| Web Hosting Deals | Holiday Logo Design | Website Header Templates | Register domain | Search Engine Optimisation | Web Hosting |
| Web Layouts Create professional webpage layouts with this very detailed, step by step tutorials. |
Submit Tools | LinkBack | Thread Tools | Display Modes |
Hello
Today we will continue with our marathon. This is tutorial number 163. In this tutorial I will show you how you can create a simple design portfolio layout. Or you can use this layout if you want to create a wordpress theme ![]() Let’s start as usual with a new document. The size doesn’t matter. I m using 760 X 770 pixels Copy the following image on your computer ![]() Open this image in photoshop, then go to Edit > Define pattern. Chose a name for this grass pattern, and click OK. Create a new layer ( press CTRL+SHIFT+ALT+N ) in the same time Grab Paint bucket tool, and Set source for fill area to : pattern ![]() Then on the layer we just created, add this gradient with Paint bucket tool ![]() Set the foreground color to #120c0c , and with brush tool, you can draw at the bottom of your layout, until you have the following result: ![]() Now with rounded rectangle tool, add some buttons ![]() for all these shapes add the following layer style ![]() ![]() Here is my result ![]() Now i will add some images on the bottom part of the layout, and in the same time i will add also some text ![]() Under the numbers, i will add a Grey rectangle. i will create this shape with rectangle tool ![]() With type tool, i will write some minus signs ![]() I will duplicate this layer with minus signs , and i will rotate it 90 degrees ( to rotate a layer first you need to select it, then go to Edit > transform > rotate 90 ![]() this is my layout so far ![]() On the header i will add a plane icon ![]() If you have Photoshop Designer's pack you will find some nice brushes for the next step. i want to add like a scarf at the end of our plane You will find this brush in the " banners " folder ![]() ![]() I am sure you will find another type of banner/ scarf in this set If you don't have the photoshop designer's pack, you can create this scarf with pen tool In the next image you can see how i placed the scarf, at the end of the plane ![]() To create a more realistic effect i will add some lines ![]() I will select brush tool, and with a small rounded brush i will create a few points ( i will use the same color as the sky ) To select the same color you can use Eyedropper tool this is my result ![]() My final step is to add some text on this scarf This is my final result ![]() Please download this layout from attachment area to understand better how it's made
__________________
3D Logo Creator + Mega Pack + Photoshop Designer's Pack = Only 148$ ( save 150 $ - use coupon code: talk ) |
such a great tutorial but i guess the background is already been implemented Web Development Blog: Web Development Insights, Best Practices, Tips & Techniques : Viget Labs if you try to look into it.... anyway, i salute you admin for having this tutorial thanks.
__________________
Philippines Freelance Web offers Web Design, Logo Design, Web Redesign, Website Development, Website Maintenance in freelance rate. For more information please visit our website. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
