Home arrow Art arrow Stunning neon light 3d typography
This tutorial is inspired by one of the creations I placed in the beauty of 3d typography article. By combining the powers of Illustrator and Photoshop, you can recreate this awesome technique.
Typography is a really hot topic at this moment in the design sphere and neon light is and has always been an effective way to attract users. Combine these two to make some beautiful artwork.
Most of this tutorial is done in Photoshop, the 3D characters are created in Illustrator. If you don't have Illustrator, you can also try making 3D letters in Photoshop.
Get ready to make some amazing typography artwork. You can download my final result as PSD from the download section.
First, we'll need to create the 3d characters in Illustrator. Start up the program and create a new file with a size of 800 x 600. I gave the image a black background because I'll be placing white characters.
Place your character using the Text tool (T). I placed the letter "M", a font called Gill Sans Ultra Bold and a white (#FFFFFF) color. With the character still selected, go to Effect > 3d > Extrude & Bevel... A new window will pop-up. I used the following settings for the 3d character.
Create more characters in your file. Give each character another kind of rotation by rotating the cube in the Extrude & Bevel Window. Place them in a way that suits you, positioning them under / above other characters, rotating them, etc. Just play around. I created my name "Marco".
Now let's go to Photoshop. Start up the program and create a new file with a size of 600 x 800. Give this file also a black (#000000) background.
Drag each character from Illustrator on a new, different layers in Photoshop. The character will be placed as an Smart Vector Object.
I wanted to add some more characters, so I did. I switched back to Illustrator, created more words (folio and .net) with the same font but with smaller size. I rotated them in all different ways and placed them, once again, in different layers in Photoshop.
Select one of the layers containing a character. Go to Filter > Stylize > Glowing Edges. This will give the character the neon glow. I used an Edge Width of 3 px, Edge Brightness of 9 px and Smoothness of 5 px.
Apply the Glowing Edges filter to all other characters, using the same settings as the previous step.
Now we're going to give this image a little bit more color. Make sure you have the top layer selected and go to Layer > New Adjustment Layer > Color Balance. A new window will appear.
I used the following settings to create a neon glow blue color. Of course, you can change this to whatever color your like.
  1. Shadows : 0, 0, 0
  2. Midtones : -71, -20, +58
  3. Highlights : -34, -23, +83
Time to add some swirly "power lines" to the artwork. To do this, select your Pen Tool and set it to Paths. Draw a path, following the line where you want to power line to be.
Now grab a hard brush with a size of 2 px and a color of #FFFFFF. This white color will be blue because of the color balance layer. Now right-click on your work path in the paths palette and select Stroke path and make sure that the source is set to the Brush. Also, check if Simulate Pressure is selected. Press Ok to apply the brush.
Repeat this step several times to draw a couple of these swirly power lines to your artwork.
To create the flakes, we'll create our own brush. Start up a new file with a size of 10 x 20 px. With the Pen Tool, draw your own "flake".
When you're done, go to Edit > Define Brush Preset and give your brush a name. Check out my example below and please note I zoomed in to a zoom level of 1200%. When you're done, you can close the file.
Go back to your other file to prepare the brush. Create a new layer beneath the color balance layer. Press F5 to bring up the Brush palette (or go to Window > Brushes). Make sure you have your custom made brush selected.
Now play around with the Brush Tip Size, Shape dynamics and Scattering to create a nice, random brush. I used the following settings.
Now draw a path (using the Pen Tool) around your typography to enhance the 3d effect.
Apply your custom brush to the path, by right-clicking on your path in the paths pallette and selecting Stroke Path. Once again, make sure you have Simulate Pressure on and the source set to Brush. Press Ok to apply the brush.
Remove the parts that are behind the typography with your eraser tool (or mask it). You should end up with something looking like this.
For the finals steps you can do whatever you want. I added a couple of sparkles using a round, small brush and playing around with Size and Spacing jitter. You can also think a little about adding another light source with nice shadow effects (Burn Tool).
Although I had something totally different in mind when starting this artwork, I still think the outcome is really cool. It was really fun to play around with, using the 3d effect from Illustrator and combining them with the powerful tools in Photoshop.
You can download my final result as PSD from the download section. If you created your own work using this tutorial, feel free to place it in the comments.
If you liked this effect, you should also check out the Glowing and sparkling intense light 3d logo.
Tags:  neon typography 3d light photoshop illustrator tutorial
Interested in this topic? You might enjoy another article I've written called
Did you like this article? Subscribe to my feed or email to keep updated on new articles.
Spread the word and submit to:
Reddit!Del.icio.us!Facebook!Technorati!StumbleUpon!Newsvine!Furl!Ma.gnolia!
