Escalight - 3ds Max tutorial, Photoshop, Flash, V-Ray, Blender, Free 3D models, etc
HOME arrow TUTORIALS arrow 3dsmax Tutorials arrow Dice Roll Animation Part 1
Thursday, 04 December 2008
Main Menu
HOME
WHAT's NEW
ARTICLE
FORUM
TUTORIALS
FREE STUFF
CG SHOP
LINKS
SEARCH
FEEDS
ABOUT US
FAQ
TERM OF USE
CONTACT US
DONATE
OTHER SITES
escaMoney
Dice Roll Animation Part 1 PDF Print E-mail
User Rating: / 17
PoorBest
by Didik Wijaya
Dice Roll AnimationIn this tutorial I will show you how to create dice roll animation with ease. This tutorial is divided into 2 section. First, this section, you will create 3D dice model using quick techniques. Second, you will create the animation. Not only one dice, but as many as you want. Let's begin by creating 3D dice model.
1. Open or reset your 3dsmax. Go to Command Panel. Choose Extended Primitives from drop-down list. Click ChamferBox button. Then, click and drag in viewport to create ChamferBox. Next, go to Modify tab and enter values in image below. When finished, you get basic shape of a dice.
2.Right click ChamferBox and choose Convert to>Convert to Editable Poly. In Modify tab, activate Polygon selection. Select 4 polygons at one side of ChamferBox (hold Ctrl while clicking to select more than one polygon). After that, in Edit Polygons rollout click Settings button right next to Inset. In Inset Polygons dialog box, enter Inset Amount=3. Don't deselect anything. This time, click Settings button right next to Extrude. In Extrude Polygons dialog box, enter Extrusion Height=-2.
3. Next, select 2 polygons in the middle. Use the same value of Inset and Extrude. When finished, you get 6-dotted at one side of the dice.
4. Using the same procedure, apply Inset and Extrude to all side of the dice. Tips: Having a real dice in front of you is helpful. You can easily know how many dotted needed in each side. If you don't have a real one, you can look at image below.
5. Next, select all extruded polygons in all sides. There are 21 polygons you need to select. As always, hold Ctrl while clicking to select more than one polygon. In Selection rollout, click Grow to add more selection. Then, in Polygon Properties rollout enter Set ID=2. By default, other polygons have ID=1. When finished, turn off Polygon selection.
6. In this step, we are going to add material. Open Material Editor (press "M" in keyboard). By default, one of unused sample material slot is selected. Name this material "dice". Click Standard button to change material type. In Material/Map browser double click Multi/Sub-Object. In opened dialog box, just click OK. In Multi/Sub-Object Basic Parameters rollout click Set Number, enter 2 and click OK. You only need 2 sub material. Click button under Sub-Material (where ID=1). Name this sub-material "white" and change Diffuse color to white. Click Go to Parent button to go back to Multi/Sub-Object Basic Parameters rollout. Using the same procedure, change other sub-material name where ID=2 to "red". Use red Diffuse color. Click Go to Parent button. Finally, click and drag from sample slot to dice object in viewport to appy material.
7. To finish this tutorial section, apply Turbosmooth modifier to dice object. Use Iterations value=2..
8. Image below shows rendered dice. Next, you will animate the dice.
Download finished 3D dice model here (3dsmax ver 8)
Dice Roll Animation Part 1 | Part 2
Any question or comments regarding this tutorial should be sent to:
Didik Wijaya, email: This e-mail address is being protected from spam bots, you need JavaScript enabled to view it
Discuss this tutorial
< Prev   Next >
Most Popular Tutorial
Newest Free 3D Models
FileWarrior Double Axe
Warrior Double Axe. Common low poly double blade axe used in battle
FileWarrior Single Axe
Warrior Single Axe. Common low poly single blade axe used in battle
FileCartoon Landscape
Cartoon landscape, with trees, hilly ground, and road. Tutorial about making this scene is a...
FileJack-O-Lantern
Jack-O-Lantern, carved pumpkin associated with Halloween holiday
FileSlimer from Ghostbuster
Slimer, ghost character from Ghostbuster The Movie. Created using 3ds max 8
Go to our free stuff section. You can find more free 3D models, vector art, clip art
Login Form
Lost Password?
No account yet? Register
Your Shopping Cart
Your Cart is currently empty.
Popular Download in Last 30 Days
1435
FileSimple Bedroom
1108
FileTable 07
732
Copyright © 2008 Escalight - 3ds Max tutorial, Photoshop, Flash, V-Ray, Blender, Free 3D models, etc. All rights reserved.
Donate to make this site better
