Photoshop Tutorials | Photoshop Contests | Photoshop Forums
Go Back   Photoshop Tutorials | Photoshop Contests | Photoshop Forums > Member Photoshop Tutorials
CLICK HERE to become a member and see no ads.
Reply
LinkBack Thread Tools Display Modes
Old 12-08-2007, 07:48 AM   #1
Dookie
Voice of Nonsense
Dookie's Avatar
Diggs: 0
Strength: 15050Dookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond reputeDookie has a reputation beyond repute
Dookie's gallery
Awards Showcase
Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 2nd Place 2nd Place Tutorial of the Month Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 3rd Place
Total Awards: 10
Creating Animated GIFs Using Photoshop & Imageready
Creating an Animated Smiley/GIF/Avatar/Sig
This action packed & informative tutorial will demonstrate how I created the (McRib) smiley for Photochopz, the world's favorite forum for chopping and satirizing any & everything.
The technique can be used in many other ways than to create an oozing McRib sandwich; such as dripping blood, growing hair, stretching anatomy, etc. Feel free to use any image you wish to follow the tutorial.
I use Photoshop CS2 and Imageready CS2 to create this, but you could use any version from 6.0 to CS3 for the first part. If you don't have Imageready, you could try something like Ulead GIF Animator or Advanced GIF Animator, both of which have free trials.
1. Open this image (or your own) with Photoshop:
2. I always create a layer from the background by right clicking the Background Layer in the Layers Palate, and choosing Layer from background. This allows you to create a Mask on the base layer by clicking the 3rd icon (it looks like a rectangle with a circle in the middle) on the Layers Palate. Make sure the Foreground/Background is Black/White (you can switch to these colors quickly by pressing the D key).
If you'd rather, you can duplicate the Background instead by pressing Ctrl+J, then hide the Background Layer by clicking the little eyeball button next to the layer thumbnail. Then create your Mask on the duplicate layer (see above).
3. Select the Brush Tool (B), on this image I set mine to Size:10 px Hardness:80%. Change the settings from either location shown below:
If you need to adjust the brush size while masking, you can quickly increase/decrease the brush size using the [/] (Bracket) keys.
I find it much easier to zoom in to about 400% while masking the background. I also use a graphic pen, so this process took me roughly 1 minute. If you don't have one or aren't very steady with a mouse, you may find it easier to create a path using the Pen Tool (P) or creating a selection using the Polygonal Lasso (L).
When your done, right click on the Mask thumbnail and click Apply Layer Mask. I do this instead of just erasing the background because it's much easier to correct mistakes or add/subtract from an area using a mask. If you take away too much, hit the X key (reverses the Foreground/Background colors) and correct it. Hit it again to switch back.
If you used the Pen Tool (P) or Lasso(L) method, create a selection from your path, invert it, then hit the Delete key. If you kept the background layer, you'll have to delete it or crop the image to size it.
4. With the background gone, trim the canvas size to fit the sandwich by going to Image/Trim. Make sure the settings appear as below:
This will leave room at the bottom for our dripping sauce.
5. Create a new layer by clicking the 6th icon on the bottom of the Layers Palate
or from the Layer Menu.
Now click the Foreground color box, selecting a point somewhere in the meat. Or you can do it the long way using the Eyedropper Tool.
*If using a different image, obviously you'd choose according to what you're animating.
Using the Brush tool (B) (mine was set to Size:8 Hardness:0%), paint some sauce along the top edge of the bottom bun in an irregular pattern.
6. Duplicate the sauce layer (Ctrl+J) and use the Smudge Tool (R) with the following settings to make your sauce drip farther down:
Repeat this step once more to make the sauce ooze even farther.
*If using a different image, more layers may be necessary, common sense and imagination are your friends.
Mine ended up like this:
7. Now select the bottom layer and Duplicate (Ctrl+J) it twice. Now drag one of them between the two top sauce layers, then drag the other between the middle and bottom sauce layers.
Select the top sauce layer, and merge it (Ctrl+E) with the sandwich layer below it. Do the same with the other two sauce layers.
8. This step is only necessary if you need to make the image a certain size; my McRib needed to be 55 pixels wide. Do this from Image/Image Size, setting the width to 55px with the Constrain Proportions box checked.
9. Go to File/Edit in Imageready. If using a GIF animator instead, you're on your own as far as putting the animation together goes. Having one that can read PSD's is helpful, otherwise, save each layer individually (with all others hidden) using the Save For Web option. This will help keep the file size down if that's a factor, which it will be if creating something like an Avatar or Signature.
When IR opens, go to Window in the menu and make sure Animation is checked. Now hide 2 of the layers, it doesn't really matter which as long as you choose a different one for every frame (see below).
10. See the red circle in the image above? Click that arrow and select New Frame. Now make the middle layer visible, and hide the bottom. You'll see the frame in the Animation Palate change to match the visible layer.
11. Create another New Frame, make the top layer visible and hide the middle.
12. Repeat step 10 (of course hiding the top layer instead). You'll end up with something like this:
13. Select all frames in the Animation Palate by clicking the last frame, hold Shift, click the first. See the tiny arrow I circled in the above image? Click it and select 0.2 seconds.
14. Now to the Optimize Palate. Set it thus:
If your using a different image than the McRib, you may need to adjust some of these settings, particularly the Matte color. I tried to pick a color somewhat close to the forum's background color.
