created - I first used the brightness and contrast tool to increase the contrast 100% (not shown) and then I added a slight Gaussian Blur to the image as shown.
Important - Save the new file we created as a .PSD file so you don't loose the information. I called this the AJ-DisplacementMap.PSD and saved it to my working directory.
Close the AJ-DisplacementMap.PSD file and you should still have the original source file open. Working in the original file, I placed the image of the fabric that I want to apply the displacement map. It is located on a layer just above the original photo. Go to the FILTER menu and select DISTORT and the DISPLACE and you should see this Dialog Box.
Click OK and you will be asked for a file to use as a Displacement Map. We choose our AJ-DisplacementMask.PSD file.
The result will look something like this.
I changed the fabric layer's blend mode to Overlay (some images may work better with different blend modes - experiment).
Now I want to mask. I turn Off the Fabric Layer and toggle to the Channel Menu. I duplicate the Channel with the most contrast between background and the subject and then lowered the Brightness and increased the Contrast.
I then used the BURN tool set to SHADOWS and a large soft brush to convert the mask to black and white and omit all the detail on the face.
I used a black brush to paint out the whites of the eyes and any stubborn highlights on the face and converted the mask to a selection. (Control Click on the layer or pick the selection tool at the bottom of the layer menu)
You will need to inverse the selection. I then changed to the layer menu and selected the Fabric layer and with the inverted selection active, I picked the layer mask tool on the bottom of the layer menu and the selection became a mask to hide the background.
Here is one of the great things about working with masks. Since I now realized that I want her eyes to be masked I go back to the layer mask and paint white over the eyes and other areas till I am satisfied the fabric only appears where I want it to be. I can add and subtract from the mask without damaging the original or the displacement map.
The final result
__________________
"A government big enough to give you everything you want is strong enough to take everything you have." - Thomas Jefferson
tx51210 is online now
Sponsored Links
Old 06-14-2008, 03:46 PM   #2
joshbond
Admin
joshbond's Avatar
Diggs: 19
Strength: 100000joshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond repute
Send a message via MSN to joshbond
joshbond's gallery
Awards Showcase
Weekly Contest 3rd Place 3rd Place Tutorial of the Month Head 2 Head Contest Winner Weekly Contest 1st Place Post whoring award Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 1st Place
Total Awards: 10
Awesome!
joshbond is offline
Old 06-14-2008, 09:59 PM   #3
PottieMouff
Senior Member
PottieMouff's Avatar
Diggs: 0
Strength: 313PottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond reputePottieMouff has a reputation beyond repute
Send a message via MSN to PottieMouff Send a message via Yahoo to PottieMouff
PottieMouff's gallery
Awards Showcase
Total Awards: 1
i always forget about displacement mapping
PottieMouff is offline
Old 06-15-2008, 03:37 AM   #4
thediceman
uber-mod
thediceman's Avatar
Diggs: 0
Strength: 100000thediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond repute
Send a message via Skype™ to thediceman
thediceman's gallery
Awards Showcase
Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 1st Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 3rd Place 2nd Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 1st Place Head 2 Head Contest Winner Weekly Contest 2nd Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 1st Place Weekly Contest 1st Place Weekly Contest 3rd Place
Total Awards: 34
wow thanks alot i just tried it and failed but i will try again when i can focus better it is alot easier to understand than most others
__________________
thediceman is online now
Old 06-15-2008, 04:37 AM   #5
tx51210
Old Bag of Crap
tx51210's Avatar
Diggs: 21
tx51210's gallery
Awards Showcase
Total Awards: 26
Glad you like it. I forgot to optimize the images for the web and just went back and resaved the files to medium quality so they are 2/3 smaller files and should load faster after the net propogates the new versions. Should open faster in the morning.
I did notice a mistake in the tute. I wrote that the blend mode was overlay instead of multiply for the fabric layer. The picture shows the blend mode I used but either could be used.
__________________
Old 06-17-2008, 03:41 AM   #6
FelixtheCat
Member
Diggs: 0
Strength: 15FelixtheCat is on a distinguished road
FelixtheCat's gallery
That is very cool. The fabric makes her skin so creepy.
FelixtheCat is offline
Old 06-20-2008, 04:30 AM   #7
SoliD
Noob
Diggs: 0
Strength: 11SoliD is on a distinguished road
SoliD's gallery
let me guess... you got this technique from Scott Kelby's Photoshop Channels book? Same thing
SoliD is offline
Old 06-20-2008, 04:34 AM   #8
tx51210
Old Bag of Crap
tx51210's Avatar
Diggs: 21
tx51210's gallery
Awards Showcase
Total Awards: 26
Actually,
Someone here asked for a tutorial on displacement masking and I had been inspired by work done previously by Pelican here on our site.
The displacement masking is pretty common stuff, but we try to make our own work for Photochopz. I have'nt seen Kelby's book, but I will check it out.
__________________
Old 06-20-2008, 04:38 AM   #9
joshbond
Admin
joshbond's Avatar
Diggs: 19
joshbond's gallery
Awards Showcase
Total Awards: 10
So Scott Kelby holds some kind of patent on all the tools and functions in photoshop?
Does this mean I have to send him a royalty check every time I use the pen tool? Do I need write him and ask for permission the next time I want to clone something?
joshbond is offline
Old 06-20-2008, 04:39 AM   #10
thediceman
uber-mod
thediceman's Avatar
Diggs: 0
Awards Showcase
Total Awards: 34
yeah im still having alot of trouble with this but im working on it ill get it.
__________________
Old 06-20-2008, 04:41 AM   #11
tx51210
Old Bag of Crap
tx51210's Avatar
Diggs: 21
tx51210's gallery
Awards Showcase
Total Awards: 26
I know, its a BEAR.
__________________
Old 06-21-2008, 08:58 AM   #12
Lengo
Senior Member
Lengo's Avatar
Diggs: 0
Strength: 30Lengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond reputeLengo has a reputation beyond repute
Lengo's gallery
Thanks for the lesson. I didn't know you could do this!
edit:
I tried this, with only some success. I was working with a black and white image with limited contrast (by design, not mistake). I did't get quite what I wanted out of it, but with adding some other tricks made it turn out fairly good. THANKS, TX! I never used displacement before because I didn't know how. You da man! erm.... that is a man in the picture chop, right?
Lengo is offline
Old 06
