Photoshop design music control volume in photoshop
Here we will tell you how to make a Photoshop design music control volume in photoshop.
[1] Take a new file of 400 pixels, 400 pixels, of resolution 72 dpi in the RGB mode.
[2] Start by creating a rectangle using rectangular shape tool color is red.
[3] Press Ctrl+T. Right Click and select Warp. Select “Inflate” style from the preset warp shapes. Apply settings as shown.
[4] After that rotate your shape like me.
[5] Now create the following selection wiht the help of Elliptical Marquee Tool.
[6] Go to Select>Modify>Feather use these values.
[7] Create a new layer fill the selection with Black color.
[8] Create a circle using elliptical shape tool.
[9] For this shape add the following layer styles.
[10] Now Create one more circle using elliptical shape tool.
[11] Add the following layer styles.
[12] Ctrl+Click on previous layer to get selection, go to Select>Modify>Contract Selection by 2px.
[13] Create a new layer fill the section with white color.
[14] For this shape add the following layer styles.
[15] Choose Gradient to and set properties like this.
[16] Create the following selection with Elliptical Marquee Tool, Apply gradient to selection to get the result like this.
[17] Now set the opacity 62%.
[18] Done!!! I hope you like it.
batch watermark photoshop
bend text in photoshop
best photoshop tutorials