Next, go to File/Save Optimized As. Save it and look in wonder at your fantastic, dripping McRib.
Dookie is offline
Sponsored Links
Old 12-08-2007, 12:24 PM   #2
TypeO
sick twisted freak
TypeO's Avatar
Diggs: 0
Strength: 115685TypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond reputeTypeO has a reputation beyond repute
TypeO's gallery
Awards Showcase
Halloween Costume Contest Weekly Contest 2nd Place Weekly Contest 1st Place 1st Place - Member of the Month Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 3rd Place
Total Awards: 7
sh1t s0n! nice job!
tut, would again!
__________________
YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
TypeO is offline
Old 12-08-2007, 04:30 PM   #3
Dookie
Voice of Nonsense
Dookie's Avatar
Diggs: 0
Dookie's gallery
Awards Showcase
Total Awards: 10
preciate that!
Dookie is offline
Old 12-08-2007, 05:31 PM   #4
joshbond
Admin
joshbond's Avatar
Diggs: 19
Strength: 100000joshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond reputejoshbond has a reputation beyond repute
Send a message via MSN to joshbond
joshbond's gallery
Awards Showcase
Weekly Contest 3rd Place 3rd Place Tutorial of the Month Head 2 Head Contest Winner Weekly Contest 1st Place Post whoring award Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 1st Place
Total Awards: 10
This is tastic!
joshbond is offline
Old 12-13-2007, 08:53 PM   #5
bajabrit
Noob
Diggs: 0
Strength: 24bajabrit is on a distinguished road
bajabrit's gallery
do you know how to embed a link into the animated gif? Having trouble...
bajabrit is offline
Old 12-13-2007, 09:09 PM   #6
twiztedtony
PeckerWood
twiztedtony's Avatar
Diggs: 0
Strength: 29649twiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond reputetwiztedtony has a reputation beyond repute
Send a message via AIM to twiztedtony Send a message via Yahoo to twiztedtony Send a message via Skype™ to twiztedtony
twiztedtony's gallery
Awards Showcase
Weekly Contest 2nd Place Head 2 Head Contest Winner Weekly Contest 1st Place Weekly Contest 1st Place 1st place Tutorial of the Month 3rd Place - Member of the Month Weekly Contest 3rd Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 3rd Place Weekly Contest 3rd Place
Total Awards: 15
this thread gets 5 ribs
lol
__________________
Quote:
Originally Posted by Skelz View Post
Tony is officially an O.G.
Quote:
Originally Posted by The Bro View Post
Wanna chill and play some gamecube?
Video crew hotline
questions and concerns
Tt 734 444 6960
Video Crew Fo LIFE
twiztedtony is offline
Old 12-13-2007, 11:35 PM   #7
thediceman
uber-mod
thediceman's Avatar
Diggs: 0
Strength: 100000thediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond reputethediceman has a reputation beyond repute
Send a message via Skype™ to thediceman
thediceman's gallery
Awards Showcase
Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 1st Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 3rd Place 2nd Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 2nd Place Weekly Contest 1st Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 2nd Place 1st Place - Member of the Month Weekly Contest 3rd Place Weekly Contest 1st Place Weekly Contest 3rd Place Weekly Contest 1st Place Head 2 Head Contest Winner Weekly Contest 2nd Place 2nd Place - Member of the Month Weekly Contest 1st Place Weekly Contest 2nd Place Weekly Contest 1st Place Weekly Contest 1st Place Weekly Contest 3rd Place
Total Awards: 34
yeah thats a great tut man always is with you
thanks
__________________
thediceman is offline
Old 12-14-2007, 04:45 AM   #8
LogicBomb
Gold Member
LogicBomb's Avatar
Diggs: 18
Strength: 5276LogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond reputeLogicBomb has a reputation beyond repute
LogicBomb's gallery
good tutorial. repped.
__________________
You can’t argue with logic.
well, actually you could but you would lose so its a waste of your time.
LogicBomb is offline
Old 12-14-2007, 04:46 AM   #9
twiztedtony
PeckerWood
Diggs: 0
Awards Showcase
Total Awards: 15
i second that
__________________
Video crew hotline
Tt 734 444 6960
Video Crew Fo LIFE
Old 12-14-2007, 04:47 AM   #10
twiztedtony
PeckerWood
Diggs: 0
Awards Showcase
Total Awards: 15
wait i can
You must spread some Reputation around before giving it to Dookie again.
__________________
Video crew hotline
Tt 734 444 6960
Video Crew Fo LIFE
Old 01-22-2008, 10:41 PM   #11
Dookie
Voice of Nonsense
Dookie's Avatar
Diggs: 0
Dookie's gallery
Awards Showcase
Total Awards: 10
Thanks Tony, and all other Reppers. This is also a flagrant way to bump this up.
Dookie is offline
Old 02-03-2008, 09:56 PM   #12
Waaqiah
Member
Diggs: 0
Strength: 24Waaqiah is on a distinguished road
Waaqiah's gallery
always wonderd how to do that , great tut
Waaqiah is offline
Old 02-03-2008, 11:13 PM   #13
Dookie
Voice of Nonsense
Dookie's Avatar
Diggs: 0
Dookie's gallery
