Setting up a Datasource
This guide will take you through the steps of setting up a datasource in the coldfusion administrator.
To setup a datasource you will need to login to the coldfusion administrator. The Coldfusion administrator is usually found under <root>/CFIDE/administrator/ you will then need to login with the password created on installation.
Coldfusion Login
You then need to navigate to the Data sources page under Data & Services on the navigation. When on this page you will need to give your Date Source a name and select the database type you are connecting to. When you have done this click add.
Data Sources
On the next page you will need to enter your database connection details and click submit.
MySQL
Your database connection will then verified and you will be notified if the connection was successful.
Connected Data Sources
Enjoy!
Related Blog Entries
Comments
Archives By Subject
Advertising (3) [RSS]
Blog Design (1) [RSS]
CFProject Scripts (2) [RSS]
Coldfusion Charts (3) [RSS]
Coldfusion Functions (5) [RSS]
Coldfusion Overview (1) [RSS]
Coldfusion Tutorials (17) [RSS]
For Sale (2) [RSS]
Image Manipulation (1) [RSS]
Java (1) [RSS]
JavaScript (4) [RSS]
PHP (1) [RSS]
Useful Tools (3) [RSS]
Recent Comments
Coldfusion and Java
Henry Ho said: I'm more interested in writing Groovy with CFGroovy. I think you may want to look into that as well... [More]
Coldfusion and Java
Jeremy P said: Since CF is build on Java, it's very easy/handy to use it. I recently had to "drop down"... [More]
Coldfusion and Java
Kumar said: Similarly to what Ben said, we have used Java objects in ColdFusion to perform certain tasks. Dan V... [More]
Coldfusion and Java
Ben Nadel said: I use Java objects in ColdFusion all the time. The CreateObject( "java" ) method makes it ... [More]
Coldfusion and Java
Steve Brownlee said: Yes, I can provide some advantages, but that's a large discussion. It can provide speed advantages ... [More]
Recent Entries
Coldfusion and Java
Coldfusion Hosting From £2.50
Coldfusion Blog | Coldfusion Hosting | About Me