Comments
Add NewSearchRSS
Ashok - Wonderful   | 122.164.165.xxx | 2008-07-13 05:13:43
Gravatar image Really nice tutorial
Jason Wild - My go at 3D typography   | 67.168.73.xxx | 2008-07-19 23:57:12
Gravatar image Wow. really nice design! its simple, yet theres alot of flare.
after your 3D typography examples I decided to give it a go. Its a bit cliche with the mirror effect and horizon, but it's a first try. the thing I'm prod about in it is the streaks around the letters. had to bust out my Wacom tablet for that. haha some things in it are a little choppy, but I think it's ok for making it at 2am while on percaset from getting my wisdom teeth out. haha
let me know what you think. we all need constructive criticism.
http://i65.photobucket.com/albums/h229/smx554/Reflection.png
Joomla boy - 3D   | 83.32.121.xxx | 2008-07-26 19:11:58
Gravatar image I didn't know Illustrator could do 3D stuff. I'm a 3D studio MAX guy myself, but I always like it when people can make simple 3D with things like illustrator and photoshop.
It's not what you use, its what comes out at the end.
Nice work
monza - great   | 79.0.113.xxx | 2008-07-27 10:42:26
Gravatar image thanks! very cool!
Anonymous   | 218.208.210.xxx | 2008-07-27 14:17:17
Gravatar image How to go to effects????the 1st step?....
Marco - Title bar   | 62.194.192.xxx | 2008-07-27 17:06:30
Gravatar image The "Effects" can be found just under the title bar in Illustrator (Next to "File" etc.)
Good luck!
Anonymous   | 122.168.14.xxx | 2008-07-30 16:25:36
Gravatar image tht ws cool...
ANON   | 92.10.71.xxx | 2008-08-16 15:25:43
Gravatar image er...what sized font did you use to start with? and did you really use 'black' as the shading for the bevel effect - my 3D letter is looking NOTHING like yours!!
not a good start - and it takes AGES to render each time i change the settings :-/
thanks
DITHER   | 92.10.71.xxx | 2008-08-16 15:35:27
Gravatar image yeh - mine also....:(
ANON   | 92.10.71.xxx | 2008-08-16 15:53:32
Gravatar image AHA!
Make sure that your character has 0 as Stroke, otherwise this will completely interfere with the 3D settings!
OK.
Now lets continue :)
Marco - Good one!   | 62.194.186.xxx | 2008-08-18 21:16:14
Gravatar image Good that you got it working!
Feel free to ask again if you're stuck and place your artwork here when you're finished :).
Good luck!
Lawrence77 - Very Good!   | 59.92.109.xxx | 2008-09-15 08:33:15
Gravatar image But the color was not nice.... :cheer:
All the others are nice indeed...
great work... :woohoo:
Lawrence77 - PSD file is not working...   | 59.92.109.xxx | 2008-09-15 09:16:26
Gravatar image :( the PSD file u give in download section is not working, it encountered a problem while opening in my PS CS1
Marco - What problem?   | 92.67.255.xxx | 2008-09-15 09:22:12
Gravatar image Hi Lawrence77,
What problem did you get when opening the file? The file was created in Photoshop CS3.
You can also try downloading again: The file could be corrupted while downloading.
Lawrence77 - TO-MACRO   | 59.92.109.xxx | 2008-09-15 09:31:28
Gravatar image 1st it shows .
Unknown data has been encountered for all letters u use one by one..
At last it shows a messagebox "could not complete your request because an unexpected end-of-file was encountered."
i'll try to download again and check... :angry:
Lawrence77 - NOW ITS SOLVED   | 59.92.109.xxx | 2008-09-15 09:41:01
Gravatar image Now it opens... thanks for your answers ..
:woohoo:
Stefan - Nice tut   | 91.150.111.xxx | 2008-11-15 20:26:02
Gravatar image Thanks for tutorial, i like it.
Maggie   | 99.139.230.xxx | 2009-01-07 21:47:21
Gravatar image love the tutorial... i'm going to try it out this afternoon!
Read more...
Name:
Email:
  Gravatar enabled.
Website:
Title:
UBBCode:
[b] [i] [u] [url] [quote] [code] [img]
:angry::0:confused::cheer:B):evil::silly::dry::lol::kiss::D:pinch:
:(:shock::X:side::):P:unsure::woohoo::huh::whistle:;):s
:!::?::idea::arrow:
Security Image
Please input the anti-spam code that you can read in the image.
Unsubscribe from e-mail notifications.
< Prev   Next >
Subscribe
Navigation
Search
Search:
Sponsors
Blogrush
Proud 9rules member
